Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 01-24-2007, 01:05 AM   #51
sonic rex 03
Member#: 62313
2003 16G 38mm ewg
sonic yellow
Originally Posted by WRXBrakes View Post
This is for installing STi rear Brembo calipers on a R160 rear hub that has a backing plate that accepts Subaru 1 pot sliding calipers.
Most commonly it would be for 02-05 USDM WRX's that have STi takeoffs in front and have too much front brake bias.
It would also fit many Forresters, Legacies, Baja's and older GC cars.
please keep us posted.
sonic rex 03 is online now   Reply With Quote
Old 01-24-2007, 01:43 AM   #52
keirnna
Member#: 50167
1996 Subaru STI RA
This is what the smart thing to do would be: http://godspeedbrakes.co.uk/Subaru/R...ar_classic.htm
Make those extra big handbrake pads in both normal and race like they do here in japan and then get with Tom to make a bracket.
keirnna is offline   Reply With Quote
Old 02-08-2007, 08:10 AM   #53
keirnna
Member#: 50167
1996 Subaru STI RA
Turns out there is already a 5X100 rotor with a 170mm handbrake assembly that will work with a bracket for the brembos. WRXBRAKES PM me if you want more info.
Old 02-08-2007, 08:19 AM   #54
BurschiK
Member#: 109250
Details
BurschiK is offline   Reply With Quote
Old 02-08-2007, 10:31 AM   #55
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Yes...please share with the rest of us.
BiggSean is offline   Reply With Quote
Old 02-08-2007, 12:39 PM   #56
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
pm'd ya
enquiring minds want to know
KNS Brakes is online now   Reply With Quote
Old 02-08-2007, 03:48 PM   #57
DZnutz
Member#: 91837
i just received godspeeds thicker brake shoes... so far they look quite good. ill give my impressions once theyre on and ive tried them out
DZnutz is offline   Reply With Quote
Old 02-08-2007, 04:06 PM   #58
BurschiK
Member#: 109250
Aren't they only for the classic Imprezas
Old 02-08-2007, 04:19 PM   #59
DZnutz
Member#: 91837
i ordered mine for an 05 wrx... they sent me a full set. so far i see no reason as to why they would not fit... ill fit them up today and let you know
Old 02-08-2007, 06:28 PM   #60
keirnna
Member#: 50167
1996 Subaru STI RA
The actual brake shoe should be the same across all Imprezas. I know that there is only one part number for the rally and gymkhana handbrake pads here in japan.
Also here is the thing. I am all about helping you guys out, but I am working two different brake upgrade options that are popular in Japan. The problem is the rotors are not available in the states. They came on non-USDM cars only. I will be speaking with WRXBRAKES about this.
These are the rotors and brackets that go with the kit. It uses the 322mm R34 rotor as far as I can tell. I believe that the rotor has the 5X100 holes drilled in it specifically so it will work on the Subaru since the GTR uses 5X114.3 I believe.
Old 02-18-2007, 08:13 PM   #61
gene4ace
Member#: 108210
subscribed!!! please keep us updated!!!
gene4ace is offline   Reply With Quote
Old 03-05-2007, 08:41 PM   #62
mateospeed
Member#: 116317
2002 WRX...sold:-(
Does anyone else think this is a crazy idea? More holes drilled in rotors? Scary!!
-Mateospeed
mateospeed is offline   Reply With Quote
Old 03-05-2007, 09:24 PM   #63
KNS Brakes
Member#: 125739
2015 WRB WRX
-Mateospeed
It's not an issue.
Old 03-06-2007, 12:53 AM   #64
keirnna
Member#: 50167
1996 Subaru STI RA
-Mateospeed
It is not an issue whatsoever!
Old 03-06-2007, 01:23 AM   #65
BurschiK
Member#: 109250
-Mateospeed
No Problem, did this myself with Brake discs from a 06 STi (PCD 114,3 to 100)
Old 03-06-2007, 01:24 AM   #66
BurschiK
Member#: 109250
Aaah, the pics:
Greetings from vienna
Old 03-06-2007, 01:18 PM   #67
Boxologist
Member#: 21118
-Mateospeed
Does anyone else think this is a crazy idea? More holes drilled in wheels? Scary!!
yeah...well...anyway. good luck with the info and getting it all straighten out. it would be nice for a bolt solution. though i did have the new backing plate for the subaru 2 pots put in. getting 12 year old wheels bearing changed as a good idea too!
Boxologist is offline   Reply With Quote
Old 03-06-2007, 01:27 PM   #68
KNS Brakes
Member#: 125739
2015 WRB WRX
The rotors are coming from DBA pretty soon - so with brackets we will have a bolt on solution.
Old 03-30-2007, 11:29 AM   #69
ToesWRX
Member#: 20798
1886 Daimler
Motor Carriage
Any word on the DBA rotors?
ToesWRX is offline   Reply With Quote
Old 03-30-2007, 12:50 PM   #70
geoffj
Member#: 9
Wow, this is good stuff. I'd like to know more about that GT-R rotor kit too! It's always nice to have more options.
geoffj is offline   Reply With Quote
Old 04-02-2007, 01:18 AM   #71
BurschiK
Member#: 109250
Brembos front and rear are in, did use the thicker brake shoes from godspeed, mounting was easy
On the rear I removed this thing to get the bigger discs fitted:
Difference between WRX and Brembo:
The Result:
Thanks Ian (www.godspeedbrakes.co.uk)!
Old 04-02-2007, 01:23 AM   #72
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Burschik:
Can you shed some light on the EXACT parts needed, and where you purchased them, to mount the rear calipers on the 5 x 100 rear?
All I have now are the rear calipers and pads.
Old 04-02-2007, 01:43 AM   #73
BurschiK
Member#: 109250
Originally Posted by BiggSean View Post
Burschik:
For my WRX (peanut eye) I did need following parts:
-rear Brembo calipers and pads from Sti
-4 mounting bolts for the rear brembo calipers from Sti
-rear Brembo discs from Sti 5x100 (i have 5x114,3 redrilled, see post above)
-thicker (hand-)brake shoes from godspeed:
http://www.godspeedbrakes.co.uk/Suba.../rearshoes.htm
That's all, mounting is plug&play
Old 04-02-2007, 01:46 AM   #74
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Did you use the factory WRX backing plates? I assume this kit comes with new brackets for this conversion to work?
Old 04-02-2007, 02:03 AM   #75
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
North American 02-05 WRXs will need a bracket b/c we got the 1-pot sliders and appropriate (smaller) backing plate.
kennyvb is offline   Reply With Quote
BRAKE ADAPTER to fit 06 STI Rear Brembos on 02 WRX ed10 Private 'Wanted' Classifieds 0 06-01-2009 02:40 PM
Gold Brembos on WRX --- rotor and bracket question ted dibiase Brakes, Steering & Suspension 13 01-21-2009 04:40 PM
Wanted: OEM WRX rear rotors and caliper brackets JWB65 MWSOC Private Classifieds 4 09-26-2006 11:01 PM
2003 WRX Rear rotors and caliper brackets REX8 Suspension/Brakes/Handling 7 09-08-2006 11:14 PM
98 rs calipers w/ wrx rotors and brackets christianvwcars Brakes, Steering & Suspension 3 02-14-2004 11:18 AM
