Old 04-08-2007, 12:18 PM   #1
insaners
Member#: 34072
01 RSTi
Default No speedo/fan relay clicking
Just recently after i put a new clutch in my car my speedo stopped working and my fan relay keeps clicking....any suggestions?!?!?!?!?!?
insaners is offline   Reply With Quote
Old 04-08-2007, 12:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Is the VSS plugged in? It would have been disconnected when the trans was pulled, might have forgotten to plug it back in.
If this is the case you'd have a CEL. Also is the CEL flashing constantly? If so check the green connectors under the driver side dash, they must NOT be plugged together. If someone connected them it will put the ECU into a diagnostic mode and cause the fans to cycle among other things.
Mulder is offline   Reply With Quote
Old 04-08-2007, 09:12 PM   #3
insaners
Member#: 34072
01 RSTi
What is the vss?
Old 04-08-2007, 10:04 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Vehicle speed sensor, it's on the trans. It supplies speed info to the ECU and speedo/odo.
Old 04-11-2007, 11:58 PM   #5
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
the problem is the VSS is very picky to get it in to the transi would recommend getting a new one, other than that i would check the connector for the sensor, as far as the fan relay clicking on and off i couldnt tell you i'd say if you didnt install that fan back in then extend the wires to the a/c fan since the A/C has been removed
mxturboracer86 is offline   Reply With Quote
Old 04-12-2007, 12:31 AM   #6
insaners
Member#: 34072
01 RSTi
Is there any way i can voltage test the sensor before i buy a new one?
Old 04-12-2007, 01:56 AM   #7
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
pull the sensor out of the trannie and spin it wit a drill wit hte key on and see if the speedo works
Relays clicking? Dubld Normally Aspirated Powertrain 3 09-05-2009 11:50 PM
Headlights are dead, No Speedo, No ABS StoryBookSin Electrical & Lighting 3 12-04-2007 04:26 PM
Fan relays? DubyaAreEcks Service & Maintenance 2 07-07-2006 12:28 AM
2.5RS no spark...fuel pump relay clicking polak13 Normally Aspirated Powertrain 8 01-26-2006 03:25 PM
fan relay location SteveW Technical Forum Archive 0 09-27-2000 12:56 AM
