Old 04-02-2007, 12:08 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Car Storage FAQ: Read if you are storing your car for more than 30 days
The following advice is based on car storage of more than 30 days. While you may use some of this advice for short storage periods, most of it is only applicable for longer term storage.
Gas: You should store your vehicle with a full tank. Extra credit for using a gas stabilizer prior to the fill-up. Reason for full vs. empty is a full tank allows less moisture into your system. Alternately you could totally drain your tank, but this is a huge hassle for 99% of people.
Oil: Change it just before you put your car into storage.
Other fluids: All other fluids should be topped off and should be fine. If your car will experience cold weather: washer fluid should be the cold weather variety so as to not freeze and split your tank. Check the bottle specifications for freezing data as most of the regular "blue" washer fluid is not rated for cold weather. For STI owners, the intercooler waterspray tank should be filled 1/2 way so the freezing process will not crack the tank. Filling intercooler waterspray tank with anything other than water is NOT necessary.
Insurance: Call your insurance company. Many insurance companies will allow you do reduce coverage for long periods of storage and each company has their own ins and outs of doing so. Contact them WELL before the storage period as they may have to verify odometer readings, etc. BE SURE to call them the day you plan on taking the car out of storage as well.
State requirements: Make sure you have a current state inspection, registration, tags, etc. for the duration. This is especially critical for outside storage as many localities will tow with no warning for expired tags, inspection, etc. If someone is watching your vehicle, you may consider a limited power of attorney for them to perform these actions on your behalf if you are unable to do so while you are away. Talk to a lawyer about this or search online for power of attorney forms. Since it is limited, you can specifiy exactly what the person can do for you and have no fear that they will sell your car out from under you.
Tires: Tires stored off the vehicle should be stacked on their sides. Have a portable air compressor ready as the tires will probably need inflation when you return to your vehicle. Removing the tires or placing your car on jackstands to prevent flatspotting is a myth carried over from older tire generations. Though you may see some tire deformation, proper inflation and running them will restore them in short order.
Mice/Rodent protection: Cover all points of entry. Windows and doors should be closed. Tailpipe should be covered to a fair the well with multiple layers of plastic. Intakes (depending on the brand/type) should also be covered in the same manner. Also look over your vehicle for any egress points that may need to be covered as well. Get underneath your car with a flashlight and check it out. Any opening larger than a dime is an invitation for critters to nest. Fender liners are famous for holes/ill fitment that allows infestation.
Interior protection: You are mainly concerned about moisture and odor. Many companies sell dessicant packs and/or charcoal packs for cars. You could even do it on the cheap tip with nice aluminum foil tray or two full of regular (NOT Match Light) charcoal. Dessicant packs can absorb excess moisture and if your vehicle is monitored during the storage period, many of them can be refreshed by oven baking the packs. The baking removes the retained moisture and many of the dessicant packs will change from (for example) pink, which is moist, to blue, which is dry. This step is not a terribly important point, but something to consider.
Exterior protection: Full detail job with a premium, long life wax. Long life is the key here as you are looking for a lasting protection, so consider one of the synthetic waxes like Nu Finish. While not the "best" wax, Nu Finish will last forever and length is more important than shine. Consider consulting www.autopia.org for other long life waxes as Nu Finish is just one wax to consider.
Car cover: That's a toughy. If your vehicle is stored indoors, most would say a QUALITY cover is a good idea. By quality, we are talking about a car cover that is designed to protect the finish of your car where it meets the cover as well as protection against UV rays and bird bombs. www.calcarcover.com is arguable THE source for quality covers and their catalog also contains other products for long term storage as well. If anything, you should sign up for their catalog anyway as it's really killer. if your vehicle is stored outdoors, most would say a cover is not a good idea. Think about it.....6 months or a year of the cover flapping against your paint....think it through....it that better than having your car covered in pollen/dirt/bird bombs?
