Old 01-22-2007, 04:49 PM   #1
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
Default Let's talk about Tokico D-Specs and wagons
So I know that there are a couple of people here running Tokico's on their wagons, but other than Orson, there seems to be little to no feedback on setups and reviews.
I'm interested in hearing from wagon owners who are running these and what lengths they've gone to to get some decent camber numbers. Plates? Bolts? How are they working for you? What springs are you running and how are you setup?
Discuss.
MT
MT_WRX is offline   Reply With Quote
Old 01-22-2007, 10:55 PM   #2
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
I'm interested too.
Wagon owners with Tokico's, please discuss.
Mind is offline   Reply With Quote
Old 01-22-2007, 11:47 PM   #3
Blown95ImpalaSS
Member#: 87629
I want to know too, I'm gonna need something when my tein wagons take a poop on me.
Blown95ImpalaSS is offline   Reply With Quote
Old 01-23-2007, 02:09 PM   #4
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
bump
MT
Old 01-28-2007, 07:14 AM   #5
Hoppie
Member#: 86150
'13 WRX Hatch
Schwarz
Anyone? I'm very interested too. Subiesport put D-Specs with Prodrives on their project wagon, I'm really curious what they did to solve the camber issue and which year springs they put on.
Hoppie is offline   Reply With Quote
Old 01-28-2007, 11:41 PM   #6
Mr Kleen
Member#: 58991
I'm not a wagon owner, but I'm very interested in any feedback on the Tokico D-Spec (especially anyone using the strut/spring package).
Mr Kleen is offline   Reply With Quote
Old 01-28-2007, 11:48 PM   #7
deviant94ex
Member#: 55548
05 Saab 92X Aero
This post: http://forums.nasioc.com/forums/show....php?t=1046120 has a ton of info on what springs to use with the d-specs. In particular, there is a lot of discussion on the "kit."
Like a few others in this thread, I am more interested in the camber issues that come from using the d-specs on a wagon and what others have done to get good camber numbers (and what are those numbers?). I want to pair these up with a set of USDM Sti wagon pink springs. I would like to maintain the ride quality of the wagon pink springs so I am not sure if I would want to run something like the RCE camber plates up front (anyone with first-hand opinions?). I'm pretty sure that camber bolts will solve any issues in the rear, but I am not sure about the front.
Thanks.
Chris
deviant94ex is offline   Reply With Quote
Old 01-29-2007, 12:00 AM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
You guys can find most of this info on any thread having to do with using sedan struts on a wagon. Using plates or a second set of camber bolts up front and camber bolts in the rear will bring you easily into decent camber ranges. Folks with plates are getting around -2.5 to -3 with plates, depending on the plates. Bolts will net you around -2 to -2.5 roughly. Personally, I'd go with plates as it easier to get your alignment done that way. Few places know how to work with aftermarket camber bolts much less 2 sets!
Obviously the bigger issue is that these struts are 02/03 compatible, meaning you have to do the washer mod to the rear if you are planning to run 04+ springs like the STi wagon pinks. TIC carries the best washer mod for this situation.
As to how the various springs are working with the DSpecs, simply read the above thread.
Arnie is offline   Reply With Quote
Old 02-03-2007, 09:23 PM   #9
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I'm interested in hearing this info too..
So I was informed that Konis, as wonderful as they are for paved applications, are not good for off road, like rallyx. Something about the housing being small (since it's an insert) which is not good for rallyx stuff... I'm guessing heat from all the bouncing.
But I want something with good digressive curves, adjustability, and works with sti wagon pinks (or even stockers for when my stock struts wear out)
chimchimm5 is offline   Reply With Quote
Old 02-04-2007, 11:14 AM   #10
MPREZYA
SCIC
Member#: 85
There were no negative camber issues using the D-specs on the wagon with either the Prodrive or Swift springs. Both sets of springs were for the 04+ .
Driving impressions of the car have been nothing but fantastic from everyone who's driven it. I've even been told not to go to coilovers due to how well it performs without sacraficing comfort.
Expect a full breakdown here soon of everything including driving impressions in the testing coming up soon.
MPREZYA is offline   Reply With Quote
Old 02-04-2007, 01:34 PM   #11
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
What do you mean by "no negative camber issues"? Are you saying that you could get camber into factory spec range or that you could achieve as much negative camber as with stock wagon struts?
Old 02-04-2007, 01:50 PM   #12
I am firmly convinced that the d-specs are a very solid product and the only gripe I've had is that I need a bit stiffer spring set than I have been using---which I now have thanks to Myles and I will be installing some new Whiteline front tops with the springs thanks to Arnie to cover THAT area of my suspension.
Old 02-04-2007, 05:33 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Ok so I'm reading Tokico Dspecs like stiff springs; fine... what about the full soft setting? How is it relative to the stock WRX or STi struts.
