Old 12-13-2006, 10:01 AM   #1
goixiz
Member#: 99128
2005 SAAB 92x
Question OEM CD changer from 2007
Will the new 2007 cd changer work in a 2005 car
Prefer not to cut cables and rewire - I like the plug and play idea
Thanks for any suggestions or idea
goixiz is offline   Reply With Quote
Old 12-15-2006, 12:15 AM   #2
SpaceGhost
Member#: 69913
2011 STI Limited
Dark Grey Metallic
Yes
SpaceGhost is offline   Reply With Quote
Old 12-16-2006, 12:43 AM   #3
RedImpreza07
Member#: 130600
2004 WRX
Yup just swapped out my single CD in the 2007 to a 6 CD from a 2005 STI. No problem. Plug and play.
RedImpreza07 is offline   Reply With Quote
Old 12-16-2006, 01:01 AM   #4
tacomaprime
Member#: 70572
2005 Tacoma
yes sir it will. I just put a 6 disc changer from an STI limited into my 05 wagon. Completely plug and play.
tacomaprime is offline   Reply With Quote
Old 12-16-2006, 01:05 AM   #5
goixiz
Member#: 99128
2005 SAAB 92x
what color is the LED or background of the 2007 unit
Did you have tobuy the cable for the AUX in ?
Old 12-16-2006, 01:25 AM   #6
tacomaprime
Member#: 70572
2005 Tacoma
The background is green, and the letters/numbers are black. Actually looks good.
I did not hook up the AUX in, cause I don't have an ipod.
Old 12-16-2006, 05:43 PM   #7
goixiz
Member#: 99128
2005 SAAB 92x
is that a cable i can make from radio shack parts ?
or the connector to the radio is very specific ?
Old 12-16-2006, 05:48 PM   #8
Legba
Member#: 88589
2005 STI
the best one
I'd be interested in knowing how to do this also.
Legba is offline   Reply With Quote
Old 12-18-2006, 01:49 PM   #9
Legba
Member#: 88589
2005 STI
the best one
Anyone?
Old 12-18-2006, 02:03 PM   #10
durchins
Member#: 19259
2004 STI
White/Silver
I will be putting a 07 headunit with the accessory port on ebay in the next few days. I have no idea what it is worth. If interested shoot me a pm
durchins is offline   Reply With Quote
Old 12-18-2006, 04:45 PM   #11
06STIGO13
Member#: 110526
2007 STI Ltd 306 UGM
2008 STI Nav & BBS AW
You can buy the cable needed at radio shack... they have a 3.5 to 3.5 cable that plugs into the ipod headphone jack and the other end plugs into the aux in that connects to the radio! Radio shack only has 6ft and 12ft cables though, but I found a 3ft cable at Best Buy.
06STIGO13 is offline   Reply With Quote
Old 12-19-2006, 01:30 PM   #12
Legba
Member#: 88589
2005 STI
the best one
Does the 2007 unit play MP3s? Can that cable be made to work on a serial port on a PDA?
Old 12-19-2006, 01:57 PM   #13
tacomaprime
Member#: 70572
2005 Tacoma
I think he's talking about just running a cable from the ipod to the back of the stock HU, which I don't think will work. The connector the the aux looked different on the back of the HU.
Someone correct me if I am feeding BS.
Old 12-19-2006, 01:57 PM   #14
tacomaprime
Member#: 70572
2005 Tacoma
yes, it does play mp3's That was the sole reason I bought one.
Old 12-19-2006, 04:52 PM   #15
06STIGO13
Member#: 110526
If that is what he is asking, then no, I don't think you can't connect the ipod directly to the back of the stock radio. I don't think there is anything to connect to, i.e. aux input! As someone else said though, yes the 07 radio plays MP3s.
Old 12-19-2006, 07:17 PM   #16
Legba
Member#: 88589
2005 STI
the best one
What does the auxilary port look like? USB?
Old 12-19-2006, 07:58 PM   #17
jsmithjr732
Member#: 20272
2007 SWP STI
I have an 07 STI and took my radio out while trying to connect the Sirius tuner to it. The aux port connects to a cable about 4 inches behind it--and it's not USB. Doesn't appear to connect to the radio. It probably connects through the main radio connector. If you can compare an 05 to an 07 connector, you'll probably see the differences. I assume there'll be a few more cables in it or something.
