Brakes & Suspension Forum sponsored by The Tire Rack |
01-24-2007, 01:05 AM | #51 | |
Member#: 62313
Tri-State
Vehicle:2003 FP Green sonic yellow |
01-24-2007, 01:43 AM | #52 |
Member#: 50167
MWSOC
Vehicle:1996 Subaru STI RA White |
This is what the smart thing to do would be: http://godspeedbrakes.co.uk/Subaru/R...ar_classic.htm
Make those extra big handbrake pads in both normal and race like they do here in japan and then get with Tom to make a bracket. |
02-08-2007, 08:10 AM | #53 |
Member#: 50167
MWSOC
Turns out there is already a 5X100 rotor with a 170mm handbrake assembly that will work with a bracket for the brembos. WRXBRAKES PM me if you want more info.
02-08-2007, 08:19 AM | #54 |
Member#: 109250
02-08-2007, 10:31 AM | #55 |
Member#: 97352
SCIC
Vehicle:2005 6MT 35R Wagon Full STI drivetrain |
Yes...please share with the rest of us.
02-08-2007, 12:39 PM | #56 |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
02-08-2007, 03:48 PM | #57 |
Member#: 91837
i just received godspeeds thicker brake shoes... so far they look quite good. ill give my impressions once theyre on and ive tried them out
02-08-2007, 04:06 PM | #58 |
Member#: 109250
02-08-2007, 04:19 PM | #59 |
Member#: 91837
i ordered mine for an 05 wrx... they sent me a full set. so far i see no reason as to why they would not fit... ill fit them up today and let you know
02-08-2007, 06:28 PM | #60 |
Member#: 50167
MWSOC
The actual brake shoe should be the same across all Imprezas. I know that there is only one part number for the rally and gymkhana handbrake pads here in japan.
Also here is the thing. I am all about helping you guys out, but I am working two different brake upgrade options that are popular in Japan. The problem is the rotors are not available in the states. They came on non-USDM cars only. I will be speaking with WRXBRAKES about this. These are the rotors and brackets that go with the kit. It uses the 322mm R34 rotor as far as I can tell. I believe that the rotor has the 5X100 holes drilled in it specifically so it will work on the Subaru since the GTR uses 5X114.3 I believe. Last edited by keirnna; 02-09-2007 at 12:32 PM. |
02-18-2007, 08:13 PM | #61 |
Member#: 108210
SCIC
subscribed!!! please keep us updated!!!
03-05-2007, 08:41 PM | #62 | |
Member#: 116317
South East
Vehicle:2013 WRX Hatch |
-Mateospeed |
03-05-2007, 09:24 PM | #63 |
Member#: 125739
South East
03-06-2007, 12:53 AM | #64 |
Member#: 50167
MWSOC
03-06-2007, 01:23 AM | #65 |
Member#: 109250
03-06-2007, 01:24 AM | #66 |
Member#: 109250
Aaah, the pics:
Greetings from vienna |
03-06-2007, 01:18 PM | #67 | |
Member#: 21118
Tri-State
yeah...well...anyway. good luck with the info and getting it all straighten out. it would be nice for a bolt solution. though i did have the new backing plate for the subaru 2 pots put in. getting 12 year old wheels bearing changed as a good idea too! |
03-06-2007, 01:27 PM | #68 |
Member#: 125739
South East
The rotors are coming from DBA pretty soon - so with brackets we will have a bolt on solution.
03-30-2007, 11:29 AM | #69 |
Member#: 20798
MAIC
Vehicle:1886 Daimler Motor Carriage |
Any word on the DBA rotors?
03-30-2007, 12:50 PM | #70 |
Member#: 9
NWIC
Wow, this is good stuff. I'd like to know more about that GT-R rotor kit too! It's always nice to have more options.
04-02-2007, 01:18 AM | #71 |
Member#: 109250
Brembos front and rear are in, did use the thicker brake shoes from godspeed, mounting was easy
On the rear I removed this thing to get the bigger discs fitted: Difference between WRX and Brembo: The Result: Thanks Ian (www.godspeedbrakes.co.uk)! |
04-02-2007, 01:23 AM | #72 |
Member#: 97352
SCIC
Burschik:
Can you shed some light on the EXACT parts needed, and where you purchased them, to mount the rear calipers on the 5 x 100 rear? All I have now are the rear calipers and pads. |
04-02-2007, 01:43 AM | #73 | |
Member#: 109250
-rear Brembo calipers and pads from Sti -4 mounting bolts for the rear brembo calipers from Sti -rear Brembo discs from Sti 5x100 (i have 5x114,3 redrilled, see post above) -thicker (hand-)brake shoes from godspeed: http://www.godspeedbrakes.co.uk/Suba.../rearshoes.htm That's all, mounting is plug&play |
04-02-2007, 01:46 AM | #74 |
Member#: 97352
SCIC
Did you use the factory WRX backing plates? I assume this kit comes with new brackets for this conversion to work?
04-02-2007, 02:03 AM | #75 |
Member#: 70234
Tri-State
Vehicle:MY86 BMW E30 325 SCIC/NWIC tranplant (-_-) |
North American 02-05 WRXs will need a bracket b/c we got the 1-pot sliders and appropriate (smaller) backing plate.
Similar Threads | ||||
BRAKE ADAPTER to fit 06 STI Rear Brembos on 02 WRX | ed10 | Private 'Wanted' Classifieds | 0 | 06-01-2009 02:40 PM |
Gold Brembos on WRX --- rotor and bracket question | ted dibiase | Brakes, Steering & Suspension | 13 | 01-21-2009 04:40 PM |
Wanted: OEM WRX rear rotors and caliper brackets | JWB65 | MWSOC Private Classifieds | 4 | 09-26-2006 11:01 PM |
2003 WRX Rear rotors and caliper brackets | REX8 | Suspension/Brakes/Handling | 7 | 09-08-2006 11:14 PM |
98 rs calipers w/ wrx rotors and brackets | christianvwcars | Brakes, Steering & Suspension | 3 | 02-14-2004 11:18 AM |
