Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 03-12-2007, 07:37 PM   #26
rodger_in_AZ
Member#: 143226
2007 Tribeca
May sound lame, but since the Tribeca is the replacement for my wife's mini-van that died, I would like to see direct replacement headrest monitors for the kids sitting in back. Sure missed being able to turn on a movie for the kids on our first long trip in our Tribeca.
rodger_in_AZ is offline   Reply With Quote
Old 03-12-2007, 08:12 PM   #27
HB_Dad
Member#: 45190
2014 Impreza Sport L
You didn't order a rear entertainment system?
HB_Dad is offline   Reply With Quote
Old 03-13-2007, 03:44 PM   #28
rodger_in_AZ
Member#: 143226
2007 Tribeca
It didn't come off the lot with one. Is it possible to order the factory version and install it? Is the wiring there for the option?
Old 03-13-2007, 07:21 PM   #29
SoDealer
Member#: 67960
You can't add it to a model that doesn't have it. You would have to go aftermarket at this point. Were you not made aware that you could get a Tribeca with a nice fat 9" fold out screen with wireless headsets and a DVD player?
Old 03-14-2007, 01:33 PM   #30
Rburks
Member#: 133971
2007 Tribeca
Default Bra
Our front end is getting creamed driving to Tahoe with all the sand they lay down. The paint seems to chip to the bare metal. And the plastic valence is not taking it too well either. Most chips are on the painted bumber surface, the leading edge of the hood, and the front quarter panels just ahead of the wheels. The rest of the car handles the nasty road grime and grit just fine.
I have looked for a BRA for the B9, but so far no luck. There is the front hood deflector, but that leaves 70% of the problem.
Rburks is offline   Reply With Quote
Old 03-14-2007, 07:08 PM   #31
rodger_in_AZ
Member#: 143226
2007 Tribeca
I purchased a Dealer Add on to replace the need for a bra or bug deflector. I haven't had them put it on yet, but it sounds like a good idea...maybe someone else here can set me straight if I am wrong...its clear 3M material, it goes up the hood about 10 inches and covers everything including the bumper. Not sure if every Tribeca comes with it, but mine came with the material already on the rear doors where they flare out. Its a clear sticker.
I have had bra's on my other vehicles and they scratch the heck out of the paint once dirt get under it and the bug deflector I have on my truck really alters the wind flow and I get a lot of wind noise with it on. take it off and the noise went away. Hopefully the 3M stuff will work out well...I am a little worried about it yellowing after a few years in the AZ sun, but I guess we'll see when and if it ever does.
It may be something you want to look into.
Old 03-15-2007, 10:45 AM   #32
Rburks
Member#: 133971
2007 Tribeca
That is a good solution. But expensive. I think its around $300. If you do opt for this when the car is BRAND NEW with no chips. Since we leased our car I opted for the Newport Pearl Blue (paint code 64z) touch-up paint from Subaru for $10 vs the 3M for $300. I was willing to spend about $60-$80, but after that - LET THE STONES FLY BABY! I got war paint!
BTW - Good luck finding Subabru paint colors anywhere other than Subaru. I went to multiple stores and noone had them.
Old 03-28-2007, 05:54 AM   #33
keepclam
Member#: 120244
2006 Legacy SE Sedan
2006 Pilot EX-L 4WD
I've seen the Stoneguard/3M/etc clear plastic coatings work well for preventing this type of damage. Wish I'd gone ahead & put them on my '06 OB when it was new - I've got a "sandblasted" bumper, too.
