Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 02-18-2007, 03:36 PM   #1
Aspen_2.5RS
Member Sales Rating: (473)
Member#: 3310
Updated: 3/9/09 This is the most current post that says what is and isn't available, READ it. If you pm me asking me for something that has already been sold, then you obviously didn't bother checking the list and I'm going to delete your pm.
This is a complete part out of an 02 wrx that was wrecked in the front, so there are TONS and TONS of OEM parts. Please read this before asking what I have. Pics are below (note that since these pics were taken the rear doors have been traded for dented ones). The car has 104,222 miles on it.
Also, if you're thinking about buying oem parts from someone else, check my feedback and rest easy knowing you'll get what you paid for. This is wrecked wrx part out #3.
As of right now currently these parts are:
Unavailable or Damaged:
Edit: 9/16 The shell was sold as a roller and the following parts were left on the car and are unavailable (of course): hubs, springs/struts/tophats, front sway bar w/endlinks, front and rear xmembers, steering rack, rear lateral links, rear trailing arms, gas tank, all 4 doors, and trunk
steering wheel (went with car shell)
trunk carpet/liner (pending)
jack handle and tranny support bolts (pending) Shane
wrx wheels (did not come with stockers)
inlet tube (messed it up)
wrx trunk board that covers spare (little warped/damaged)
wrx power steering reservoir (damaged)
wrx radiator (damaged)
wrx a/c condensor (damaged)
wrx front bumper (damaged)
wrx grill (damaged)
wrx hood (damaged)
wrx driver and passenger side fenders (damaged)
wrx headlights (damaged)
wrx abs unit (damaged)
lower portion of airbox (damaged)
rear bumper (damaged)
hoodscoop (damaged, let the owner keep it as a momento)
What is SOLD already
hks bov - SOLD - Kevin
wrx clutch master cylinder SOLD- Kevin
wrx clutch slave and line SOLD - Kevin
wrx pedal box assembly SOLD - Kevin
wrx complete dash setup (trim/cluster/fan box/heater core box, hvac controls, trim around shifter, center console, shift boot, everything but the passenger side airbag) SOLD - Kevin
wrx 3 gauge pod from center of dash SOLD - Kevin
wrx wrb side mirrors SOLD - Trey
wrx rear doors (traded for dented doors)SOLD - Trey
wrx left rear exhaust bracket with bolts )SOLD - Michael
wrx under seat subwoofer w/harness SOLD - Pablo
wrx auto dimming mirror SOLD - Pablo
under hood clips/door sill clip/rubber wiper bolt cover - SOLD - Christian
wrx 6 disc radio SOLD - David
wrx 3rd brake light SOLD - Trey
wrx taillights SOLD - Andy
wrx a/c compressor SOLD - Charles
wrx front 02 sensor SOLD - Charles
wrx rear 02 sensor SOLD - Aphex
wrx front calipers w/brackets/rotors/pads SOLD - CJ
wrx iacv (idle air control valve) SOLD - Chris
wrx maf SOLD - Adam
wrx ecu & fuse box cover pocket SOLD - Julian
exhaust manifolds SOLD - David
left trunk liner SOLD - Ben
fog light switch SOLD - Alex
passenger front window SOLD - Ben
metal trim around shifter SOLD - Philip
fuel injectors SOLD - Eric
bulkhead/front harness w/ fp controller & rear harness SOLD - Tim
wrx starter and 4 coil packs SOLD - Tim
front left axle and alternator SOLD - Nathan
rear diff SOLD - Disraili
wrx sideskirts SOLD - Trey
stock bpv SOLD - Charles
2 firewall plugs behind intercooler, covers for rear seatbelts, trunk light SOLD - Justin
anchor bolt for seatbelt on B pillar SOLD- Gary
rear axles and one front axle SOLD- Sam
wrx heads w/cams/valves/cam gears SOLD- Matt
engine harness & intake manifold SOLD- Matt
tgv sensors SOLD- Matt
tgv housings & tps (throtte position sensor) SOLD- Matt
engine sensors minus throttle body sensors & coil packs SOLD- Matt
coolant crossover pipe SOLD- Matt
busted mainshaft wrx trans SOLD- Matt
