#76 | |
Member#: 39514
SWIC
Vehicle:2003 WRX 2.5L Hybrid Mostly Blue |
I swear to god man, you get an idea in your head and we need a bulldozer to get it out. ![]()
#77 | |
Member#: 134222
MWSOC
Vehicle:2013 Ferd ST Tuxedo Black |
sorry to bump an old thread... but i have this same problem and this leak is pissing me off hardcore |
#78 |
Member#: 132215
NWIC
Vehicle:06 Mitsubishi Evo Wicked White |
Thinking about doing this but since I have a FMIC plugging it into the Turbo Output to test the intercooler piping.
Hoping I dont have to pull off the bumper to fix a leak. |
#79 |
Member#: 73055
Vehicle:04 STi White |
What did you guys use to plug the three nipples on the turbo inlet?
#80 |
Member#: 35269
Tri-State
Vehicle:2011 WRX |
I was able to run the test but the air was coming straight out of the exhaust. This is with the fitting in the turbo inlet, capped off the fittings, capped off the intercooler piping at the throttle body coupler.
I could sit there and constantly run air through and it would not compress. I sat down by the exhaust and absolutely heard air coming out. What does it all mean? |
#81 |
Member#: 46135
Tri-State
Vehicle:02 WRX Powered by Sti V9 Spec C |
I think it's possible that all engines stop in the same positions, most of the time. It can be that in the WRX a position is with one of the cylinders having intake and exhaust valves open.
#82 |
Member#: 35269
Tri-State
Vehicle:2011 WRX |
I don't think that's possible since I capped off before the throttle body.
#83 |
Member#: 46135
Tri-State
Look, if there was no physical connection between the air supply and the engine (you disconnected and caped everything), then I don't know see how the air got into the exhaust. It would have to travel from the compressor housing into the turbine housing.
#84 |
Member#: 35269
Tri-State
Vehicle:2011 WRX |
It seems that way doesn't it? That's why I'm posting about it. I'm ******* LOST!
It's like this...air into the turbo inlet, capped all 4 connections on that, including the bpv hose. Capped the throttle coupler at the throttle body. At that point I was thinking I would strictly be testing the intake system since everything else was bypassed but somehow the air won't compress and comes right out the exhaust. I had sure I could hear the air coming, going, coming, going, etc as he fed it. |
#85 |
Member#: 46135
Tri-State
Was everything cold? Try to separate the turbo, that would confirm the finding. Did you also cap the compressor boost pickup nipple?
#86 |
Member#: 35269
Tri-State
Vehicle:2011 WRX |
Yeah everything was completely cold. Car hasn't ran since Tuesday.
I got mad and ripped it apart. The turbo is out and sitting on the work bench. Tomorrow I'm going to swap my TD04 back in and see if that does anything. Far from the easiest way to diagnose but I was mad and something is telling me it's the turbo. |
#87 |
Member#: 51427
I am having a real hard time sourcing the parts especially the rubber cap......can anyone post an internet link to somewhere that has them?
#88 |
Member#: 46135
Tri-State
It's weird. If the prosibility exists for a leak between compressor and turbine, probably the exhaust would come into the compressor, there's more pressure there.
Otherwise, the leak would have to be in the wastegate area. I havent' heard of this from other forums, maybe it's a TD04 problem? |
#89 |
Member#: 35269
Tri-State
Vehicle:2011 WRX |
I'm running a VF23. What would be the best way to test the wastegate while the turbo is out of the car?
#90 |
Member#: 46135
Tri-State
This may sound stupid, but hook up the air supply to intake side of the compressor and maybe try to close the outlet with your palm. I think that this way you won't do dammage because you'll just use your judgement.
Obviously, a leak will be heard on the exhaust (turbine) side. I got the idea from the days when I was cleaning carburetors by reving and chocking the carburetor intake with my palm. ![]() |
#91 |
Member#: 57871
NESIC
Vehicle:2004 WRX 13.4 @ 102 |
subbed for future reference!
#92 |
Member#: 145425
HIIC
Vehicle:2002 WRX PSM |
im gonna try make this tommarrow.. hopefully it will get me out of "limp" mode !!!! i think i have been running on wastegate since the dealership sold me the car.. bastards..
#93 |
Member#: 147350
South East
Vehicle:'03 2.5/2.0L Hybrid 308hp/320tq |
Yo Erick,
Did you ever do this? Do you have a pressure tester. This not hitting full boost is really getting to me. I replaced all the vac lines in the car so the leak, if there is one, must be coming from somewhere else. Wanna help me figure it out? ![]() |
#94 |
Member#: 145684
Tri-State
Vehicle:03 WRX Silver |
so.... what size pvc piping should I get for the stock inlet hose???
#95 |
Member#: 108051
Tri-State
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
#96 |
Member#: 108051
Tri-State
mske sure your boost gauge goes right to your Manifold with no T off's in the vac hoses if there is it wont be a correct boost reading.
#97 |
Member#: 108051
Tri-State
also check the stock turbo inlet when i took mine off the clamp was lose where it clamped to the turbo.
#98 |
Member#: 145684
Tri-State
#99 |
Member#: 117991
NESIC
is it necessary to plug the ventilation ports on the inlet to perform this test?
#100 |
Member#: 74792
VIC
| Thread Tools | |
| Display Modes | |
| This just in - the War on Drugs is a complete failure | FightingFalcon | Political Playground | 1655 | 05-12-2013 03:33 AM |
| A complete n00b's guide to changing the oil in your WRX (with pics!) | perret318 | Service & Maintenance | 140 | 06-23-2012 12:38 PM |
| Swap complete, just lost the clutch! | SJwrx | Pre-2002 Factory Turbo Powertrain | 9 | 05-08-2010 01:56 AM |
| The longest lasting DIY paint your wheels thread | chimchimm5 | Tire & Wheel | 1 | 04-03-2010 01:26 PM |
| Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. | Chandy69 | Tri-State Area Forum | 13 | 05-09-2005 05:58 PM |
