Old 08-23-2006, 10:01 PM   #26
RP31
Member#: 123574
2005 stuck-in-garage
CGM STi
What EM are you using? Cobb? I'd say pull off the coilpacks.
RP31 is offline   Reply With Quote
Old 08-23-2006, 11:13 PM   #27
tankerWRX
Member#: 102053
2007 LGT (Sold)
Originally Posted by diamondsplitter
I will be swapping in a Vf39 this weekend. I would like to know, what is the EASIEST way to keep the car from starting so I can prime the turbo?
Pull the fuse for the ignition, crank the car for about 5-10 seconds at least 3-5 times.
tankerWRX is offline   Reply With Quote
Old 08-24-2006, 01:34 AM   #28
compressor_guy
Member#: 75772
02 WRX
Originally Posted by tankerWRX
Funny thing is that car will be in Cincy soon. No really. I deploy to Iraq this fall and my parents will be holding it for me.
Yup, it was an inside joke. I'll be helping your dad install an exhaust on his rex soon. - J
compressor_guy is offline   Reply With Quote
Old 08-24-2006, 09:36 AM   #29
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Good tip! I gotta remember that one...
ScoobyNubieToo! is offline   Reply With Quote
Old 08-24-2006, 12:13 PM   #30
diamondsplitter
Member#: 102498
2006 WRX Wagon
WR Blue
Yes, I have a Cobb Accessport.
diamondsplitter is offline   Reply With Quote
Old 08-24-2006, 11:55 PM   #31
tankerWRX
Member#: 102053
2007 LGT (Sold)
Aha I was wondering if that was you.
Old 08-25-2006, 02:56 AM   #32
06AspenWhite
Member#: 123501
06 WRX Stage II
awesome!
06AspenWhite is offline   Reply With Quote
Old 08-29-2006, 01:14 PM   #33
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
I installed everything as indicated here - fyi the STi restrictor pill did not need to be drilled. It was already slightly larger than the 0.043" drill bit.
It boost creeps badly - in 3/4/5th gear at about 5k it fuel cuts like a mofo.
Factory boost guage is reading about 18.5 psi.
How the heck can this be fixed?? I've read - -use cat, port wastgate, tune it out. Does anyone really know?
I hate to ty 4 differtn things that don't work. Anyone else w/ similar issues?
infantsam is offline   Reply With Quote
Old 08-29-2006, 06:25 PM   #34
tankerWRX
Member#: 102053
2007 LGT (Sold)
According to the map notes from COBB if the restrictor is not 0.043" you will have boost issues. So, you say the stock STI pill is larger and does not need to be drilled. This also means you are using a restrictor that is not 0.043"... that might be the source of your problem. Just a shot in the dark.
I drilled mine to the #57 bit and have not had any problems, but I am also using a downpipe with a high-flow cat.
Old 08-29-2006, 06:44 PM   #35
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
i here ya - it's 'barely' bigger - the bit only just slides in. Bur befroe I go buying a pill and driling it I'd like to see what is really going on.
If I could understand the dern control system it would be easier to guage what to do. If I understand it the pill is used to damp the response so that the ECU does not overshoot it's targets.
And surely it is sensitive - it over-boosted much worse on day 2 when it was cooler.
Do you have this issue? Have you been on a road course where high load runs are semi-continuous? I'm not challenging - just looking for answers. I have a pretty strong feeling that going to get another pill and driling ti won't fix it. The idea that the wastegate can't flow enough and needs porting makes more sense to me.
A stage 2 STi exhibits similar behavior?? (Given some arguables that is at least very close to correct)
hmmm
It is quite nicely powerful though - so I think it's a great combination of minimal lag and goop power - PLENTY for the road course. Just got to get it sorted - fuel cut doesn't feel good at all.
Old 08-30-2006, 12:46 PM   #36
diamondsplitter
Member#: 102498
2006 WRX Wagon
WR Blue
If anyone doing a vf39 swap needs a #57 drill bit, send a self addressed stamped envelope to me, and I'll send you one. I have a few extra laying around. Just trying to help out. Pm me for my address. BTW, Did my swap last weekend. AWESOME
EDIT: Went to the track, dang clutch wont hold now! BOO!!
Last edited by diamondsplitter; 09-03-2006 at 10:14 PM. Reason: Went to track, clutch not holding!
Old 09-20-2006, 04:06 PM   #37
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
does any year STI tmic fit the 06'? what is required for fitment?
sluflyer06 is offline   Reply With Quote
Old 10-01-2006, 09:21 PM   #38
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
How about paypal for 5 bucks or something, I am in Afghanistan?
As for the oil line, if the VF39 I bought doesnt come with one, do you have a link to where to get it and cost? Also, if you modify it, you didnt say what you would have to do or why?
Is there any differences doing this on the 05?
Matth3w is offline   Reply With Quote
Old 10-01-2006, 09:48 PM   #39
coil222
Member#: 62091
2003 911 Turbo
Originally Posted by Tomnel View Post
Thanks! theres nothing like seeing pics and a step by step before tackling this for the first time.
+12345
Subscribing this for when I pull my turbo for WG portage!
coil222 is offline   Reply With Quote
Old 10-02-2006, 12:59 PM   #40
tankerWRX
Member#: 102053
2007 LGT (Sold)
I think this is the one you need. http://www.subaruparts.com/cart/?pn=15197AA060
Part #15197AA060
As for modifying it you basically just drill a hole because the spacing for the bolts are different.
Old 10-02-2006, 01:05 PM   #41
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
i got a message saying mine comes with the part so thanks a million
Old 12-24-2006, 03:49 PM   #42
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Dug this up from the dead to give a few thoughts...
