Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-27-2007, 07:55 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Stage 2 Plus Engine($2799)/sti >bigport< Heads($999)/sti Ej20($1999)/ej22 Forged!
Hey guys,
Got lots of engine goodies!
GRUPPE-S STAGE 2 PLUS SHORT BLOCK
This engine is the ultimate forged short block available without sleeving. The GS650 PLUS starts life as a regular STI shortblock. First we replace the weak hyper-cast stock pistons with custom spec forged units (race coated). Not only are the pistons significantly stronger than the stock units the pistons are substantially lighter too. We then address the connecting rods. The rods are replaced with Helix +2mm forged H-beam rods held together with ARP L-19 bolts. The super-strong forged rods coupled with the best rod bolts available on the market allow for high RPM operation. The crankshaft is then modified with our proprietary techniques creating a crankshaft similar to the $2000 STI race crankshaft used on the WRC cars. The bearings are swapped out in favor of Gruppe-S coated race bearings. This addresses all the common main failure points of the stock STI 2.5 engine – spun bearings, cracked pistons, and damaged rods. FOR MORE INFO: http://www.gruppe-s.com/Subaru/submotors/GS650SB.htm
FEATURES
*Gruppe-S / Wiseco Custom Forged Pistons
*Gruppe-S Detonation Resistant piston coating
*+2mm Long Rod Ratio Design
*Coated High Performance Rod & Crankshaft bearings
*Helix +2mm Forged Connecting Rods with ARP L19 Rodbolts
*Reworked high RPM crankshaft (Nitrided & Cross-Drilled)
*Professionally balanced and assembled
*Capable of up to 650HP Operation
$2799 + core!!!* (ONE AT THIS PRICE)
*Core charge is $500 and will be refunded upon receipt of a good working core (low compression is ok, cracked / scored cylinder walls is not).
EJ22 FULLY FORGED CLOSED DECK SHORT BLOCK!!!
*Helix Forged Connecting Rods
*Closed deck design for high boost applications
$1999 + Shipping (ONE AT THIS PRICE)
NOTE: Picture is a stock picture, if you want pictures of the actual block please e-mail!
STI >BIG PORT< HEADS
Guys, these are the ULTIMATE heads for the EJ20. These ports are bigger than the USDM WRX, and even bigger than the JDM or USDM STI!!! That's right they are bigger than the 2.5 STI heads.
These heads are found on the late model Limited Edition Legacy STI, with its 280HP and 8000RPM engine, these heads feature the latest innovations in performance heads including a high performance valvetrain, shimless buckets, and hollow cored cams. These are twin avcs heads, but we have taken the liberty of deleting the exhaust side AVCS so you can run either single AVCS or none. We recommend STI exhaust cam gears to be used. This setup will rev to 8500RPM!
Excellent for the modified 2.0 car.
These heads are used for about 10,000 miles and need to be redecked and valvelash reset before use.
Cam gears not included
$999 Shipped!! (ONE AT THIS PRICE)
2006 STI EJ20 COMPLETE LONG BLOCK
This engine is pulled from the JDM 2005 Subaru Legacy STI 2.0. This is a GREAT ENGINE. The head ports are HUGE. They are even bigger than the USDM STI head ports. The cams / heads / valvetrain is far superior to the JDM V8 STI engines. The shortblock has forged internals, but it an open deck block.
This is an engine rated at 280 HP and is a single turbo engine (not the twin turbo one of the previous generation). Features include TWIN AVCS, larger duration camshafts (STI "press on lobe" style), better flowing heads, semi-closed deck, and forged internals. This engine is very similar to the JDM STI 2.0 engine. You can opt to leave AVCS unconnected, run a JDM ECU for twin AVCS (you will need the pedal box and gauge cluster for hte DBW t-body) or you can pop out the cams and run WRX or STI cams.
We originally thought this engine had low compression but as it turns out it had some debris on the intake valve on #1. After some carb cleaner compression is now over 90% across the board.
This motor is extremely rare and hard to find (only 400 of these cars produced) and is handbuilt in Japan. Side feed injectors not included (available for $100). Engine is as shown.
$1999 + Shipping!! ONE AT THIS PRICE!
LONG ROD RATIO SETUP KIT
-Custom Wiseco +2mm Pistons
-Aerospace coating to reduce detonation and improve thermal characteristics (same as Cobb)
-Helix +2mm rods with ARP L19
-Longer piston dwell time improves rev range and top-end power
-Gruppe-S Coated Race Bearings
$949 Shipped!!
Please contact us for orders. Thanks!
Gary
[email protected]
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 04-30-2007, 05:32 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 04-30-2007, 09:26 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump For Prices!!
Gruppe-S is offline
Old 05-01-2007, 03:37 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 05-02-2007, 09:06 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
HERE YA GO!
EJ22
Fully Forged
+0.5mm Wiseco Pistons
I Beam ARP 2000 Forged Connecting Rods
Gruppe-S Race bearings
fully balanced, professionaly installed
Gruppe-S is offline
Closed Thread
06 STi stage 2 plus header Fine Line Imports Proven Power Bragging 6 07-29-2009 07:31 PM
exedy stage 2 plus ppgs godforbid67 Transmission (AT/MT) & Driveline 2 05-26-2008 10:14 PM
Gruppe-S lightened crank pulley $89! Stage 2 Plus Engine($2799)/sti bigport Heads Gruppe-S Engine/Power/Exhaust 14 05-07-2007 05:05 PM
Cobb Stage 2 plus stealthback BHawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-14-2005 02:28 AM
cobb stage 2 plus headers WrexFactor36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-05-2004 08:23 AM
