Old 03-20-2007, 01:06 AM   #1
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Default Went rotated? Tired of the stock power steering lines?
Well, I think I have a solution!
Ever since we installed the Perrin rotated turbo kit on my car last winter, the stock power steering lines have always looked like ass and never fit correctly. So after seeing a few cars on here that had steel braided lines made for the high pressure line off the power steering pump, I decided it was time to give it a shot.
So my buddy and I went to Summit Racing tonight and this is what we came up with.
http://store.summitracing.com/partde...0&autoview=sku - This the adapter that goes into the power steering pump. It goes from a 14x1.5 to a -6AN fitting.
http://store.summitracing.com/partde...0&autoview=sku - This a -6AN fitting to a -6AN line with a 90* bend on it that comes off of the fitting above.
http://store.summitracing.com/partde...0&autoview=sku - 6 feet of braided SS teflon line - this is capable of handling the higher pressures in a power steering system comparted to regular braided SS rubber hose. We only used about 4 feet of it and will probably use less once the motor is in the car and we can finish mocking it up. You need a whiz wheel or a big set of cutters to cut this stuff. I taped it to keep it from fraying and used a Dremel with a cutoff wheel.
http://store.summitracing.com/partde...0&autoview=sku - this part is the adapter to go from the 14x1.5 fitting on the steering rack to a -6AN fitting, which connects to the part below.
http://store.summitracing.com/partde...0&autoview=sku - this part connects the -6 hose to the above adaptor.
All of this cost ~$77 after tax and about an hours worth of work. We put everything together, I blew into it and it seemed to not leak, but I won't know for sure until the engine is back in the car and I start it up.
Also, I bought a few feet of 3/8" fuel injection hose to go from the bottom port on the power steering resevoir to the other port on the steering rack.
All and all, it seems like it should work and I'm happy with the way it turned out. We took some pictures tonight and my buddy will download them tomorrow and I will post them up.
Just trying to clean up the overly cluttered Subaru engine bay.
SloRice is offline   Reply With Quote
Old 03-20-2007, 01:15 AM   #2
SloRice
Member#: 44351
2004 Mitsubishi Evo
Here are the pictures. Not the best but it's what I got.
Old 03-20-2007, 01:23 AM   #3
veightkiller
Member#: 78967
2011 335i
do a write up after your done im interested doing this mod.
thanks
veightkiller is offline   Reply With Quote
Old 03-20-2007, 03:37 AM   #4
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
awesome Tim! I have always wanted to do this from the time I went rotated. that hard power steering line is always in the way of things. Looks like I'll have to add these parts to my summit order. ooo this is going to be one big order (a1000 pump, aero filter, regulator, etc..) should be worth it though for my new setup
dan avoN7 is offline   Reply With Quote
Old 03-20-2007, 08:22 AM   #5
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
subscribed
Zornorph is offline   Reply With Quote
Old 03-20-2007, 11:02 AM   #6
SPIN2GST
Member#: 106665
05 Buschur Powered
Evo w/corn in da poop
Ok this is the correct part #. However on Summits website it is the wrong picture. It is a female to male fitting. Check uploaded pics for referance.
SPIN2GST is offline   Reply With Quote
Old 03-20-2007, 11:08 AM   #7
jays05
Member#: 78165
05 STI 35r + e85
Awesome! I bookmarked this thread. Gonna do the same thing when my motor goes back in.
jays05 is offline   Reply With Quote
Old 03-20-2007, 11:47 AM   #8
SloRice
Member#: 44351
2004 Mitsubishi Evo
bump for pics added.
Also, as I said in the first post, I did blow into the lines and they seamed sealed. But until I actually run PS fluid through them at high pressure, I don't know for sure if they are going to seal.
So there are the part numbers...anyone with a running car want to be the guinea pig?
Old 03-20-2007, 11:55 AM   #9
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The stock pressure line has a restrictor built into it... Did you get that put back in? If you didn't, your fluid will foam up in the pump and in the resevoir and your power steering will work like ass... Trust me, I know
wrx_driver_2002 is offline   Reply With Quote
Old 03-20-2007, 12:03 PM   #10
SloRice
Member#: 44351
2004 Mitsubishi Evo
bah! I've heard of this supposed restrictor. Where is it at in the line?