keepclam is offline   Reply With Quote
Old 03-30-2007, 02:40 PM   #34
johnjb
Member#: 144867
Default Limited Subaru grill
I want the optional Limited Subaru grill
johnjb is offline   Reply With Quote
Old 04-02-2007, 11:26 AM   #35
SGT Goltz
Member#: 130716
2006 Tribeca
Just wanted to keep everyone updated on my proggress. Currently I am working on three things for my Tribeca. I have some springs for a legacy that the delear here thinks will fit and lower the car 1.5 inches and will retain the stock ride quality, I also have an exhaust intended for the Leagacy that I am in the process of getting put on. Ran into a problome with the rear Y pipe not being made right but should have that fixed soon. One thing I did do already was install a Sub in the back and I can say that that by its self makes a huge differance in the overall sound of the Stereo system. My front doorpanels are almost done and will house the before mentioned 8", 4" and tweeter. All MB quart Q" these will be powered by an A/D/S Amp so it should sound about as good as one can excpect for doing a low line converter off the factory deck. Once I get this all done I will be working on doing away with the factory stereo compleatly. What I'm going to do is find a aftermarket head unit that will support an exsternal screen and also support a wired remote and retain the stock steering wheel controls and possibly the stock upper display. If I can't retain the stock upper display I'm going to get a differant one and do a smaller display in the same place as the factory unit as with the custom adapter that I'm going to be making it should be equal to a double din. Then I woll just put a scrren in the top for a DVD. Everything I mentioned will be all custom done as I have found nothing that is made for our cars yet. I'm also working on a custom grill that will get rid of the chrome compleatly. should have that done some time this week. If my grill stock from grillguy.com shows up. As this stuff gets done I will post picks.
SGT Goltz is offline   Reply With Quote
Old 04-02-2007, 06:52 PM   #36
hawker800mech
Member#: 53923
2013 Legacy Limited
Originally Posted by SGT Goltz View Post
I have some springs for a legacy that the delear here thinks will fit and lower the car 1.5 inches and will retain the stock ride quality.
I was thinking of that, too. I wonder what the spring rates are between the Legacy and Tribeca. The Tribeca is about 1000 lbs heavier. But I use to think my wifes Legacy 2.5i road soft. Compaired to the Tribeca it rides firm. i'll be very interested to see how that goes.
hawker800mech is offline   Reply With Quote
Old 04-02-2007, 10:11 PM   #37
WRXURV8
Member#: 14848
2007 Tribeca
TS w/ 20" OZ's
I am trading in my '06 OBXT for an '07 Tribeca. Picking it up this Saturday and already have these coming the day I get it:
They will be rapped in Yokohama Spec-X's (255/45/20)
WRXURV8 is offline   Reply With Quote
Old 04-02-2007, 10:36 PM   #38
hawker800mech
Member#: 53923
2013 Legacy Limited
Post a pic when you get them on. I was looking at those, too.
Old 04-03-2007, 11:25 AM   #39
SGT Goltz
Member#: 130716
2006 Tribeca
Sense mine is black I'm going to go with a black with chrome lip.
Old 04-04-2007, 10:52 PM   #40
packetmangler
Member#: 129931
SGT Goltz,
Mind sharing your experience/how-to when you added a sub in the back? I have an amp and some 12s that are sitting around and would love to put them in the back.
Thanks,
PM
packetmangler is offline   Reply With Quote
Old 04-06-2007, 10:54 AM   #41
SGT Goltz
Member#: 130716
2006 Tribeca
Originally Posted by packetmangler View Post
SGT Goltz,
Thanks,
PM
I used an MB Quart pwd 254 I think is the model number. I wanted to make it flush with the allready exesting floor so I made the box myself I was going to finnish it up last night but due to the fact that its 33 degree's outside I didn't get it done. I used a low/line converter and taped into the factory deck. Although If I could find out where the subout on these things are I would rather of taped into that. But my suspesion is mine that didn't come with it from the factory didn't have the wireing for it. If you remove the back storage box you will have only about 7" of height to work with so not a lot of room to work with. I'm going to be fibergalsing the bottom of the box soon to get the height of the box down. I made it as low as I could and still clear the sub. And I'm still a good inch too high. I also purchesed some dark gray carpet that matches the rest of the car to re-cover the rear. As the factory tan carpet gets dirty if you look at it wrong. I will take some picks tonight when I get home. And post them.
