Old 02-03-2007, 04:04 PM   #1
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
Default drained coolant, how much needed to fill?
long story short, i drained coolant from the point where you install the engine block heater. i put about a gallon in the radiator, turned my car on and let it heat up, but my heater is blowing cold air. anyone know how much coolant is needed?
ihavebettersound is offline   Reply With Quote
Old 02-03-2007, 04:27 PM   #2
dibblejr
Member#: 94070
05 LGT
The Owners Manual has all the answers but I will help you. This is the only PROPPER METHOD to add coolant and purge air from the system
AT NO TIME OPEN THE RADIATOR CAP
Use propper 50/50 mix for all coolant resevoirs.
1) Fill the coolant resevoir (plastic bottle) to the fill line (put cap on)
2) Fill the Turbo Coolant Reevoir (small metal right in front of turbo) (put cap on)
3) Start car and turn on heater (high)
4) Hold RPM's at 3000 for 10 minutes ( even if temp = H)
5) Turn engine off and leave key to ACC (keep heater on)
6) Let engine cool to "C"
7) Repeat steps 1-6 until no coolant is required to fill resevoirs
While replacing my turbo took 45 minutes to complete the process.
Like I said above DO NOT open radiator cap at anytime, to do so will negate everything you are trying to do.
Any other ways mentioned to burp the system on our cars are Shade Tree Mechanics.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-03-2007, 04:32 PM   #3
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
ok ill give that a try. thanks a lot.
Old 02-03-2007, 05:37 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The owners manual has fluid capacities??? OMG!!!
Old 02-03-2007, 07:16 PM   #5
ihavebettersound
Member#: 74882
2004 WRX
JBP Cobb Stage II
ha who would have thought.
that worked perfectly, thanks again.
Old 02-04-2007, 08:17 AM   #6
dibblejr
Member#: 94070
05 LGT
Glad you got it.
Jay-R
Old 02-20-2007, 01:13 PM   #7
cornerbuddy28
Member#: 88976
Main Ingredients:
WRX motor, PPG's, me
just curious, why does the heat need to be on high? just to help keep it from overheating while you're doing this?
cornerbuddy28 is offline   Reply With Quote
Old 02-20-2007, 01:34 PM   #8
dibblejr
Member#: 94070
05 LGT
For the recirculation effect throught he heater core. It just speeds the process up, this step is used in every car. It also in most cases lower the engine temp, it will not prevent a car from over heating.
Jay-R
Old 02-20-2007, 02:19 PM   #9
cornerbuddy28
Member#: 88976
Main Ingredients:
well coolant flows through the core whether you have the fan on or not, I don't see why having it on will help this go any faster. If it's off, the engine
will come to temp faster. I'm not debating whether those directions are correct or not, that's straight out of the manual, I just don't see why that is necessary.
I'm just trying to figure out if I might have to change something on my car because its a 95 Impreza with an 02 wrx motor and an 04 STi dash. I didn't get any of the heater controls for the center panel but instead made my own face plate out of aluminum and the heater is controlled by a switch. on or off so if there's something in the electrical system that needs to be switched on besides just the heater fan relay then I may have a problem.
Old 02-21-2007, 11:08 AM   #10
SubieRon
Member#: 64485
2004 GGA
i bought one gallon of the Subaru coolant. Am i going to need another gallon for a flush?
SubieRon is offline   Reply With Quote
Old 02-21-2007, 11:33 AM   #11
dibblejr
Member#: 94070
05 LGT
Absolutely. I dont buy suby stuff (overpriced) I buy Prestone Pre Mixed 50/50.
Ensure you follow the instructions I posted to get the system burped Properly.
Jay-R
Old 02-21-2007, 11:45 AM   #12
SubieRon
Member#: 64485
2004 GGA
damn...it is overpriced but i was reading somewhere about how our components are made of aluminum and stuff so i wanted to stick with the OEM stuff. time to return this thing. i think i paid like $25 for it, theres no way im paying another $25. I could just let the dealer take care of the flush for the price of 2 gallons.
Old 02-21-2007, 04:53 PM   #13
WRX_JUNKi
Member#: 100695
2006 WRX Limited
Regardless of what I use for the main antifreeze (Prestone, PEAK, OEM), after flushing, I would pour the conditioner and the Red Line Water Wetter prior to filling. Correct?
WRX_JUNKi is offline   Reply With Quote
Old 05-19-2007, 06:53 PM   #14
_sti_05
Member#: 72313
16 STi
question but after removing my fmic a while back, i never put the coolant resevoir which im guessing is the one next to the radiator back on, i could never find it. is this bad, i just have the hose hanging loose.
_sti_05 is offline   Reply With Quote
Old 05-20-2007, 03:40 PM   #15
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If I understand you correctly, you no longer have the coolant overflow tank in your car, which was probably removed to make way for your FMIC.
Without it, when the coolant expands due to heat, which obviously will happen when the engine warms up, any "excess" coolant in the cooling system will flow out to the ground instead of into the overflow tank.
This results in an overall loss of coolant, which means besides polluting the environment, you will be spending more money on additional coolant to replace that coolant which flowed out onto the ground.
And, if you lose enough coolant and don't realize it, your engine will overheat. How bad it overheats, and for how long, will determine the amount of possible engine damage you will ultimately have.
If the coolant went to the overflow tank, it would return to the engine when the engine and coolant cooled.
Old 05-21-2007, 12:54 AM   #16
_sti_05
Member#: 72313
16 STi
i see, thank you very much. I will be ordering a replacement asap.
How much notice to give roommate that they need to move? Stroke Off-Topic 28 01-14-2010 02:13 PM
How much water do I need to fill up a 1 gallon container? mattjk Off-Topic 86 06-02-2004 02:44 PM
How much oil to I need to purchase to change my WRX tranny and diff oil? kenshiro Transmission (AT/MT) & Driveline 6 03-13-2003 05:51 PM
How much $$ to fill nos bottle? nathan power Technical Forum Archive 4 10-06-2000 07:13 PM
