Old 02-16-2007, 06:08 PM   #1
Donzo
Member#: 95337
2012 Jeep Overland
Default Compilation of painted wheels
UPDATE: Due to the popularity of this thread, it is now open to ALL repainted wheels. (Not just stock wheels)
Instead of searching for which colors look best on which wheels/vehicles, this thread should be a compilation of pictures for ALL wheels that are repainted.
Make sure to give a brief description including what wheels they are, and more importantly, what primer, paint, and clear coat. Please, post the brand and color of the paint since most of these threads all ask "what paint did you use" over and over again in the same thread.
Feel free to post multiple pictures, also including one or more picture/s of the wheels mounted on the vehicle since the year, model, and vehicle color will be an important factor in deciding which looks best.
I will start by posting my wheels in the second post. I hope this thread helps clear up a lot of clutter and helps those deciding on what colors look best.
Donzo is offline   Reply With Quote
Old 02-16-2007, 06:26 PM   #2
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Default Graphite painted WRX stock OEM wheels on a sonic yellow wagon and how-to
1. Remove the center caps
2. Remove any wheel weights you have
3. Clean and degrease everything thoroughly
4. Sand the inside with 200 grit paper
5. Then sand the painted side with 350 grit paper
6. Wipe with a tack cloth
7. Plug the bolt patter (lug holes) with newspaper
8. Mask the tires and valve-stems
9. Primed the inside with 2 coats of self etching primer
10. Primed everything with primer/filler
11. Sand everything with 350 grit paper again
12. Wipe with a tack cloth again
13. Spray on 2 coats of Duplicolor Graphite Wheel Paint
14. Sand with 800 grit paper
15. Spray on 2 more coats of Duplicolor Graphite
16. Spray on 3 coats of Duplicolor High-performance clear coat
17. Let them dry for 24-48 hours before handling
18. Head on over to the tire shop and have them rebalancing
19. Make sure they install the new weights on the inside
20. Go and show off your new wheels to your friends
Last edited by chrisarella; 02-16-2007 at 11:40 PM. Reason: added how-to and picture
chrisarella is offline   Reply With Quote
Old 02-16-2007, 06:50 PM   #3
Donzo
Member#: 95337
2012 Jeep Overland
Due to some curb rash and not wanting to pay to have my stock wheels fixed, I decided to fix/repaint them myself. Since this isn't a thread about the process itself, I won't go into detail. You can search for that in all 42380946 threads about how to do it. This is for picture reference only.
These are my stock 2006 WRX wheels.
-Repainted with Wurth Silver Lacquer.
-Primed with regular primer I had laying around but didn't like it so I bought a can of scratch filler primer which is much thicker and came out great.
-I also used Wurth clear coat which I wasn't too crazy about because it wasn't shiny so I later bought a high gloss clear coat and it came out great. I chose Wurth silver lacquer because it's the closest you will get to the stock color. It will work on many wheels.
This wasn't my last coat of paint but you can see where I had the wheel taped off (around each spoke and around the inner portion of the rim) and how close the paint matches. Once I clear coated it, it was pretty much a perfect match.
Old 02-16-2007, 06:59 PM   #4
Donzo
Member#: 95337
2012 Jeep Overland
This is how they look on a silver 2002 WRX:
And this is how they look on a black 2006 WRX:
Old 02-16-2007, 07:13 PM   #5
Donzo
Member#: 95337
2012 Jeep Overland
Next up, I painted a set of OZ Racing/Prodrive wheels due to some curb rash. They're a factory upgrade option so I will count these as stock. lol
Once again, I used Wurth silver lacquer, scratch filler primer, and high gloss clear coat.
This is how it looks on a black 2006 WRX:
And this is how it looks on a silver 2002 WRX.
Old 02-16-2007, 10:53 PM   #6
jojotherider
Member#: 70730
2006 WRX ltd AW
02 WRX, 00RS - sold :(
Sanded
Primer (1 coat): Rustoleum Clean Metal Primer
Paint (4 coats): Duplicolor Gold
clear (2 coats): Duplicolor High Performance Wheel Coating
The products
Link to my original thread for some in process pics:
http://forums.nasioc.com/forums/show...php?p=17083392
Yes i painted over the wheel weights. These are my winter wheels. Though, there's a good chance I'll do this with the summer wheels.