P.S Anyone know anyone that has laser cutter that can cut some plexi for me? Looking to do it flush with the floor but need it vented some how so want to cut some simple designs out of it and doing it by hand isn't working out to well
Old 04-07-2007, 11:21 AM   #42
WRXURV8
Member#: 14848
2007 Tribeca
TS w/ 20" OZ's
I picked up my Tribeca.....got my OZ's on.....and I all I can say is wow. The appearance of the truck is incredible now....and the ride quality is somehow......better than with the Stock Tires! I live in downtown Philly where the roads stink.....and this truck is great! I will post pics as soon as I can figure out how to.
Old 04-07-2007, 11:51 AM   #43
hawker800mech
Member#: 53923
2013 Legacy Limited
Sign up at photobucket.com or similar site. It's free.
Old 04-16-2007, 12:21 PM   #44
DizzyV6P
Member#: 73193
2004 Sienna AWD Ltd
07 B9 Tribeca Ltd Nav/Dvd
Anyone find a front brush guard for the Tribeca yet? LOL. We get a lot of fog between my house and our mountian chalet so some extra fog lights would help a LOT!
DizzyV6P is offline   Reply With Quote
Old 04-16-2007, 08:04 PM   #45
DubyaSTi
Member#: 86763
2009 STI
I actually saw a Tribeca locally with a brush guard on it. However, it was the type that only covers only the front section of the bumper, similar to the picture below. Also, it didn't have the bar going accross the middle to mount any lights to. It was more of a dress up piece. Wish I had taken a picture of it.
DubyaSTi is offline   Reply With Quote
Old 04-17-2007, 05:08 PM   #46
HB_Dad
Member#: 45190
I want the '08 grille, but unfortunetely, that'd require major bodywork to do...
Old 04-22-2007, 10:48 PM   #47
DizzyV6P
Member#: 73193
2004 Sienna AWD Ltd
I contacted Romik and they informed me that they carry the side-steps and bull guard for the Tribeca's. I'll post up more as soon as I get pics and more info.
Their products can be seen at www.romik-usa.com
I'm interested in their bull guard w/ skid plate product
Old 05-05-2007, 04:00 AM   #48
HB_Dad
Member#: 45190
Here's a pic of their products. Answers both of your posts I think. I really dig both accessories, but I fear the step may block the puddle lights. Anyone know for sure?
Old 05-05-2007, 02:20 PM   #49
packetmangler
Member#: 129931
Thanks for the reply SGT Goltz.
I'll probably do the LOC thing as well since getting to the rear sub is so easy and it probably won't make much difference if it's not used.
Now how would I punch through the firewall to run some large gauge wire for the amp? Anyone have any suggestions? I took a look from the engine bay and the interior but nothing pops out at me yet.
thanks,
PM
Old 05-05-2007, 03:34 PM   #50
njjuliano
Member#: 132041
I like the side steps but swayed away from the bull bar. I'd like it either a bit lower and/or wider. That pic certainly makes it look great, but its a bit deceiving. It only comes in stainless right now, and it doesnt look like a perfect match with the side steps.
YMMV.
If you go to Romik, the main site, not USA site, you can see a different angle on the bull bar for the Tribeca.
Cant link yet, since I have very limited posting history.
njjuliano is offline   Reply With Quote
Did you, or will you 'settle down' where you grew up? Kiwi Off-Topic 89 09-13-2007 12:34 PM
So what will you or your mama be cooking for Thanksgiving this year? imprezton Off-Topic 49 11-08-2005 05:16 PM
What colors are available or will be? ciper Baja Forum 6 12-13-2002 09:09 AM
What aftermarket seats are you using (pics please) Carlitos Interior & Exterior Modification 8 01-26-2002 11:16 PM
WRX Owners: What aftermarket clutch are you using?? subywan-kenobi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2001 11:36 PM
