Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-07-2007, 12:29 AM   #1
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Question Anyone see a 2.5 shortblock with 2.0 heads and TD04 or similar?
I'm curious about the effects of changing a mostly stock 2.0L wrx setup to a 2.5L shortblock, while retaining the stock sized turbo...
I have to build a motor soon and I don't plan on building for a lot of power (100k on this 5mt, don't wanna bust it yet...)...and I have an STi swapped GC already...no need for two...yet.
I'm currently N/A and wanna keep the swap on the cheap side, as I'm saving for a house.
I really only care about low end torque.
I was thinking big block, small turbo.
Thoughts?
-- Dave
AcquaCow is offline   Reply With Quote
Old 02-07-2007, 12:34 AM   #2
thejean
Member#: 17763
Talk to PeteDucati.
thejean is offline   Reply With Quote
Old 02-07-2007, 01:23 AM   #3
keaniegenie
Member#: 94494
2005 Element 92x
I had a full EJ257 longblock with a td04. Super responsive, no top-end. My top-end was actually not bad with all things considering, but I did have an equal length header and an EWG. IWG td04 plus the 2.5l = low boost or = boost creep.
keaniegenie is offline   Reply With Quote
Old 02-07-2007, 02:18 AM   #4
bachan114
Member#: 99321
2012 WRX (WRB)
"BLU BALZ" is coming 4 u!
bump for this...i have been thinking about upgrading my 2.0 wrx with the 2.5 shortblock and would like to hear about some possible routes to go
-Cramer
bachan114 is offline   Reply With Quote
Old 02-07-2007, 02:28 AM   #5
Vahnatai
Member#: 25027
I have a stock turbo (until the 18G goes in). As previously said, super responsive.....no top end. Power drops after about 5,800.
Vahnatai is offline   Reply With Quote
Old 02-07-2007, 02:32 AM   #6
bachan114
Member#: 99321
2012 WRX (WRB)
well..not to hijack the thread acquacow, but do you need a new wireharness when doing the 2.5 shortblock? what acompaning parts are needed?
Old 02-07-2007, 03:48 AM   #7
thejean
Member#: 17763
Hey lads, not to be a total dink but there are quite a few threads on this. Just search around a little and you'll find em. Search for my name as I have posted in most and got in trouble from Unabomber for doing so. lol
Basically, there are 3 options:
1. STI SB (either stock pictons or new forged) with WRX heads
2. STI LB with WRX intake manifold (need Hydra to run the AVCS)
3. Full STI LB swap with DBW throttle and STI wiring harness (BIG PITA)
Old 02-07-2007, 09:28 AM   #8
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
You would get full spool by what like 2000 rpm's. Monster off the line.
JMK508 is offline   Reply With Quote
Old 02-07-2007, 11:19 AM   #9
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
thats my set up right now. the car is insane off the line. ifi auto crossed it would be perfect for it. i hit peak boost 16 psi at 2400 rpm. definitely a fun car in the twisties gets ya out of the corners really quick. but like others said it runs out of breath starting at about 5000 rpm i usually shift right before 6000 rpm. it made a lot better numbers than i though it would on th edyno. 260 whp 304wtq.
jbwrx is offline   Reply With Quote
Old 02-07-2007, 11:27 AM   #10
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
This sounds like exactly what I am looking for.
I'm going to have to replace the wiring anyways, as I'm going from N/A to turbo, so new ECU/etc...
I'll stay tuned for more info.
Thanks!
-- Dave
Old 02-07-2007, 01:53 PM   #11
SplatZ400
Member#: 84377
2011 335d
Thanks!
-- Dave
Dave you are still bench racing!
SplatZ400 is offline   Reply With Quote
Old 02-07-2007, 02:07 PM   #12
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
No, I'm in the process of trying to cheaply replace my EJ25 before it grenades in the coming months.
-- Dave
Old 02-07-2007, 02:08 PM   #13
SplatZ400
Member#: 84377
2011 335d
-- Dave
I know just giving you a hard time. Good luck with the build, there is so much in this area technical wise that i have lost my mind in here trying to figure out what i want to do with my block.