stock scissor jack SOLD- Greg
fog lights SOLD- Justin
heatshield/top bracket/egt sensor SOLD- Nathan
rubber door stoppers SOLD- Rasmus
stock clock w/surround SOLD- Eric
Intercooler brackets w/ bolts SOLD- Eric
wrx power steering lines SOLD- Calvin
power steering pump SOLD- Douglas
timing belt tensioner/idler wheels SOLD- Brian
windshield washer reservoir with motor SOLD- Brian
defi gauges SOLD- Jerry
stock td04 turbo w/coolant and oil lines SOLD- Daniel
passenger side airbag w/cover and passenger front seatbelt SOLD- Ching
Ricer rims SOLD- Tim
A/c line from firewall to compressor (L) SOLD- Evan
factory bcs (boost control solenoid) SOLD- Eduardo
transmission SOLD- Paul
a/c bracketry w/pulley SOLD- Damon
driver rear window switch SOLD- Patrick
coolant reservoir (metal tank) SOLD- Ben
thermostat housing w/bolts SOLD- Dan
driver front window motor SOLD- David
wrx sunvisors SOLD- Shawn
intercooler SOLD- Gabe
top and bottom steering column trim pieces, e-brake cables, e-brake hardware, front door lock actuators SOLD- Stephan
uppipe SOLD- Cory
intake hose from airbox to inlet pipe SOLD- AJ
throttle body (no tps or iac) SOLD- Josh
wiper motor SOLD- Matt
rear 20mm stock sway bar with mountsSOLD- Norm
The shell was sold as a roller, so the following parts went with it: hubs/13" steel wheels/xmembers/steering rack/springs/struts/springs/control arms/lateral links/4 doors/gas tank/trunk w/wing SOLD- Robby
rear calipers with brackets SOLD- Benny
Catalytic section after the dp SOLD - David
front and rear seats SOLD - CJ
wiper stalk assembly SOLD - Ken
damaged driver side airbag SOLD - Wing
wrx shortblock w/ 104k SOLD - Andrew
water pump SOLD - Andrew
brake master cylinder SOLD - Omar
magnaflow muffler on stock axleback SOLD - Justin
driver side sidemarker SOLD - Andrey
egt sensor SOLD - Kevin
front driver side abs sensor SOLD - Philip
motor mounts from psm wrx SOLD - Shaun
dome light SOLD - Abel
glove box wiring/switch/bulb SOLD - Abel
trunk/gas tank release assembly minus cables SOLD - Jacob
"map sensor" - pressure sensor on throttle body SOLD - Andrew
Downpipe - SOLD - Tyler
a/c line from condensor to compressor (H side) - SOLD - Jeff
alternator belt cover - SOLD - Patrick
4 interior door panels (still have 2 others) - SOLD - Russ
tool bag, intercooler splitter, & a-pillar trim for driver's side (still have another splitter) - SOLD - Marc
helix cel fix - SOLD - BJ
passenger rear window switch - SOLD - John
headlight/turn signal switch stalk - SOLD - Robert
mirror switch (I have another one) w/connector/wiring - SOLD Daniel
3 wire vehicle speed sensor harness - SOLD - Jan Christian
A/C bracket - SOLD Drew
driver side rear abs sensor (have more) - SOLD -Daniel
overflow coolant reservoir - SOLD -Daniel
carpet for sedan SOLD (2 more left) devarian
floormats SOLDdevarian
dead pedal SOLD (2 more left) devarian
driver side front window SOLD (at least 1 left) devarian
trunk/gas relase handles SOLD devarian
mesh bugeye fog covers SOLD devarian
driver side front door card SOLD Seth
green test mode connectors from leftover chopped up harness SOLD
wrx transmission xmember/brace SOLD Joshua
Impreza L shifter and knob SOLD Andrew
wrx coolant overflow tank SOLD Andrew
wrx throttle cable SOLD Jesse
driver side radiator fan assembly w/shroud SOLD James
gauge cluster bezel surround SOLD Stephen
1 carpet and 1 passenger rear interior door panel SOLD to myself
wrx oem intercooler splitter w/hardware - SOLD Josh
power steering pump bracket - SOLD Trey
What is AVAILABLE Not a complete list by any means, ask me if it's not pending or damaged
wrx engine shortblock parts - 3 pistons/rods
wrx fuel pump
front end links (off another car I parted)
rear end link (only 1)
cruise control unit (2)
