#1 |
Member#: 105772
Vehicle:2002 WRX Sedan Midnight Pearl |
Anybody know what the best way to resurface the headlight lens? Mine are all pitted and such... also, what is the best bulb set up on a budget?
JK
#2 |
Member#: 29355
NWIC
Vehicle:03 subarus are for lesbians, not douchebags |
GE Nighthawks.
and there's some plastic polish that might work with an orbital, or something, but i have heard too many horror stories about that to really condone it. |
#3 |
Member#: 125413
NWIC
Vehicle:2002 STi wannabe WRB - Sold |
There's a thread floating around about using a fine grit sandpaper and then using a polishing compound - it had before and after pics and the after pics were amazing. I'd post the link but i'm too lazy to search for you to find it.
#4 |
Member#: 57833
SCIC
Vehicle:2002 WRX Wagon PSM |
I tried wet sanding it down to 2000 grit but ended up having very very very fine scratches all over that can't be buffed futher down with whatever plastic polish I used. Orbital sanders are hard to use on this 'cause if you buff too hard you'll burn the platic and create swirl buff marks.
Words of advice: If you never tried sanding/spray painting, stay away from this... if you really want to try, look for those plastic lens refinish kit, you might have better luck with those. |
#5 |
Member#: 121459
SCIC
Vehicle:2002 WRX Silver |
I think you guys might be getting "orbital" buffers confused w/ "rotary" buffers...Orbital buffers don't really go very fast at all & I would be amazed if anyone ever burnt a hole through anything w/ one ever...they spin off-axis at fairly low speed. Rotary buffers, on the other hand, are what detail shops use in the "cut & buff" process of a paint job. They are meant to be used after the wet sanding stage, as they just spin in one place at much higher speed than an orbital.
#6 |
Member#: 27504
Vehicle:2002 WRX sedan WR blue |
There is a plastic polish called Flitz, it works very well on the headlight plastic after sanding with 2000 grit. There catchy saying is "Just Flitz it!" It is a amazing polish really, also works on aluminum. You can apply it with there buff ball or use an orbital polisher.
#7 |
#8 |
Member#: 83638
SCIC
Vehicle:2002 wrx winglesswhitesaloon |
just did my friends last night. but its a bimmer
http://forums.bimmerforums.com/forum....php?p=8425933 |
#9 |
Member#: 50142
South East
Vehicle:2002 2.5TS MBP |
May not take out all the pits and scratches, but it'll help. |
#10 |
Member#: 57833
SCIC
#11 |
Member#: 62856
Tri-State
Vehicle:MBP WRX SQC#197 Upgrade Time! |
Plastix works great. If you check out autopia.org someone did it with the 1500 grit as well and they came out wonderful.
With plastix, just make sure you rub it in well enough before wiping, otherwise it'll just make it foggy. found the link on autopia. http://autopia.org/forum/car-detaili...ion-guide.html |
