Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 04-11-2007, 08:04 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Tgv Delete Group Buy!!!! (STI EJ25 & WRX EJ20)
Hey guys,
We have just put together a TGV Delete Group Buy.
2002-2005 WRX EJ20
The best solution for the 2002-2005 WRX EJ20 is the JDM Spec C manifold. Not only does this manifold look amazing, it deletes your TGV's thus improving performance (you will need some form of engine management to turn off the CEL).
JDM SPEC C INTAKE MANIFOLD & Gruppe-S Fuel Rail Adapter
-Designed for top feed injectors
-~20% flow improvement
-Includes Gruppe-S Fuel Rail Adapter
$399 Shipped!! (normal price $449)
2004+ STI EJ25
Don't waste your time welding up your stock TGV housings (and testing for leaks). Go OEM! These are JDM OEM TGV deletes for a limited edition STI car. They are BRAND NEW.
-JDM STI TGV'S
-~20% increase in flow
-Will bolt on to stock USDM manifold and heads
-Minor modification to the USDM manifold is required (you will have to enlarge the 2x center holes on each side by ~2mm). It's a 5 minute job with a drill
$169 Shipped!! (normal price $199)
GROUP BUY TERMS:
*100% DEPOSIT IS REQUIRED
*LEAD TIME IS 4-6 WEEKS
*GROUP BUY CLOSES 5/1/07
Gary
Gruppe-S
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 04-12-2007, 05:14 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
Gruppe-S is offline
Old 04-13-2007, 01:39 AM   #3
BiggSean
Member Sales Rating: (23)
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
I'm confused, isn't this the same group buy you had here?
http://forums.nasioc.com/forums/show....php?t=1111476
Will the adapter allow you to run USDM fuel rails?
BiggSean is offline
Old 04-13-2007, 12:30 PM   #4
orwrx
Member Sales Rating: (102)
Member#: 33869
2002 wrx
rally blue
Hey Gary, I'm confused too. Ppl are waiting for your adaptor for it, but you are starting another GB for the same thing that comes with the adaptor? Same qustion here, can I buy the adaptor only? Does your adaptor fit with Perrin V2 fuel rail kit?
orwrx is offline
Old 04-13-2007, 12:33 PM   #5
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
The original GB was $349.99 for the V8 manifold. Are we to assume that the adapter is $50 if we want to buy that by itself?
BiggSean is offline
Old 04-13-2007, 05:04 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The adapters would be $69 shipped if you wanted the adapters by itself. Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-13-2007, 05:05 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yup, they will fit with the Perrin rails.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-13-2007, 05:13 PM   #8
Midwestrider
Member Sales Rating: (5)
Member#: 42955
2004 Bone Stock..
Does this adapter you offer work w/ BDL Industries fuel rails for WRX's (2004)
So this is a direct bolt-on to the USDM models if I have read everything correctly.
Thanks in advance
-E
Midwestrider is offline
Old 04-13-2007, 06:29 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks in advance
-E
Hi E, you will probably have to relocate some wires / sensor holders, but the manifold bolts on directly to the USDM WRX heads, and the fuel injectors will work. Honestly I would consider this a more advanced mod, it's not really meant for guys that are running stock turbos or even VF34's.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-13-2007, 06:51 PM   #10
Midwestrider
Member#: 42955
2004 Bone Stock..
Thanks,
Gary
Gruppe-S
Thanks Gary for the heads up. But whom said I was running a VF34 or stock unit.
I will have to ponder going this route vs doing the deletes and using my stock manifold.
Eric
Old 04-13-2007, 08:00 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Eric
Hehe sorry I wasn't implying you were runing the VF34, I was just generalizing. If you're looking for big power you will want to run this manifold - there is a small loss associated with turbulence during the transition between TGV and manifold according to STI engineers. This is exactly why the V8 manifold is a 1 pc unit as opposed to the V7 manifold with TGVless housings.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-13-2007, 09:56 PM   #12
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
I will ask this question again. Will it work with the USDM fuel rails provided we use your adapters?
BiggSean is offline
Old 04-13-2007, 11:25 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi Sean,
Yes the JDM V8 intake manifold coupled with our Gruppe-S adapters will accomodate the OEM fuel rails on an 02-05 WRX. Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-16-2007, 05:17 PM   #14
WRXShawn
Member Sales Rating: (6)
Member#: 35742
2002 PPG + FPGreen
PM'ed you with a few questions. By lead time 4-6 weeks do you mean that we will receive the manifolds 4-6 weeks after May 1, 2007?
WRXShawn is offline
Old 04-18-2007, 09:02 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey,
Yea 4-6 weeks after may 1st. Thanks for your patience!!
Zak
Gruppe-s
Gruppe-S is offline
Old 04-18-2007, 09:54 PM   #16
sonic03rex
Member Sales Rating: (17)
Member#: 40534
2008 STI
M3, and more
Gary or Zak,
is there a limit to the number of people that can take advantage of this GB? I'm thinking of purchasing the setup but won't have the funds till the 27th. Thanks guys!
sonic03rex is offline
Old 04-18-2007, 10:51 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
No limit, although I hear we they may be running low in Japan. As with the RA gears this is a limited production item, Subaru Japan only keeps a couple dozen of each part # in stock at any given time!
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-19-2007, 12:01 AM   #18
THE-95-STi
Member Sales Rating: (30)
Member#: 113734
1998 FSTi, 95 sold!
the JDM yO!(MAIC4LIFE)
possibly instrested in STi TGV's, what injectors/rails will work with them? I am going topfeed
THE-95-STi is offline
Old 04-19-2007, 05:55 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The STI TGVs are designed specifically for the side feed injectors. If you are looking for top feed TGVs we can special order those too (from the V7 STI) but they are a bit more expensive. My recommendation is to go with the entire V8 manifold - that flows better than having a 2 pc setup. Thanks,
Gary
gary@gruppe-s.com
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 04-19-2007, 09:56 PM   #20
SAABARU_92x
Member Sales Rating: (13)
Member#: 118974
how do we get in? and this is a direct bolt in for the stock 2.0 mani?
SAABARU_92x is offline
Old 04-20-2007, 12:01 AM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Just call!
This is a direct bolt on for the EJ205 with the Gruppe-S fuel rail adapters
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 04-20-2007, 08:51 AM   #22
SAABARU_92x
Member#: 118974
does this package come with necessary gaskets and also what kind of powerboost would this give, rough estimate is fine!~thx
Old 04-20-2007, 08:59 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
SAABARU_92x,
PM'd!
Gruppe-S is offline
Old 04-20-2007, 10:07 PM   #24
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Ok, sign me up for one too with the fuel rail adapter.
BiggSean is offline
Old 04-20-2007, 10:57 PM   #25
mathetes
Member Sales Rating: (18)
Member#: 106238
So....will this be beneficial for a stage 4 (vf34) set up? I was told by a tuner that it would.
mathetes is offline
Closed Thread
fs: aps tgv deletes with 04 sti tgv motors boostinwrx Engine/Power/Exhaust 2 12-03-2009 08:56 AM
04 STi EJ25 & 02 WRX EJ20 Block, EJ20 Heads with cams WRenXhaven Engine/Power/Exhaust 25 07-22-2009 09:40 PM
WTB TGV delets for 04 Sti XSTIc Private 'Wanted' Classifieds 2 01-15-2009 02:08 PM
TGV Delete on 07 STi - Motor/Sensor Unit and CEL? KevlarSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 11-30-2007 02:35 AM
FS: APS TGV deletes for USDM STi (sidefeed injectors) **PICS** phlegmon Private 'For Sale' Classifieds 0 07-19-2006 10:46 PM
