Old 03-09-2007, 11:48 AM   #1
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
Default ej20g injector replacement
been researching but wanted to be clear on if the 04 STi sidefeeds will swap in for the grey top 440's on my swap.
civic2scooby is offline   Reply With Quote
Old 03-09-2007, 01:38 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no
they are "pintle" style injectors
the sti 04-06 are "ball" style
thats said there is a guy selling 550/650/750 pintles on ebay
Old 03-09-2007, 01:53 PM   #3
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
Old 03-09-2007, 07:29 PM   #4
kbahus
Member#: 70256
2000 STI V2 Swapped
http://www.fecker.co.uk/scooby/fabri...etail.php?id=2
I am going to be ordering some these when my tax return shows up.
kbahus is offline   Reply With Quote
Old 03-10-2007, 12:07 AM   #5
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
now, from what i hear in the DSM world, they are interchangeable.....
but i really dont know. i mean, its just a needle valve versus a ball
Hurley 2.5 WRS is offline   Reply With Quote
Old 03-10-2007, 12:22 AM   #6
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
just found out they dont interchange....but that link I posted on ebay will I talked to the seller...gonna do 660 injectors as per my tuner.
Old 03-10-2007, 09:38 AM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
its the shape of the rail thats the proublem
the only reservation i have is that the "venom" injectors don't have an espically good reputation
Old 03-10-2007, 12:21 PM   #8
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
The STI side feeds fit into the JDM/EUDM 1999-2000 fuel rails, and also the EUDM/USDM Legacy 2.2 and 2.5 up to 1998.
Marnix is offline   Reply With Quote
Old 03-10-2007, 12:49 PM   #9
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Im running USDM STi inj. w/ ej25(NA, dohc) fuel rails. it was a good upgread and cost less then $200. If you looking at 300WHP this settup w/ be perfect. if your looking for more, contact RC and see what they can do for you.
snowman4us is offline   Reply With Quote
Old 03-10-2007, 12:51 PM   #10
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
ok?
I don't have an ej25 NA, dohc though....I have an EJ20G....
Old 03-10-2007, 09:57 PM   #11
oldhat
Member#: 113036
Originally Posted by civic2scooby View Post
These Venom injectors are pure, unadulterated ****.
http://www.rs25.com/forums/showthrea...enom+injectors
oldhat is offline   Reply With Quote
Old 03-10-2007, 09:59 PM   #12
oldhat
Member#: 113036
BTW, does anyone have a write up on how to swap injectors in an EJ20G?
Old 03-10-2007, 10:14 PM   #13
GripGC8
Member#: 110653
87 FC3S
snowman4us is saying:
you can use dohc 2.5 fuel rails and usdm sti injectors on your ej20g.
GripGC8 is offline   Reply With Quote
Old 03-10-2007, 10:59 PM   #14
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
ohhhhhh...ok yeah that was the confusing part...thanks
Old 03-12-2007, 03:32 AM   #15
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Also what I meant but maybe I wrote it down even more confusingly...
Old 03-12-2007, 03:35 AM   #16
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
yeah, I was just confused on the wording.
Old 03-12-2007, 03:37 AM   #17
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
sent you a pm on how to do this, probably work the same way for the dohc 2.5 rails.
turboL is offline   Reply With Quote
Old 03-12-2007, 03:40 AM   #18
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
thank you much!
Old 08-25-2008, 01:34 PM   #19
Zora
Member#: 74712
1995 Impreza Wagon
Crimson Pearl Met.
Guys, I know this has probably been beaten to death, but I haven't been able to find a definite answer to the following question...
Are the ANY USDM injectors that will be a direct replacement for a '97 WRX GF8 EJ20G motor (Phase I, grey tops), WITHOUT changing the fuel rails?
Thanks.
Zora is offline   Reply With Quote
Old 08-25-2008, 02:03 PM   #20
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no 12345
Old 08-25-2008, 03:54 PM   #21
Zora
Member#: 74712
1995 Impreza Wagon
Crimson Pearl Met.
Thanks for a quick reply. So could I use these fuel rails with STi injectors: http://cgi.ebay.com/ebaymotors/_Car-...4506.m20.l1116
They list a lot of engines, but I read in other threads that it is only the 2.5 DOHC rails that will work without mods. It would be nice if someone could confirm whether these will work for me.
Thanks.
Old 08-25-2008, 04:46 PM   #22
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
there are a few thread on this
i used 1.8 rails and had the tabs welded on
the other option is to use collers and the phase 2 injectors
Old 08-26-2008, 12:19 AM   #23
DSM_Outback
Member#: 56345
93 Swapped L
Green
Thanks.
Yes.
12345
DSM_Outback is offline   Reply With Quote
Ej20g piston replacement help........ gc895 Newbies & FAQs 3 05-25-2007 09:48 AM
In need of EJ20G injectors Millencolin! Private 'Wanted' Classifieds 2 03-17-2006 01:35 PM
wtb ej20g injector silvialost Private 'Wanted' Classifieds 0 11-03-2005 03:00 PM
ej20g injector problems smacksube Subaru Conversions 4 01-13-2004 03:12 PM
EJ20G Injectors NinNin Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-30-2002 03:37 PM
Message Board Statistics All times are GMT -4. The time now is 08:17 PM.