If I recall correctly, the stock unit has:
1. Radio connector
2. Antenna connector
3. Power connector
4. Sirius tuner connector
That's it. Search here or iwsti.com for "ESN" or "SID" and you'll find wrxgrl's thread. I have a few pix uploaded. Here's the link to my site's pix:
www.jsmithjr.com/subaru/radio
John
jsmithjr732 is offline   Reply With Quote
Old 12-20-2006, 07:21 PM   #18
goixiz
Member#: 99128
2005 SAAB 92x
what if you want to use XM instead is there a CeNet unit for XM to connect to it ?
And which plug is for the Aux wire (is it the white connector)
I bought a HU but seller did not include any wiring
Old 12-20-2006, 07:44 PM   #19
jsmithjr732
Member#: 20272
2007 SWP STI
Search for the thread I referenced above. It has pix along with information in it.
I don't know which one is the AUX. The aux ash tray unit has a mating plug behind it, but I don't know where that wire goes--maybe the small white one on the opposite end of the antenna plug?
Old 12-27-2006, 05:24 PM   #20
Jpapania
Member#: 61202
2004 WRX Wagon
WR Blue
This is probably a stupid question, but I am assuming if this swap would work in an 05 there would be no issues in doing in an 04 wagon? It is just simple plug and play right? Would be so nice to burn MP3 disc and also work on getting the AUX input hooked up
Jpapania is offline   Reply With Quote
Old 01-05-2007, 06:18 PM   #21
SilvrWRX
Member#: 8582
2007 Impreza WRX
Default Just took out my 2007 radio and aux port
Here are some pics for those who are wondering about the aux input on the 2007 factory radios. I don't know if any of the previous factory radios had this rear input, but here is a pic of the back side. The aux port interconnecting cable plugs in the port circled in green.
The interconnecting wire connects from the radio rear port to the cable coming from the ashtray aux port. Here is a picture of the connectors from the ashtray aux port (left) to the interconnecting wire (right).
Just an overview.
SilvrWRX is offline   Reply With Quote
Old 01-05-2007, 07:24 PM   #22
jsmithjr732
Member#: 20272
2007 SWP STI
Right on the money. From right to left:
1. CNET cable for the Sirius tuner
2. AUX cable going to the ashtray port
3. Main radio cable
4. Antenna
Old 01-06-2007, 03:11 PM   #23
SilvrWRX
Member#: 8582
2007 Impreza WRX
Default connector details for interconnecting wire
SVXdc requested some detailed pics of the connectors for the interconnecting wire. There are 5 contacts, but I'm not sure what they are all for. Ground, left, and right? That would leave 2 for something else. I don't believe any of these wires are for lights as the "AUX" label in front doesn't light up. Use the 1 inch mark as the reference starting point. Sorry no metric.
This connects to the plug from the ashtray box.
This connects to back of radio. Sorry they're a little blurry.
Old 01-06-2007, 04:26 PM   #24
goixiz
Member#: 99128
2005 SAAB 92x
when you want to use the AUx port for input
does it automatically switched from cd to aux ?
just wondering how it switches ?
whats the CAT button for ?
Old 01-06-2007, 06:25 PM   #25
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
You probably have to press the CD/AUX button to toggle between those two sources.
When you're in SATellite mode, this allows you to change categories -- notice how the up/down button in the middle says "SEEK/TRACK/CAT".
See this thread: SIRIUS ESN/ID Number (it gets interesting starting at about post #23)
ADDED: That is the post by "wrx grl" that jsmithjr732 was referring to in post #17 above.
WTB: 2007 WRX OEM cd-changer pj_cab NWIC Private Classifieds 1 03-14-2013 09:14 PM
FS: OEM CD Changer from 04 WRX Leprakkon Interior/Dressup/Audio & Security 0 09-02-2009 02:09 PM
WTB 2007 OEM CD Changer jaWn Private 'Wanted' Classifieds 0 11-25-2007 06:02 PM
FS: 6 Disc CD/MP3 Changer from 2007 Impreza 2.5i, with AUX Input Jack tarp Interior/Dressup/Audio & Security 3 08-27-2007 04:58 PM
FS: OEM 6 CD changer from 04 Forester XT SzGuy Private 'For Sale' Classifieds 0 10-23-2005 11:05 PM