a/c line from firewall to strut tower and strut tower to condensor
throttle body to intercooler coupler
wrx brake booster (booster only)
wrx manual driveshaft
gas caps (2)
valve covers
cowl trim (2) (covers the windshield wiper arms/motor)
e-brake handle (2)
glovebox light/switch w/wiring (1)
wrx middle sunvisor (3)
power mirror switch/controls (1 or 2 left)
wiring harnesses for the doors (have all 4)
cruise button (2)
wrx map lights (1)
wrx dome light (1)
wrx ecu cover/kickplate (3)
psm fuel door
pretty much all interior trim is available that isn't related to the dash, a pillar trim for the passenger side, b-pillar trim, section below b-pillar trim, c-pillar, door card trim, and door sill trim
driver and passenger side rear seatbelts
front driver side seatbelt
windshield wiper arms/motor (from a previous car)
all power window/lock switches and motors (all of the single window switches have been sold, I do still have the main driver switchblock )
miscellaneous screws/clips/bolts
all door glass minus the passenger front
rear deck cover (2)
antenna assembly (2)
exhaust manifold heatshield for driver's side (minus the crossover pipe)
spare wheel/tire (1 of these - black steel with mini-tire)
some e-brake components - shoes/springs/clips/etc
Impreza L/RS rubber clutch pedal cover - new in bag - 36015GA111
Impreza clutch pedal assembly for hydraulic clutch - new
95 Impreza L power steering lines
95 Impreza L rear axle (only one, the other has messed up threads)
95 Impreza L radiator fans/shrouds
95 Impreza L throttle cable
95 Impreza L fuel pump
Again, do not ask me for components that I have specifically said are not available right now, I'll call you a noob . If it's not in the list and you have a question about it, feel free to ask. If it is in the list and I've said it's not available, don't expect me to pm you back, b/c you've failed to read (wastes my time and yours).
Last edited by Aspen_2.5RS; 02-20-2011 at 01:43 PM. Reason: updated parts list 9/12/09
Aspen_2.5RS is offline   Reply With Quote
Old 02-18-2007, 05:03 PM   #2
dingobite
Member Sales Rating: (28)
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
You still have the ecu i wanna get a buddy to look at this if you do.
dingobite is offline   Reply With Quote
Old 02-18-2007, 05:07 PM   #3
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
how much shipped for trunk wooden tray cover and liner (trunk carpet) to 12601?
txl146 is offline   Reply With Quote
Old 02-18-2007, 05:15 PM   #4
Aspen_2.5RS
Member#: 3310
Edit: ecu is now sold
txl146, The wooden cover is kinda warped, not sure you'd want it. The trunk carpet is pending, I'm sorry I gotta add that to the list.
Cam
engine was SOLD
Trunk is gone.
Old 02-18-2007, 05:31 PM   #5
on3letsgo
Member Sales Rating: (1)
Member#: 28400
2002 WRB WRX Wagon
do you have an armrest extension & lower black B-pillar trim piece?
how much for the radio?
on3letsgo is offline   Reply With Quote
Old 02-18-2007, 05:35 PM   #6
Aspen_2.5RS
Member#: 3310
I don't have an armrest extension. I do have a lower black B-pillar trim piece.
Edit: radio was sold
Cam
brake booster (master cylinder SOLD), High pressure a/c line SOLD, windshield wiper motor/assembly
cruise control unit (3)
coolant tank SOLD
uppipe SOLD and egt sensor SOLD
Old 02-18-2007, 06:19 PM   #7
MyRad25rs
Member Sales Rating: (34)
Member#: 86191
2000 brp GC
...and still adding to it
Thanks for the PM.
I'm looking for the plastic trim that covers the bolts that hold the seats down to the floor. Any luck finding it?
MyRad25rs is offline   Reply With Quote
Old 02-18-2007, 06:31 PM   #8
Aspen_2.5RS
Member#: 3310
Those covers are going to go with the seats more than likely. They are pending right now. I should know in about a week whether or not they are sold for sure.