Vehicle Preps:
a. Your battery should be removed. PLAN ON it being dead even if you remove it and place it on a dry, non-conductive surface. Plan ahead and have a charger of some type, another vehicle for jump-starting, or a fresh battery. Your battery WILL be dead no matter what precaution you take and the OEM battery is famous for not returning from the dead, so keep this in mind. Plug in type trickle chargers are another option, but it is generally easier to do one of the above options.
Supervised storage: If you have someone that will be looking after your car, having them start it once a month or every two weeks is another option. It should be run for at least 10 minutes. 10 minutes is enough time for it to come up to temperature and have all the water in the oil burn off. If the vehicle is parked, they should drive it for 5-10 miles or so. As to whether it's better to leave the vehicle be or to have someone drive it once or twice a month....that's a judgement call for you as there is no set answer as many people have used both methods successfully.
Garage/storage unit storage: Definately the best way to go.
Outside storage: Worst case scenario. The keys to look for here are:
a. Will it be in a safe place?
b. If someone is looking after it/driving it occasionally, the battery should be left in and they should keep a careful eye on tire inflation and keep the tank topped off. MAKE SURE the person knows you car takes premium.
c. Make sure the person (if applicable) who drives your vehicle is kosher. Your cousin Jimmy whose insurance lapsed due to not paying his premium by two days and has a suspended license is NOT a good candidate. Your ideal candidate has a valid license (check it), valid insurance (check it), and you both have a WRITTEN contract stating the uses of the car. If your mother T-bones a bus load of nuns, a written contract could save you and/or your insurance company from a horrendous lawsuit. Odds are nothing will happen, but cover your ass.
d. Limited power of attorney for the supervisory person. This will allow them to get state inspections, new plates, maintenance, etc. on your behalf. Not for everyone, but with a limited power of attorney, it will allow that person to perform actions on your behalf that you specify.
e. Will you use a car cover or not? As stated above, that's a tough call and one for you to think about.
Off storage start up: Remove the car cover if applicable. You will have to put the tires back on and check for proper inflation or lower the vehicle and check for proper inflation. Remove any protection on your tailpipe/intake and any charcoal/dessicant packs from the interior. Replace the battery and have it charge on a charger or have a new one installed. If you are jumping an old battery, put the cables on for a good 10-15 minutes before attempting a jump start. If all else fails and you need to "pop the clutch", it's usually easier to do so in 3rd or 4th gear vs. 1st gear. Popping the clutch should be your LAST resort for getting the car started. Once started, easily take off. You might very well hear/feel some jarring pops or bangs like you ran over a piece of concrete in the road. This is one or all of your differentials unseizing and breaking free, so expect some starting off unpleasantness. Now drive your vehicle for a good 15 minutes in a very Christian fashion. Act like it's a Kia Sephia, no boost, no mad power runs. After 15 minutes and everything comes up to temperature, you can wail on it once again. In theory, you should then be good to go. For extra points you may get an immediate oil change though that's not really necessary.
Old 04-02-2007, 12:09 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Hope this covers all the main points. I'm in the Navy so I've been there and done that with car storage.
<-----car goes into 6 month storage in August
Old 04-02-2007, 01:01 PM   #3
BlackfeetVI
Member#: 40567
RIP Worcester 6
St Florian protect us all
Teh Bomber does it again!
BlackfeetVI is offline   Reply With Quote
Old 04-02-2007, 06:35 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Tire flatspotting is not much of a problem with modern tires. In any case it is a temporary effect. It is most noticable on nylon cord tires which are typically not sold much any more.
If a tire flat spots you only need to drive the car at moderate speeds for a few miles to warm the tire up and the flat spot will go away of its own accord.
Label this one as a minor nusince issue. I am also not that fond of putting a car on jack stands for a couple of reasons. It hangs the suspension components on the bushings in un-natural ways. I've parked many cars for time spans of years with no problem.