Old 02-07-2007, 03:44 PM   #14
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I just wanna build something that works.
I can always upgrade later.
-- Dave
Old 02-07-2007, 03:56 PM   #15
thejean
Member#: 17763
VF39 will spool almost as good and will give you power all the way to 6000 rpm. That's what I'm going with. JC
Old 02-07-2007, 04:17 PM   #16
thejean
Member#: 17763
Old 02-07-2007, 04:30 PM   #17
Drink
Member#: 102682
... ripper's
sister.
I ran 2.5 w/ TDo4 for about 10k mi. The low end torque is amazing. The car pretty much falls flat after 5500rpm. I really did like the setup though. I ran about 20 psi and can't recall driving a car with the much low end respone. Step on the gas and your at full boost. PM me if I can help at all
Drink is offline   Reply With Quote
Old 02-07-2007, 04:42 PM   #18
keaniegenie
Member#: 94494
2005 Element 92x
I would highly recommend an EWG with this setup.
Old 02-07-2007, 04:45 PM   #19
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
On that note, if you compare the 39 to the 18G, the spoolup is almost identical, with an even better topend. In the i-speed dyno runs, the 18G actually hits a higer peak boost sooner than the VF39.
foxboroxt is offline   Reply With Quote
Old 02-07-2007, 04:45 PM   #20
just_a_wrx
Member#: 133116
04 WRX
Hey Matt, was this w/ IWG or EWG?
just_a_wrx is offline   Reply With Quote
Old 02-07-2007, 05:25 PM   #21
thejean
Member#: 17763
Umm, nope. Look again. You may have been looking at the VF34. The VF39 peaks in the low 3's whereas the 18g peaks in the high 3's (based on the TQ curves, not the HP curves). But look at all the VF39 TQ around 2500 rpm... 260+ ft-lbs as compared to the 18g's 210 at that rpm. 18g is always gonna have top end on a VF39 but for sure the VF39 spools better/earlier and has a better bottm end. And, it doesn't give up that much on the top either. For rallyX and autoX, I'll sacrifice the top end. And on the street, I'll rarely ever use that kind of power.
Old 02-07-2007, 08:00 PM   #22
JMK508
Member#: 115420
Its like a STI.....
Yea i was going to say.... hell if you thinking about a 18G you have gone to big and now you should just throw a 20g or bigger.
Old 02-07-2007, 08:05 PM   #23
dibblejr
Member#: 94070
05 LGT
This "Hybrid" swap is made all the time. I would recommend a larger turbo, your OEM turbo wont last very long, unless you set boost limits low... then whats the point of the swap.
Jay-R
dibblejr is offline   Reply With Quote
Old 02-07-2007, 08:22 PM   #24
Drink
Member#: 102682
... ripper's
sister.
IWG. Tuning it was kinda a pain. It took me and a friend a few weeks to get eveything situated. The IWG seemed like it was having a hard time staying shut in the upper RPMs.
Old 02-07-2007, 10:09 PM   #25
poormansporsche
Member#: 79798
I dunno if this will be good on your 2.5RS tranny tho. Thats a lot of tq. Mostly why all the 2.5RS-T folk blow their trannies IIRC. Just has crazy tq that just get poured on immediately. With the 4.11 gears tho it will be a force to be reckoned with.
cheers
garrett
poormansporsche is offline   Reply With Quote
doing the 2.5 shortblock w/ 2.0 heads n8t_dog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-03-2008 09:37 PM
Clearance and moving sale: forged 2.5 shortblocks, forged 2.0 shortblocks, and more Gruppe-S Engine/Power/Exhaust 14 06-20-2007 06:23 AM
2.5 sb with 2.0 heads Redscoob Subaru Conversions 2 05-21-2007 12:52 AM
2.5 shortblock with wrx heads deadlystealthwrx Subaru Conversions 6 02-02-2006 10:13 PM
2.5 shortblock w/ 2.0 head?'s AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-22-2002 07:01 PM
