#1 |
Member#: 72519
SCIC
Vehicle:05 EJ20T silveR. |
hey guys.
i need some help from people who have experienced my problem. i installed the h1 10k set on my 05 wrx. after i got them installed properly. when i went to test them, they didnt turn on. is it possible that i shorted the ballast? might of been a spark tht i didnt see. neither side turns on.? what shud i do? please help, very ashamed at myself if i did sumpn wrng.
#2 |
Member#: 104176
SCIC
Vehicle:2005 wrxxx obp |
reverse the polarity, it worked for me.
#3 |
Member#: 72519
SCIC
which wires r u talkign about? im pretty sure something shorted. because both my fuses blew and had to replace them to get my fogs and high beams working. but h1's still didnt turn on
#4 |
Member#: 87921
SCIC
Vehicle:09 TSX 6 speed WRX has been sold |
+1 for reverse polarity... The ground and power wire colors are reversed on the 05 headlight harness. Switch them around and use a test light to confirm the polarity. Its been stated on one of the HID write ups...search around and you will find it.
#5 |
Member#: 9
NWIC
I thought this was going to be a totally different kind of disappointment.
#6 |
Member#: 29355
NWIC
Vehicle:2003 GD6 Hate chall but i'mma maintain |
#7 |
Member#: 72519
SCIC
HAHAHA
imm ahave to try the polarity trick tomm. well i hadta catch ur guys attention some how thanx for the input. and one more question? if my ballasts made a spark when it touched another piece of metal and blew out my headlight fuse. will that in soem way damage my ballast so it wont work ne more? |
#8 |
Member#: 115154
MWSOC
Vehicle:2003 Legacy L Turbo silver |
Here comes the HID nazi's >_>
#9 |
Member#: 72519
SCIC
anyone think that a relay harness would solve my problem?
what do i need to do to get my mccullochs working? |
#10 |
Member#: 95992
SWIC
Vehicle:08 E92 335i Grey |
try constant power and constant ground whould work no matter what, to rule out bad ballests and/or bulbs
#11 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
#12 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
#13 |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
10k... I didnt know they actualy got that hot...
#14 |
Member#: 72519
SCIC
i didnt have to go with constant ground and power.
didnt need a relay. just did the good ol' polarity switcha roo. 10ks looks great. thnx guyzz |
#15 |
Member#: 145785
Tri-State
Vehicle:2004 Impreza Sti Platinum Silver |
#16 |
Member#: 121883
E. Canada
#17 | ||||
Vehicle:OK Houston we have an Uncle |
...and here we all thought nobody was actually dumb enough to put 10k's on their car ![]() |
#18 |
Member#: 50142
South East
Vehicle:2002 2.5TS MBP |
#19 |
Member#: 53200
MWSOC
Vehicle:2004 S60R Gray |
there is nothing wrong with your HID's. I have that Mcculloch kit, and it works great. Things that you could be messing up:
1) reverse the polarity. 2) try using the high beams. 3) replace the fuse. 4) check wiring. |
#20 |
Member#: 131768
E. Canada
Vehicle:2004 WRX WRB |
Red wiring from your HID connect it to the black wiring of your Headlight then black is to red...try that!!
| Thread Tools | |
| Display Modes | |
| disappointment after disappointment | 12eckless WRX | General Community | 88 | 06-04-2004 10:21 AM |
| McCulloch 5000k H.I.D. in Stock headlight | DNG_WRX | Interior & Exterior Modification | 7 | 06-04-2002 05:17 PM |
| Your opinion on McCulloch H.I.D. | MaximusRex | Interior & Exterior Modification | 22 | 05-25-2002 02:27 AM |