Old 03-20-2007, 03:19 PM   #11
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
SloRice I think you can be the guinea pig since you already have it all setup
I've seen stainless power steering line that was rated higher than teflon based line. Also I think it was earls or some company that also had power steering line fittings. not sure if it is all required though
Old 03-20-2007, 04:14 PM   #12
SloRice
Member#: 44351
2004 Mitsubishi Evo
I don't care, I'll be the guinea pig, but my car isn't going to be moving anytime soon.
The SS teflon line and the Russell fittings I purchased are designed for power steering pressures (2500psi max), whereas the regualar SS line is rated for 1000psi.
Old 03-20-2007, 04:32 PM   #13
veightkiller
Member#: 78967
2011 335i
everything just bolt right in right?with no problem?
Old 03-20-2007, 05:14 PM   #14
Trevor723
Member#: 57989
2016 .:R
LGM
sure just send it to me and I'll be your guinea pig :P
Trevor723 is offline   Reply With Quote
Old 03-21-2007, 10:54 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
RSX guys with superchargers have been doing this for years without any issues. Not sure if they have a restrictor built into the stock hose though.
Tony
Old 03-28-2007, 04:47 PM   #16
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
any more info on that restrictor in the wrx or sti line?
Old 03-28-2007, 05:01 PM   #17
SloRice
Member#: 44351
2004 Mitsubishi Evo
I talked to one shop on this forum about it and they said the power steering pump whined, but everything is still working 15000 miles later.
He also said they didn't know what kind of condition the pump was in to begin with because the car hadn't ran in like 3 years. So it may have done that anyway.
Old 03-28-2007, 05:54 PM   #18
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Not to be an A$$ but you might want to listen to what this guy is saying, his car is already driving with the mod. So he has good experiance with it working or not.
Token-Negro is offline   Reply With Quote
Old 03-28-2007, 07:41 PM   #19
the aaron vaccar
Member#: 77255
looks good!
im going to summit soon, mabey ill look into this while im there....i love living by the walmart of car stores
the aaron vaccar is offline   Reply With Quote
Old 03-28-2007, 10:28 PM   #20
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Nice write up man I was planning on doing this.
Poweredbysnail is offline   Reply With Quote
Old 04-22-2007, 04:01 AM   #21
Ctracer911
Member#: 73405
Bump, any updates about this? Ive seen braided lines on some cars but nobody ever gives any advice on making one or where they get it. Oh yea how would you get the restrictor pill out and then into the new line??
Ctracer911 is offline   Reply With Quote
Old 04-22-2007, 10:55 AM   #22
SloRice
Member#: 44351
2004 Mitsubishi Evo
I'm not cutting my stock line apart to see if there is a restrictor pill in it. I'm just going to try what I posted above. If it works, great, if not, I'll go back to the stock line.
Hopefully should have my motor built and back in the car in a couple weeks.
Old 04-22-2007, 04:30 PM   #23
salt
Member#: 105055
2004 STi [email protected]
GT30R E85 22psi
I just did this mod yesterday. I stripped the 14mm x1.5 ->-6an adapter(aluminum) I will try again on tuesday when I get parts from summit. I would also recommend:
http://store.summitracing.com/partde...5&autoview=sku
instead of http://store.summitracing.com/partde...0&autoview=sku
it is a 45 degree since the straight one hit the perrin rotated mount uppipe. That is how i stripped my fitting.
Now my driveway looks like a murder scene.
salt is offline   Reply With Quote
Old 04-22-2007, 07:00 PM   #24
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
bump... for conclusion
Old 04-22-2007, 09:39 PM   #25
SloRice
Member#: 44351
2004 Mitsubishi Evo
good info salt. Get some pictures if you can.
I hear you on the "murder scene"!
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 04:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 07:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 11:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 11:58 PM
