Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 04-30-2007, 01:06 AM   #1
sickmint79
Member#: 54385
Default autocross at college of lake county - grayslake next weekend
http://www.clcautomaniacs.com/module...2007&eventid=3
$30, i think $25 if you are actually going to clc. $25 if you have a miata. lot 5 (the big lot) get there 8:30-9am - wouldn't recommend showing up any later if you want to drive! if you want to watch then it would behoove you to stop there some time before 2... which is probably around when it will end.
sickmint79 is offline   Reply With Quote
Old 04-30-2007, 01:07 AM   #2
sickmint79
Member#: 54385
if you're saying "what's an autocross?" here's one from last year at CLC -
http://video.google.ca/videoplay?doc...0&q=sickmint79
Old 04-30-2007, 01:32 AM   #3
xtian
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
hmm... might have to hit this one up..
xtian is offline   Reply With Quote
Old 04-30-2007, 02:46 PM   #4
Nilesh
Member#: 126987
Are helmets and other saftey equipment required?
Nilesh is offline   Reply With Quote
Old 04-30-2007, 02:54 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
helmets and seat belts are always required
as are jeans and tennis shoes normally
HndaTch627 is offline   Reply With Quote
Old 04-30-2007, 04:31 PM   #6
sickmint79
Member#: 54385
helmets are required; you can use a motorcycle one, they will have some there available to borrow as well.
close toed shoes are required.
shorts are ok. jorts are even better.
you'll have to remove anything loose in your car (change, subs, corpses)
Old 04-30-2007, 04:46 PM   #7
ChrisM623
Member#: 114573
Slow Miata
How many runs do you normally get it?
Usually a good showing of cars?
ChrisM623 is offline   Reply With Quote
Old 04-30-2007, 05:40 PM   #8
misterau
Member#: 108434
05 sti
Dam tank is almost empty
Is there an index for the classes, did not see one on your webpage.
misterau is offline   Reply With Quote
Old 04-30-2007, 06:34 PM   #9
EarlQHan
Member#: 90215
sucks that dd15 is that same day. i'll be there on the 17th.
EarlQHan is online now   Reply With Quote
Old 04-30-2007, 07:18 PM   #10
cramlow82
Member#: 124244
2006 WRX
More than likely I'll be there
cramlow82 is offline   Reply With Quote
Old 04-30-2007, 08:10 PM   #11
fattie92
Member#: 118093
2005 WRX Wagon
Hmm.. Never autocrossed before.. Only Rallycross......Hmmmmm
fattie92 is offline   Reply With Quote
Old 04-30-2007, 08:55 PM   #12
ms3p
Member#: 51596
2007 G35S 6MT
2006 SV650S blue hotness
I think I'm going.
Looks like a fairly short course. (if the same as video)
ms3p is offline   Reply With Quote
Old 04-30-2007, 09:05 PM   #13
fattie92
Member#: 118093
2005 WRX Wagon
...To bad this isnt on dirt...
Old 04-30-2007, 10:50 PM   #14
sickmint79
Member#: 54385
i've had up to 14, the miata club is actually organizing this, they just use the clc club to leverage the lot. i think they are capping at 12 runs this year. typically other clubs (bmw, audi, vw) do 6-8 runs. they have a decent showing of cars but not as many as the other clubs. which i have never fully understood actually. i would expect 35-40 cars.
Old 04-30-2007, 10:51 PM   #15
sickmint79
Member#: 54385
since it's miata club, if you're not in a miata you won't get classed. there is non-miata, i think they actually have some rule like < 2.5 liters is x1, >= is x2, but it's not like scca indexing or anything.
Old 04-30-2007, 11:00 PM   #16
sickmint79
Member#: 54385
adam (blue turbo miata) used to do these a lot, i think he's all about drifting now though! i'm sure you'll see him at dd15.
Old 04-30-2007, 11:01 PM   #17
sickmint79
Member#: 54385
Originally Posted by ms3p View Post
I think I'm going.
typically are ~60ish seconds. i guess scca ones might be longer, or autocrosses they set up on road tracks around here (milwaukee mile, blackhawk farms, autobahn go-kart track - miata club has one coming up here)
Old 05-01-2007, 03:41 PM   #18
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
OMGHi2U
I don't get it.
Scoobyslack1 is offline   Reply With Quote
Old 05-01-2007, 03:51 PM   #19
sickmint79
Member#: 54385
cone course is set up in a parking lot, cars are timed as they run through it
Old 05-01-2007, 04:02 PM   #20
Scoobyslack1
Member#: 2780
junk yards rule!