Old 02-05-2007, 07:38 AM   #14
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
yes, full soft, they're like stock... as far as i can remember. (it's been a few years since i've been on stock suspension.) but, i think they were designed to be as soft, if not softer than stock at their softest setting.
Old 02-09-2007, 12:15 PM   #15
deviant94ex
Member#: 55548
05 Saab 92X Aero
Ok, I apologize if I am asking for information that has already been disseminated in other areas, but I figure that this thread is easy to search for and other wagon owners will want to know the same info....so here goes:
1. In regards to the stock setup, it appears that there are no camber bolts in the rear, and one set already in the front? If so, adding a set to the rear will let you get well within specs, and either adding a second set to the front or using RCE plates (or other similar products) will out you well within specs on the front. Are my assumptions here correct?
2. If using RCE plates on the front, what effect do they have on ride quality?
3. MPREZYA, what were your alignment readings since you say that you had no camber issues using the sedan d-specs on your wagon?
Thanks.
Chris
Old 02-09-2007, 02:10 PM   #16
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I'd still like to know the answer to this too.
Old 02-09-2007, 02:33 PM   #17
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
Glad this thread is starting to pickup! Even though I currently have a brand new set of GR-2's waiting to match up with my SPT Pinks.
Hopefully we can get some continued feedback and clarification, because I STILL think that I may end up with the Tokicos at some point. The suspension swap sickness is starting...
MT
Old 02-09-2007, 03:34 PM   #18
uathatis
Member#: 117300
MT
No ****? tell me how that GR-2 plus spacers and spt pinks works man.
lucky you and your jdm hookups
When your talking tokicos aren't they like 600$ vs gr-2s which are 400....
hopefully the gr-2's will match fine for your DD/collegstudentbudget
uathatis is offline   Reply With Quote
Old 02-09-2007, 04:09 PM   #19
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
I will. I still think that this setup is going to be pretty nice. I'm probably going to sacrifice some stiffness, but we'll see. There aren't too many here who are running this setup, but the ones who are have good feedback.
Steppin' down from teh JDM goodness. But I'm gonna hold onto that setup until the verdict comes down!
No college for me man!! The only homework I do these days involves lots of reading here...
MT
Old 02-09-2007, 04:13 PM   #20
rdy4flt
Member#: 86882
2005 92x Aero-stg2
Arctic Silver
I'm running Tokico Dspecs with Espelir ASD springs. To compensate for the neg rear camber I got poltec adj lateral links. For the rear suspension I also have perrin adj rear sway bar with end links and a rear strut tower bar. I love how the car handles, very balanced. In order to go with my Sti wheels I rolled my fenders.
Rudi
rdy4flt is offline   Reply With Quote
Old 02-10-2007, 12:45 AM   #21
...the d-specs can be had for $525 shipped
Old 02-10-2007, 07:10 PM   #22
uathatis
Member#: 117300
o rly? then thats a pretty nice deal..... especially if the fitment is just fine for both sedan and wagon...
125 more for adjustability is not bad... doesn't that make them around same price as sedan gr-2/agx's as well.
pm me who sells them for that much if you would please
Old 02-10-2007, 07:56 PM   #23
b_powerfade
Member#: 76118
2013 WRX Hatchback
Plasma Blue Pearl
http://www.cvrmotorsports.com/view_p...product=DSP-10
b_powerfade is offline   Reply With Quote
Old 02-10-2007, 09:02 PM   #24
rdy4flt
Member#: 86882
2005 92x Aero-stg2
Arctic Silver
Originally Posted by b_powerfade View Post
That's were I got my Tokico Dspecs as well as my TBE, Brakes, strut tower bar. They have great prices.
Old 02-24-2007, 06:23 PM   #25
MPREZYA
SCIC
Member#: 85
Thanks.
Chris
Sorry for the late response I've been super busy lately and not around a computer much.
My alignment readings are -1deg front and -1.8deg and 3/32nd toe in for the rear, is what it is currently sitting at with what is on the car now. I plan on upping the camber more to -1.75 to -2deg front and -2.5deg rear with the same toe setting. I will update when I have that done if there are any issues.
When I had the prodrive and d-specs alone it was -1deg front and -1.25deg rear same toe setting.
Tokico D-Specs and Swift Wagon Springs MXracer52 Suspension/Brakes/Handling 15 11-14-2009 01:40 PM
Let's talk about clutches and flywheels... ('02 WRX) Jard Mid Atlantic Impreza Club -- MAIC 25 08-04-2006 02:34 PM
Let's talk about sluts and lapdances benjaminetanyahoo Off-Topic 47 08-03-2006 07:48 PM
Let's talk about when to change out the rods. Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 10 03-04-2002 12:44 PM
Let's talk about the Rimmer Supercharger rao General Forum Archive 88 09-21-2000 08:56 AM
