Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 04-05-2007, 12:50 AM   #1
akuma59
Member#: 72519
05 EJ20T
silveR.
Default Mcculloch 10k disappointment
hey guys.
i need some help from people who have experienced my problem.
i installed the h1 10k set on my 05 wrx.
after i got them installed properly. when i went to test them, they didnt turn on.
is it possible that i shorted the ballast? might of been a spark tht i didnt see.
neither side turns on.? what shud i do?
please help, very ashamed at myself if i did sumpn wrng.
akuma59 is offline   Reply With Quote
Old 04-05-2007, 01:03 AM   #2
luv4suby
Member#: 104176
2005 wrxxx
obp
Default simple but works
reverse the polarity, it worked for me.
luv4suby is offline   Reply With Quote
Old 04-05-2007, 01:08 AM   #3
akuma59
Member#: 72519
05 EJ20T
silveR.
which wires r u talkign about? im pretty sure something shorted. because both my fuses blew and had to replace them to get my fogs and high beams working. but h1's still didnt turn on
Old 04-05-2007, 01:31 AM   #4
Penguin150
Member#: 87921
09 TSX 6 speed
WRX has been sold
+1 for reverse polarity... The ground and power wire colors are reversed on the 05 headlight harness. Switch them around and use a test light to confirm the polarity. Its been stated on one of the HID write ups...search around and you will find it.
Penguin150 is offline   Reply With Quote
Old 04-05-2007, 02:06 AM   #5
geoffj
Member#: 9
I thought this was going to be a totally different kind of disappointment.
geoffj is offline   Reply With Quote
Old 04-05-2007, 02:24 AM   #6
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
ditto. funny how so many fail to see the light when they see the light.
Handsdown is offline   Reply With Quote
Old 04-05-2007, 03:24 AM   #7
akuma59
Member#: 72519
05 EJ20T
silveR.
HAHAHA
imm ahave to try the polarity trick tomm.
well i hadta catch ur guys attention some how
thanx for the input.
and one more question?
if my ballasts made a spark when it touched another piece of metal and blew out my headlight fuse. will that in soem way damage my ballast so it wont work ne more?
Old 04-05-2007, 03:24 AM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Here comes the HID nazi's >_>
rougeben83 is offline   Reply With Quote
Old 04-06-2007, 04:21 AM   #9
akuma59
Member#: 72519
05 EJ20T
silveR.
anyone think that a relay harness would solve my problem?
what do i need to do to get my mccullochs working?
Old 04-06-2007, 04:32 AM   #10
pajak
Member#: 95992
08 E92 335i
Grey
try constant power and constant ground whould work no matter what, to rule out bad ballests and/or bulbs
pajak is offline   Reply With Quote
Old 04-06-2007, 07:10 AM   #11
fastwrx25
Member#: 126441
03 bugeye
word.
Your lights are actually working fine.
that is what 10k looks like.
Old 04-06-2007, 12:17 PM   #12
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Box em up, send them back to the store. Retrofit with a pair of 4300k's. Done.
cucamelsmd15 is offline   Reply With Quote
Old 04-06-2007, 01:37 PM   #13
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
10k... I didnt know they actualy got that hot...
IllNastyImpreza is offline   Reply With Quote
Old 04-06-2007, 02:16 PM   #14
akuma59
Member#: 72519
05 EJ20T
silveR.
i didnt have to go with constant ground and power.
didnt need a relay.
just did the good ol' polarity switcha roo.
10ks looks great.
thnx guyzz
Old 04-09-2007, 04:35 PM   #15
whifkey Sti
Member#: 145785
2004 Impreza Sti
Platinum Silver
Originally Posted by fastwrx25 View Post
word.
Yea thats exactly what I was thinking also. I'm not too familiar with wiring and stuff so I try and stay away from it.
whifkey Sti is offline   Reply With Quote
Old 04-10-2007, 12:46 PM   #16
jezzy
Member#: 121883
hahahah
jezzy is offline   Reply With Quote
Old 04-10-2007, 01:04 PM   #17
word.
Originally Posted by jezzy View Post
hahahah
...and here we all thought nobody was actually dumb enough to put 10k's on their car
Old 04-11-2007, 09:38 AM   #18
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Should we tell him that he could've gotten 30k's?
BlkTS02 is offline   Reply With Quote
Old 04-11-2007, 11:49 PM   #19
4pOwnag3
Member#: 53200
2005 LGT
there is nothing wrong with your HID's. I have that Mcculloch kit, and it works great. Things that you could be messing up:
1) reverse the polarity.
2) try using the high beams.
3) replace the fuse.
4) check wiring.
4pOwnag3 is offline   Reply With Quote
Old 04-12-2007, 01:24 AM   #20
jd20jd
Member#: 131768
2004 WRX
Red wiring from your HID connect it to the black wiring of your Headlight then black is to red...try that!!
jd20jd is offline   Reply With Quote
disappointment after disappointment 12eckless WRX General Community 88 06-04-2004 10:21 AM
McCulloch 5000k H.I.D. in Stock headlight DNG_WRX Interior & Exterior Modification 7 06-04-2002 05:17 PM
Your opinion on McCulloch H.I.D. MaximusRex Interior & Exterior Modification 22 05-25-2002 02:27 AM