Shortblock SOLD
Cam
Last edited by Aspen_2.5RS; 12-08-2007 at 11:48 PM. Reason: added a pic of the engine with sold parts removed
Old 02-18-2007, 06:35 PM   #9
cbarth3
Member Sales Rating: (6)
Member#: 67249
2004 WRX
do you have the stock bcs and harness ?
cbarth3 is offline   Reply With Quote
Old 02-18-2007, 06:38 PM   #10
MyRad25rs
Member#: 86191
2000 brp GC
Cam
Thanks for the head's up, Cam! LMK either way. Good luck!
Old 02-18-2007, 06:39 PM   #11
$lick_Rick
Member#: 120454
02 wrx
wrb
got any pics of the wrx auto dimming mirror?
$lick_Rick is offline   Reply With Quote
Old 02-18-2007, 06:49 PM   #12
Aspen_2.5RS
Member#: 3310
Ugh, why won't the first link use the img tags correctly?
Mirror needs to be cleaned off, but nothing wrong with it. SOLD!
SOLD!
Old 02-18-2007, 06:54 PM   #13
Aspen_2.5RS
Member#: 3310
That will go with the engine if it's sold. Like I said, I will know for sure on the 25th.
Foglights SOLD
Cam
Last edited by Aspen_2.5RS; 12-08-2007 at 11:49 PM. Reason: added a pic of the foglights
Old 02-18-2007, 07:55 PM   #14
seanh287
Member Sales Rating: (3)
Member#: 113811
2003 WRX
bump...
cam,
i dont need anything at the time, thanks for keeping me in mind though.
seanh287 is offline   Reply With Quote
Old 02-18-2007, 10:05 PM   #15
Silver_04_WRX_SC
Member Sales Rating: (27)
Member#: 67198
2012 Audi S5 Cabi
Grey
pm'd about the defi gauges!
Silver_04_WRX_SC is offline   Reply With Quote
Old 02-18-2007, 10:19 PM   #16
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
Please PM a price for the driver side fog light lens. Thanks.
-Bryce
Carnot is offline   Reply With Quote
Old 02-18-2007, 10:31 PM   #17
Aspen_2.5RS
Member#: 3310
Bryce,
I want to sell the fogs as a set.
Cam
Old 02-18-2007, 10:33 PM   #18
quadtard
Member Sales Rating: (62)
Member#: 104206
2004 WRX
Tunnel Ram Gray
hey Cam, you still got the plastic Boost control solenoid cover and the two clips? or just the two clips? if so, i can paypal you and include that with my coolant hose you're sending. pm me back. thanks
quadtard is offline   Reply With Quote
Old 02-18-2007, 10:34 PM   #19
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
oh!, and the bypass valve return hose, how bout that?
Old 02-18-2007, 10:36 PM   #20
Aspen_2.5RS
Member#: 3310
I have the cover for the boost solenoid, but not the clips. The bpv return hose isn't available right now b/c I may be selling the engine complete.
Cam
Old 02-18-2007, 10:55 PM   #21
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
no clips... ah! nm. i'll find some. lemme know whenever you find out about the bpv return hose, thanks.
Old 02-18-2007, 11:11 PM   #22
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
how about power steering pump? i'm full of ??s, aint i?
Old 02-18-2007, 11:13 PM   #23
Aspen_2.5RS
Member#: 3310
Power steering pump stays with the engine at this time. Anything that is bolted to the engine I can't sell at the moment.
Cam
Old 02-18-2007, 11:14 PM   #24
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
i guess you don't have it from the other part out?
Old 02-18-2007, 11:19 PM   #25
Aspen_2.5RS
Member#: 3310
Nope, sorry, I sold it off the other car a long time ago.
Like I said, I'll know whether or not I can sell engine related stuff on the 25th (the night of the 25th).
Cam
TW: is there any interest for a part out of my 02 WRX 04 Slo Sti MWSOC Private Classifieds 27 03-21-2010 04:41 PM
some parts out of my 02 wrx Johnnypoofies Private 'For Sale' Classifieds 3 07-22-2006 01:17 PM
gauging the interest in a part out of my 02 WRX! wrk king New England Impreza Club Forum -- NESIC 13 04-06-2004 09:32 AM
Begining the parting out of my 02 WRX! wrk king Private 'For Sale' Classifieds 11 01-08-2004 09:12 PM