Did a VF39 install yesterday. Thanks for the pics and instructions, it went very easy with the guidance of this thread.
- Do not loosen/unbolt the turbo from uppipe until after you have taken off the coolant lines. I did, and ended up with some (not much) coolant running down into the uppipe. Not a big deal, but I would have avoided it if I had thought about it before hand (doh!).
- For some reason, when my TurboXS uppipe was installed by anonymous local vendor X, they double-gasketed the UP-Turbo (one old, one new :/). I used a single new gasket and torqued to 35lbs. No leaks.
- I found it easier to remove the hard oil line from the block and turbo than to bend it out of the way. I feared breaking it more than the difficulty of reinstalling it, which was a PITA and took quite awhile. If you have the time, I'd think about removing it entirely.
- My TD04 had washers on both sides of the banjo bolts, so I reassembled the same way.
- Before tightening the turbo onto the uppipe, reinstall the passenger side TMIC bracket. It's a PITA to tighten the bracket bolt that is underneath of the coldside outlet once the turbo is fastened down.
- Both of my coolant lines leaked at the turbo after reinstall. The hoses are older and have 47k miles on them, so replacing them may have solved the problem. I took the easy route and hose-clamped both lines on the turbo side, done deal.
- I bought new vacuum-lines/T/pill from Subaru and used Zip-Ties on the inline coupler where it connects to the factory BCS to ensure I didn't have any boost control issues on the plumbing side.
- This might be just my mind playing tricks on me: The coldside outlet appears to be slightly offset of my TD04, which made the passenger side of my OEM TMIC sit closer to the firewall on that side, and miss the bracket. I pushed the IC hose further onto the pass side y-pipe deal and it fits fine now.
Good luck to all!
EDIT: My swap was on a 2L, so a few things might be slightly different.
lancelucas is offline   Reply With Quote
Old 02-25-2007, 03:10 AM   #43
Mooneyes13
Member#: 113666
60' all over you
great info here, vf39 swapping soon
Mooneyes13 is offline   Reply With Quote
Old 02-25-2007, 03:31 AM   #44
alpnwhite96
Member#: 115482
2006 WRX Limited
just did mine the other week, it went in/out easy as pie, even in 20 degree weather at night in the parking lot of my apt...
local ace hardware had plenty of irwin #57 bits.
alpnwhite96 is offline   Reply With Quote
Old 02-25-2007, 11:30 AM   #45
El Capitan
Member#: 121261
06 STG 2+ STi
Originally Posted by equipment junkie View Post
If you look at the picture shown a couple of posts above (from the cobb ap info) - you'll see where the pill is supposed to be. If for dome reason there is no pill inside the particular vacume line as indicated in the photo - you should be able to purchase one from your loca Subaru dealership.
Drill it out as described, place it into the vacume line - lube it with silicone spray (or even some light oil) - push it into the vacume line 1/2 " to 3/4". Obviously, you want to make sure that the
drilled hole in the brass pill is aligned with the vacume tube to allow air to pass throught it (I know it sounds pretty obvious - but I've seen simpler things screwed up!)
While I worked at Trollhattan Motors (a SAAB & Volvo place) a few years back, we had learned from the Bosch School in California that silicone spray should not be used anywhere it could be sucked into the engine. In small amounts it is supposed to casue the Lambda to prematurly fail or give bad readings and in large amounts will casue it to go haywire almost right away.
Are there and chemists out there who can confirm? Regular O2 sensors are expensive enough, I'd hate for some one to prematurly ruin a wideband.
El Capitan is offline   Reply With Quote
Old 03-01-2007, 05:15 PM   #46
t3ch9
Member#: 69549
I have a Cobb 2 stage ECU reflash and was interested in upgrading my turbo to a VF-39. How much more power will I get? Will I have to swap out the injectors as well as other internals?
thanks in advance for answering my q's.
t3ch9 is offline   Reply With Quote
Old 03-01-2007, 05:16 PM   #47
RP31
Member#: 123574
CGM STi
We need to know what car you drive.
Old 03-01-2007, 08:50 PM   #48
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
if you have a 02-05 WRX then you will need new injectors and a bigger intercooler.
if you have a 06-07 then you won't need the injectors.
power range for the OTS cobb maps can vary especially since we don't know what year you have...on the 2.5L i've seen anywhere from 260-300 at the wheels without a protune.
I'm currently running the OTS map and its ridiculously faster than the stock turbo but my car doesn't like the map much i'm only seeing about 10psi in 1st, 14 in 2nd and 3rd, and then about 15-15.5 in 4th and 5th...boost target for my OTS map is 16.6.
Old 03-01-2007, 09:14 PM   #49
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
That's what I like to hear! My VF39 will be here next week
06rexwagon is offline   Reply With Quote
Old 03-02-2007, 01:07 PM   #50
t3ch9
Member#: 69549
i drive a 02 wrx. Do I have to purchase pink injectors or is there a cheaper alternative. So the stock fuel pump will work with this turbo? Will the cobb 2 reflashed ECU work with the new turbo or should i purchase an access port?
Trunk Swap Instructions Sti-lysh Interior & Exterior Modification 15 01-11-2006 08:41 AM
N00b JDM STi swap instructions? perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2005 07:26 PM
clutch swap instructions? sailil Mid Atlantic Impreza Club -- MAIC 5 08-03-2004 09:03 AM
Trunk and lock swap instructions? Fair Oaks STI Interior & Exterior Modification 2 08-16-2003 02:59 PM
Bring back the bumper swap instructions! AccidenT General Forum Archive 1 03-17-2001 12:33 AM