Wink
but, he didn't hit any cones....was he actually trying to go fast?
Old 05-01-2007, 04:32 PM   #21
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
those cones won't scratch or dent your car, how are you supposed to know when you hit twelve?
Achilles38WRX is offline   Reply With Quote
Old 05-01-2007, 04:45 PM   #22
sickmint79
Member#: 54385
you don't hit cones it's not like gran turismo here's your line... if you hit a cone and knock it over or outside of it's box (no penalty if upright by somewhat inside box) then it adds 2 seconds to your final time.
Old 05-01-2007, 04:47 PM   #23
sickmint79
Member#: 54385
no, car is fine. can put tape on it if you are concerned though. there are 3 run groups. you rest before you run, then you drive/run, then you work. work means you're out with a group of people at some corner station and if someone knocks down a cone, you call it in on a walkie-talkie and your group puts the cone back where it should be. at the end of your run they'll announce your time or put it on a display board/print it out, forgot how they do it but you'll be able to see each run.
Old 05-01-2007, 09:14 PM   #24
cramlow82
Member#: 124244
2006 WRX
Anyone who is even slightly curious about autocrossing should at least try it!!! Come and try it out, and see what your car can really do. It doesn't matter if you are stock or highly modded.
If you are anything like me... you'll be addicted after the first run!!!
Old 05-02-2007, 10:11 AM   #25
Scoobyslack1
Member#: 2780
junk yards rule!
OMGHi2U I am curious, but
could you help me class my car?
Engine & Transmission:
JDM STi rear axles
JDM STi rear mechanical LSD
'93 Legacy turbo 5MT w/STi 20kg diff
2.2L Legacy turbo block
'98 Legacy intake manifold
'04 STi injectors
Bosal WRX downpipe
custom intake
custom intake box/heat shield
custom mid-pipe
custom oil catch can w/breather
custom shifter linkage
Dawes device MBC
EJ20G heads & cams w/Axis valvetrain
Exedy lightweight flywheel
Exedy WRX sport clutch
Flex-a-lite radiator fans
Forge S4 diverter valve
HKS Titanium/Carbon cat back exhaust
hydralic clutch
JDM Greddy FMIC kit
K & N filter
Kartboy short shifter w/shift knob
KOYO aluminum radiator
lightweight crank pully
Redline MTL tranny fluid
STi motor mounts
STi pitch mount
STi side feed injectors
STi helical front diff.
wrapped downpipe w/insulation
Walbro fuel pump
Megan headers/up-pipe
Exterior: Aero, Paint, Trim:
Morette headlights
CF hood
'99 RS front bumper
DIY color matched subaru badge
fog light covers
MRT intake scoop
Primitive Racing STi replica grill
RS front bumper beam (modified)
RS side skirts
Interior: Electronics, Gauges, Controllers:
Autometer EGT gauge
Autometer roll pod gauge pod
Autometer triple gauge pack - oil pressure, volts & water temp
custom grounding kit
custom roll cage
Isspro 15psi boost gauge
Tec 3 ECU
MOMO Start race seats
Sparco Ring steering wheel
Sparco/MOMO steering wheel hub adapter
stripped interior
Miscellaneous:
3" G-Force 5-point racing harnesses
3" Sabelt NOMEX harness pads
fire extinguisher
Suspension & Braking:
Axis metal master rear pads
Cusco camber plates (front)
Cusco front strut tower bar Type ALC 40
DMS 40mm coilovers
EBC Green stuff pads on front
EBC slotted front rotors
FHI 20mm rear anti-sway bar
Goodridge SS brake lines
Hairpin Racing endlinks
Legacy turbo front brakes
Motul 600 brake fluid
MRT adjustable rear lateral links
Power Slot rear rotors
STi rear strut top hat
WRX rear hubs & disk brakes
Wheel & Tire:
'99 RS wheels
Hoosier A3S03
Autocross at College of Lake County 5/20 cramlow82 Mid West Subaru Owners Club Forum -- MWSOC 11 05-19-2007 05:21 PM
Incase there is a "giving away" of Texans tickets for next weekend.... KnightWRX Texas Impreza Club Forum -- TXIC 0 09-03-2006 04:32 PM
Need to borrow a set of wheels and tyres next weekend Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 22 08-10-2004 06:38 PM
Sacramento SCCA Autocross this next weekend (9/21-22) at McClellen AFB Kostamojen Bay Area Impreza Club Forum -- BAIC 4 09-17-2002 03:17 AM
Message Board Statistics All times are GMT -4. The time now is 03:21 PM.