-joel
jojotherider is offline   Reply With Quote
Old 02-16-2007, 11:32 PM   #7
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
I painted my wheels with Duplicolor graphite....
first i sanded down the old paint, then i used simple green and clean the wheels, i then spray 3 coats of paint and then 3 coats of duplicolor clear coat....i wish i would have used more clear coat, but its ok, im getting new tires put on tomorrow so i will be repainting them again shortly, i think i will redo them every 6 months or so just to keep them chip free..tell me what you think...any questions, just pm me
blowbyu24 is offline   Reply With Quote
Old 02-16-2007, 11:36 PM   #8
jojotherider
Member#: 70730
2006 WRX ltd AW
looks like you did a good job.
Old 02-16-2007, 11:38 PM   #9
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I updated the second post with my process and a picture.
Old 02-17-2007, 12:27 AM   #10
Donzo
Member#: 95337
2012 Jeep Overland
Thanks guys! Once again, it's not really necessary to list the process since it's always the same process. Atleast now no one will ask HOW you all did it. Lets try to get all the stock wheel pics in this thread so that we have everything in one place. I'm even contemplating just posting pics of other member's wheels since half of them will probably be too lazy!
Old 02-17-2007, 12:34 AM   #11
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
^^^ well aren't you just miss picky....haha jk
Old 02-17-2007, 12:35 AM   #12
jojotherider
Member#: 70730
2006 WRX ltd AW
I think you should open it up to all wheels instead of just stock. lol, you posted non stock wheels. I think its just good to see paint in different light.
I do think its very important to include the product(s) used, though.
-joel
Old 02-17-2007, 10:34 AM   #13
Donzo
Member#: 95337
2012 Jeep Overland
Well, those wheels were a factory option. That silver bugeye has all of the factory options (skirts, lip, etc) so technically the exterior is still stock, including the wheels.
If we get enough people posting in this thread, posting any painted wheels would be a good idea.
I wanted to make this thread because a lot of people love their stock wheels but just want to change the color and can't decide on which color to go with. Thanks for the pics and the input guys. Keep them coming!
Old 02-17-2007, 12:19 PM   #14
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
I cheated, I bought them painted. Though I still don't know why someone painted 04 goldies.
DiscoGsus is offline   Reply With Quote
Old 02-17-2007, 12:39 PM   #15
Donzo
Member#: 95337
2012 Jeep Overland
^^ The wheels look great. However, do you know what brand or color paint was used on those?
Old 02-17-2007, 11:27 PM   #16
tac04wrx
Member#: 120791
2014 xv
dk
i used duplicolor paint but i forget what the exact name is...something blue and i used the duplicolor wheel clear coat.
tac04wrx is offline   Reply With Quote
Old 02-18-2007, 12:32 AM   #17
Donzo
Member#: 95337
2012 Jeep Overland
Now THAT'S original. Good job!
Old 02-18-2007, 12:43 AM   #18
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
1. cleaned rims
2. sanded rims
3. cleaned rims again
4. masked rims
5. painted rims with green hi temp (engine) paint. put 4 coats on them
6. let them dry.
7. enjoy
PARANOID56 is online now   Reply With Quote
Old 02-18-2007, 02:09 AM   #19
jdmmuscle
Member#: 81326
06 IMPREZA WRX STI
Real man Krew #24!
^ Looks good...
jdmmuscle is offline   Reply With Quote
Old 02-18-2007, 02:23 AM   #20
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
express_wagon is offline   Reply With Quote
Old 02-18-2007, 10:34 AM   #21
tac04wrx
Member#: 120791
2014 xv
dk
ha thanks.
btw luv the green & white.
Old 02-18-2007, 10:39 AM   #22
Donzo
Member#: 95337
2012 Jeep Overland
express wagon... what brand/color paint did you use?
Paranoid, that color combo looks awesome! That definitely took some nuts to paint them green but they came out great!
Old 02-18-2007, 06:03 PM   #23
randolph-rs
Member#: 3371
2004 Forester XT
Java Black
I know its a Forester but I painted my wheels also. They are the stock Forester XT wheels.
I used Rust-oleum Metallics night black. This paint is black with a highly reflective metallic finish. I used no clearcoat on them and they are doing well with no chips. I followed the basic procedure of scouring with course scotchbrite pads. Then I cleaned each wheel with degreaser and allowed them to dry. I did not mask the tires because they were covered with multiple layers of tire dressing which kept the paint from sticking to the tire.
randolph-rs is offline   Reply With Quote
Old 02-18-2007, 11:51 PM   #24
Donzo
Member#: 95337
2012 Jeep Overland
That's probably one of the sickest looking Foresters I've seen!
Old 02-19-2007, 08:48 AM   #25
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
I am pretty sure it's generic green Rustoleum from Home Depot. Don't remember so well since it's been almost two years.
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 08:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 07:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 12:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 02:35 PM
