Old 04-30-2007, 09:01 PM   #701
frostyT
Member#: 145416
2006 vf39 WRX TR
I'm sorry, but I want to ****ing choke someone or something right now (probably the chicken). I just read through soooo much bull**** to find several dead links and no ****ing results! If anyone has a link PLEASE let it fly. (and make sure it works!)
frostyT is offline   Reply With Quote
Old 05-01-2007, 11:43 PM   #702
downshift1
Member#: 15607
I'm not the type
to make angry
the link to the magazine article has been dead for quite a while. What results would you like to know?
downshift1 is offline   Reply With Quote
Old 05-22-2007, 10:11 AM   #703
frostyT
Member#: 145416
2006 vf39 WRX TR
i was just looking for some results. a few dynos or one overlayed would be nice to get the idea of the torque and power curves. do you have a copy of this info?
Old 09-16-2007, 10:12 PM   #704
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
what he said... all this work and the comprehensive results arent posted anywhere any more? i'd like to see then and i'm sure some others would too...
TROLL is offline   Reply With Quote
Old 09-16-2007, 11:32 PM   #705
amazonparrot
Member#: 57070
2003 Impreza WRX
Hybrid 2.5 / Aspen White
all that reading for nothing, is there seriously not a working link or a scan somewhere???
amazonparrot is offline   Reply With Quote
Old 09-17-2007, 12:24 PM   #706
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
the way the shop printed the charts was assinine. I was very unhappy with the article when it was finished.
I'll give you the short version.
All the headers with the exception of the GT Spec Ver.2 made power.
The average increase in spooltime was about 200rpm on the first cold pulls, then non-existant on the second pull. (all headers were wrapped w/ DEI wrap)
The Cusco Header made the most power by 1hp (I consider that Dyno error margin)
The GP Moto header was second making about 17hp more across the pull.
The Fujitsubo came in 3rd with about 12hp across the pull.
The Borla, Gruppe-S, and the rest came in about the same with 5-10hp
Please keep in mind that all headers that did not come with an up-pipe were tested with the Helix up-pipe to be fair against the one piece units.
I'm not mentioning the GT Spec Gen.3 as it has been discontinued and had a catastrophic failure shortly after this test (on RiftsWRX's car).
As for fitment, the Cusco, Borla, Gruppe-s, and Fujitsubo fit the best and were the easiest to install.
The GT Spec, GP Moto were the hardest.
If you have any further questions feel free to pm me.
btw- I hae since tested a set of extrude honed/ cnc port matched, jet hotted stock manifolds. The results were interesting. No loss of spool (cast iron holds heat better), and a gain of about 5hp across the band.
For the money spent ($700) to do the port job right (by hand is impossible to remove as much material as extrud hone) and the cross over pipe and the jet hot coating, I would rather spend the $699 on the GP Moto header, $60 on header wrap and make about 10 more whp.
For all those who complain about losing the "boxer rumble", remember it's teh sound of inneffecency.
Dylan
DS1 Inc.
there ya go.
romanlynch is offline   Reply With Quote
Old 09-17-2007, 01:06 PM   #707
amazonparrot
Member#: 57070
2003 Impreza WRX
thanks Roman, That was a good start at least, do we have some plots to look at perhaps?
Old 09-17-2007, 11:24 PM   #708
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
FWIW, I read this whole thread about 2 years ago, trying to decide if I should buy headers along with uppipe and tbe. IIRC, most lost power early, some gained later. I wasn't impressed with any, but the borla was the best bang for the buck. With rumors of cracking, I'm taking my chances with the ebay headers, which should arrive tomorrow. For $125 shipped, I'll be the guinea pig!
Psipwrd is offline   Reply With Quote
Old 09-17-2007, 11:42 PM   #709
amazonparrot
Member#: 57070
2003 Impreza WRX
Good luck with that :P
Old 09-18-2007, 10:51 AM   #710
MMastro
Member#: 18230
1993 EG Civic/ITR
How does that summary explain this dyno chart for gt spec headers as well as post #45 on page 2??http://www.jscspeed.com/part_picture...eader_dyno.jpg
I was going to pick them up based upon this dyno chart. I don't see how they 'dont make power' at all, they look almost identical design to some of the others out there??
MMastro is offline   Reply With Quote
Old 09-18-2007, 11:00 AM   #711
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
sorry if its been said... But I read through this thing a while ago...
basicly it comes down to EL headers give more power... but kill your growl...
IllNastyImpreza is offline   Reply With Quote
Old 09-18-2007, 11:55 AM   #712
romanlynch
Member#: 126684
02 wrx
and the 4-2-1 give you a little more power on bottom end but not as much top end and vise versa for the 4-1.
