Old 01-09-2007, 07:31 PM   #1
nyyankees003
Member#: 71877
2003 Legacy L SE
Mystic Blue Pearl
Default Sway Bar Install Q's
Ok so i just recieved my whiteline adjustable rear sway bar and endlinks, has anyone installed this before? Should i just go to a shop and get it installed? I'm just wondering how difficult it is and if anyone has any tips or anything.
-Andrew
nyyankees003 is offline   Reply With Quote
Old 01-09-2007, 07:49 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Not hard. Get the rear up on some ramps, not in the air, and go to it. Pretty self-explanatory once you get under there. Take the bolts out of the endlinks...
Jared
gtwagon941 is offline   Reply With Quote
Old 01-09-2007, 08:09 PM   #3
sha_zapple
Member#: 41012
1998 Legacy L
http://sl-i.net/FORUM/viewtopic.php?t=16
Its for a 95-99, but its the same basic idea
sha_zapple is offline   Reply With Quote
Old 01-09-2007, 08:46 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Also, it helps to remove the muffler from the hanger. It'll give you a little extra clearance when you finagle the bar out. I had to take off the right wheel and wiggle it out from there because the jacks couldn't go high enough to take the bar out from the bottom.
rougeben83 is offline   Reply With Quote
Old 01-09-2007, 11:16 PM   #5
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
You'll need enough clearance to angle it out. A big tip is spinning the bar as you work it out to clear the exhaust.
Plays_With_toys is offline   Reply With Quote
Old 01-09-2007, 11:54 PM   #6
Reason01
Member#: 82150
1998 Legacy SL-i.net
Oh damn, Lee is going to get banned or get this thread lock. WAY TO GO LEE!
Reason01 is offline   Reply With Quote
Old 01-10-2007, 12:11 AM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Beat me to it!
Wiscon_Mark is offline   Reply With Quote
Old 01-10-2007, 01:27 AM   #8
OutbackGT
Member#: 135173
2007 Acura TL-S
2015 Bolt C-Spec
I did mine with the rear in the air and the wheels off. Pretty simple really.
OutbackGT is offline   Reply With Quote
Old 01-10-2007, 11:19 AM   #9
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
You ruined NASIOC Lee
legacy99black is offline   Reply With Quote
Sway bar option q's Brody8877 Newbies & FAQs 10 12-17-2008 03:00 PM
Front Sway bar install - subframe q's christothes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2002 12:58 PM
SPO adj. sway bar install 2.5GTL Legacy Forum 1 05-31-2001 04:53 PM
Sway bar install : suspension - to compress or not compress? Puckaveli Brakes, Steering & Suspension 15 03-06-2001 08:20 AM
Rear Sway Bar Installation STORER General Forum Archive 26 10-19-2000 08:45 PM
