Old 12-17-2006, 08:47 PM   #101
AGL_7882
Member#: 97623
05 WRX
WR Blue
Originally Posted by WRXRallyBlue View Post
What exactly is it you want to know?
just general performance, reliability, and any major differences
AGL_7882 is offline   Reply With Quote
Old 12-18-2006, 01:09 AM   #102
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Aside from what we discussed in the pm, not sure what else to tell.
I don't know much about the tc.com turbos aside from they're cheaper than their competitors and it seems those who've bought them have been happy with their performance.
I have yet to make a decision on deadbolt turbos or not. Many swear by them and many swear never to buy them..
I can tell you that any performance differences and the reliability between the two will probably be minimal and you should purchase based on brand preference and your comfort in the decision.
WRXRallyBlue is offline   Reply With Quote
Old 01-05-2007, 04:17 PM   #103
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
wow, it just shows you how much i visit this forum... this is the first i've seen the thread!
just a minor point... on the vf23 section it states that it spools "significantly faster" than its big brother, the vf22. i would rephrase that to read "slightly faster."
basically from what i've seen on other vf22 datalogs, they're spooling only the tiniest bit slower than mine. like 50-100rpms.
as a bit of additional info, it was fitted standard on the 22b, but the vf22 could be added as a no-cost factory option.
Old 01-07-2007, 11:06 PM   #104
Sharky NRK
Member#: 29549
2003 WRX
also I may be wrong but I think the VF39 doesn't have the P15 housing, I have heard P17 and I think deadbolt said he has seen them with P18s
Sharky NRK is offline   Reply With Quote
Old 01-09-2007, 07:44 PM   #105
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks.
Old 01-20-2007, 02:20 AM   #106
Stevothehero
Member#: 137600
2002 RS 2.5
Midnight Black/Blue
im guessing that all the turbos ment for the WRX's are also able to go on the RS's right?
or what?
Stevothehero is offline   Reply With Quote
Old 01-20-2007, 07:50 AM   #107
Sharky NRK
Member#: 29549
2003 WRX
or what?
well there are a whole lot of things necessary for bolting a turbo designed for a wrx on an rs. Namely turbo crossmember, exhaust manifolds, uppipe, downpipe, i/c setup just to physically make it attach assuming the n/a 2.5 (253??) has the same exhaust port configuration as the 205 or 257. Fuel, EM, ect are also required to make it run well.
Old 01-20-2007, 12:18 PM   #108
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
You could make just about any turbo work with some custom fabbing and patience. If you are using wrx parts to turbo your rs you'd probably want to stick to the bolt-on turbos available.
Old 01-21-2007, 03:59 AM   #109
Stevothehero
Member#: 137600
2002 RS 2.5
Midnight Black/Blue
what do you mean a "bolt on turbo"? do you mean like the main turbos are primarily made for the wrx so the "bolt on" ones are better made for the rs?
Old 01-21-2007, 08:12 AM   #110
Sharky NRK
Member#: 29549
2003 WRX
he means turbos that bolt onto the stock WRX uppipe and downpipe flanges with the proper for stock WRX clocking orienation. There is no "bolt-on" turbos for the RS - there are bolt on "kits" that you can buy or source out of WRX/STi parts
Old 01-21-2007, 03:24 PM   #111
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
That's correct. If you look through the list, the turbos either say "bolt-on" or "kit," etc. next to them.
Old 01-22-2007, 01:43 AM   #112
Stevothehero
Member#: 137600
2002 RS 2.5
Midnight Black/Blue
Smile
sweet, thanks mate
Old 01-24-2007, 07:04 PM   #113
NotPhilTran
Member#: 124888
what turbo does the 2007 limiteds get?
NotPhilTran is offline   Reply With Quote
Old 01-24-2007, 08:56 PM   #114
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
vf 43
007WRX is offline   Reply With Quote
Old 02-09-2007, 11:24 PM   #115
lester
Member#: 138937
2005 STi
CGM
wow that's alot of info!!! good gouge though. Thanks!
lester is offline   Reply With Quote
Old 02-12-2007, 11:16 PM   #116
909scoobySti
Member#: 140601
Great write up
This is the standard equipment turbocharger used on the JDM Subaru Impreza WRX. The VF35 is similar to the VF34. It utilizes the same compressor housing and the same compressor inducer size. The differences are in the divided thrust-bearing design and the P15 exhaust housing. This allows the VF35 to spool slightly quicker than the VF34 at the cost of less top-end performance.
Expect to achieve full boost with the proper mods and a quality tune between 2800-3300rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles.
909scoobySti is offline   Reply With Quote
Old 02-12-2007, 11:17 PM   #117
909scoobySti
Member#: 140601
Edit: You guys just updated it lol
Old 02-16-2007, 04:55 PM   #118
AGL_7882
Member#: 97623
05 WRX
WR Blue
why are turbocharger.com's turbos so cheap compared to everyone elses turbos? specifically the td05-18g? does anyone have any experience or advice they can give me on this turbo?
Old 02-17-2007, 08:24 PM   #119
bosozokujin
Member#: 141042
dang they are cheap, imma get mine from here prolly
bosozokujin is offline   Reply With Quote
Old 02-18-2007, 11:30 PM   #120
DSycks
Member#: 137943
2005 Evo RS
Wicked White
Would I be right in thinking that most of these turbos would come on boost a hint faster on a 2.5 liter motor? Looks like most of the numbers are based on 2.0 WRX type action.
DSycks is offline   Reply With Quote
Old 02-19-2007, 01:49 AM   #121
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
You would be right in thinking that
Old 02-20-2007, 10:06 PM   #122
steve1221
Member#: 113080
10 WRX
Dude! What the heck is this? I thought I had my turbo choice narrowed down to 2 possibly 3 turbos. Now I'm all messed up. Excellent info and thank you for taking the time to write this.
steve1221 is offline   Reply With Quote
Old 02-21-2007, 08:37 AM   #123
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
just shift the spool numbers 25% lower.
Old 02-21-2007, 02:57 PM   #124
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
No problem.
Old 02-22-2007, 01:10 AM   #125
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Originally Posted by Anthon View Post
cool....where you get all those?
You can paypal me
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