Old 11-27-2007, 10:54 AM   #713
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Would there be any different outcome with an aftermarket turbine?
kike_ej20 is offline   Reply With Quote
Old 11-27-2007, 12:09 PM   #714
romanlynch
Member#: 126684
02 wrx
well thats a whole different catagory. a header will complement the gains from a bigger turbo or a turbo that spools faster. basically the header is a bigger pipe then the stock part and it has more gradual bends, its a hell of a lot smoother... it just gives better flow, which in turn helps the turbo spool a little faster
Old 11-27-2007, 09:04 PM   #715
kike_ej20
Member#: 145440
EJ20G 2123cc!!
The thing is that I have a Prova 4-1 header and a fujitsubo(or hks ,not sure) equal length header sitting in my garage. I just wanted to know which one is better or,let me rephrase that....which one gives you more power mid to high range?
Old 11-28-2007, 12:40 PM   #716
romanlynch
Member#: 126684
02 wrx
well as stated above the fuji is about 12hp, if they are both 4-1 then they will give you a little more power mid-top then a 4-2-1 would. either way they are both an improvement over stock.
the el header is 'better' then the unequal length for some reason that escapes me at the moment, maybe someone can fill in the blank
Old 11-28-2007, 01:21 PM   #717
kike_ej20
Member#: 145440
EJ20G 2123cc!!
Is this everywhere in the powerband?
Old 11-28-2007, 02:34 PM   #718
downshift1
Member#: 15607
I'm not the type
to make angry
The Fujitsubo did have a very nice gain almost all the way across the power band.
Old 11-28-2007, 04:43 PM   #719
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Dylan, what are your thoughts on the HKS header?
Better stuff for the dollar? they seem like a nice piece, granted i am sure they are not worth the cost of admission new. Used though...
DoctorNick is offline   Reply With Quote
Old 11-28-2007, 09:09 PM   #720
kike_ej20
Member#: 145440
EJ20G 2123cc!!
equal length?
Old 12-04-2007, 12:28 PM   #721
downshift1
Member#: 15607
I'm not the type
to make angry
kike_ej20- If they aren't i would say very close to equal length.
Dr.Nick- HKS are nice but no better than the Borla/Gruppe-S/etc. that all use the same style and tube diameter.
Dylan
Old 01-29-2008, 09:02 PM   #722
amazonparrot
Member#: 57070
2003 Impreza WRX
since it can't really be seen from the summary post...what is the best Unequal length gainer
Old 01-29-2008, 10:27 PM   #723
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Originally Posted by Chapel View Post
so, after all that, the charts don't link anymore... and the website is dead and there's nothing about it on the new website...
Are you and all the others whining about dead links serious?
You ressurrected a thread started over 4 years ago that hadn't been active for close to 3 years at the time of your posting.
A mod should have locked it for necromancy 9 months ago when you posted.
turboICE is offline   Reply With Quote
Old 01-29-2008, 10:31 PM   #724
amazonparrot
Member#: 57070
2003 Impreza WRX
What you say is true...it is unrealistic to expect this thread to still have live pictures...HOWEVER...where would you have us find a good collection of tested information...since there seems to be a clusterf*ck of information if you try and search for it...
Old 01-29-2008, 10:38 PM   #725
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
here is the link to the magazine article:
http://wrx.grapon.com/exhaust/headers/wrxheadertest.pdf
and here are high-res versions of the charts (colorblind people go find some crayons)
http://wrx.grapon.com/exhaust/headers/Boost2.jpg
http://wrx.grapon.com/exhaust/headers/Boost4.jpg
http://wrx.grapon.com/exhaust/headers/Overall2.jpg
http://wrx.grapon.com/exhaust/headers/Overall4.jpg
And here is another independent test of various exhaust manifolding and headers:
http://forums.nasioc.com/forums/show...ghlight=header
along with his high-res results:
http://wrx.grapon.com/exhaust/header...omparo-SAE.jpg
http://wrx.grapon.com/exhaust/header...ll-Comparo.jpg
Now let this thread die again.
nhluhr is offline   Reply With Quote
looking for an auto shop to do header installation wolfwayne Vancouver Impreza Club Forum -- VIC 16 12-12-2009 08:56 PM
software to do road dyno? rapturem3 Open Source Reflashes 13 08-05-2008 06:02 PM
Header Dyno Comparison not12listen Normally Aspirated Powertrain 8 08-22-2007 12:40 PM
looking to buy headers and flex joint uppipe wrxsti143 Mid Atlantic Impreza Club -- MAIC 0 05-24-2004 01:22 AM
Looking to do a custom trunk install. Need suggestions on where to go? my02wrx Southern California Impreza Club Forum -- SCIC 25 12-05-2003 12:58 PM