The second issue for putting a car on jack stands is if you need to move it in a hurry ( house is on fire, flooding etc. you can't!) Judge your own risk on this issue based on location and conditions where you are storing the car.
I usually inflate the tires to about +5 - +8 psi over normal pressure to be sure the bead stays seated if they develop a slow leak.
Infestation by rodents is greatly increased if the car is parked where tall grass or weeds might provide access ladders up into the engine compartment that otherwise would be very difficult for the rodents.
Racers frequently block tail pipes / headers by finding the appropriate diameter rubber ball, drilling a hole in it and threading a length of rope throught he hole and tieing a knot.
On the pre-storage oil change, and addition of fuel stabilizer, do it a couple days before the car is stored, so the new oil gets pumped through the engine a bit. Lots of anti-corrosion additives don't do you any good setting in the oil pan you want to get them coated onto the parts that are most likely to have most of the oil drain off. Likewise the fuel stabilizer needs to mix and get into the full fuel system.
Also good idea to leave a note on the dash board or drivers seat telling the things that must be done to restart the car, such as reconnect the battery, unplug the tail pipe, remove aluminum foil cover over airfilter or what ever.
They now make small solar battery trickle chargers which help keep a battery alive. If a battery is discharged it is subject to freeze damage so it is useful to keep it on some sort of charging cycle. (even a once every month trickle charge is very helpful). Lead acid batteries can live for 10-15 years if kept fully charged with a low current trickle charger that does not cook the water out of them. The battery does no need to end up damaged or dead. If you let it fully discharge due to its normal slow loss of charge, due to both chemical processes and low current loads like the clock and such that always draw very small amounts of current, it will kill the battery due to sulfation. It is the long term discharge that kills the battery, rather than the battery is discharged because it is dead.
Also make sure dome lights etc. are shut off, as folks have a tendency to bump switches and leave car doors ajar on stored cars. Removing the bulb in the dome light works to prevent it being left on by accident when someone gets in the car to look for that spare snow scraper, or gets in the glove box and does not fully close it if it is one that has a light.
As far as the clutch siezing to the flywheel I have never seen or heard of that happening, and would not think it a good idea to keep the hydraulic clutch system under constanstant pressure holding the clutch off the flywheel and pressure plate.
Larry
hotrod is offline   Reply With Quote
Old 04-02-2007, 09:53 PM   #5
NLspiked02
Member#: 127345
2004 Impreza WRX STi
WRB/Bronze BBS Rims
yet again the unabomber stricks! very good information and could only take a few hours to do.
NLspiked02 is offline   Reply With Quote
Old 04-03-2007, 12:06 PM   #6
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Great info on tire storage:
http://www.yokohamatire.com/pdf/tsb-112102.pdf
My vehicle is stored for 4-5 months every winter. I leave the wheels/tires on the car and use the over inflation method. So far, no problems.
jac04 is offline   Reply With Quote
Old 05-14-2007, 01:51 AM   #7
SplatZ400
Member#: 84377
2011 335d
good stuff wish this was out before i left.
SplatZ400 is offline   Reply With Quote
Old 05-23-2007, 07:37 AM   #8
TheConekillGirl
Member#: 97438
2013 BRZ
This is great!! I am currently storing my boyfriends car right now while he in in Iraq. It looks like so far i have covered my bases with what youve recommended!!
BTW I printed out all of your info threads and sent it to him over there...I think he should know quite a bit when he comes home!
TheConekillGirl is offline   Reply With Quote
Old 05-23-2007, 08:02 AM   #9
SplatZ400
Member#: 84377
2011 335d
He should also have access out here if he doesnt tell him to look me up and call me
Old 05-23-2007, 08:47 AM   #10
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
I just got a clear image in my mind of some poor mouse getting shot out of a tail pipe
Qcanfixit is offline   Reply With Quote
Old 05-23-2007, 11:56 AM   #11
TheConekillGirl
Member#: 97438
2013 BRZ
He is actually in a very remote location as well as in the infantry and they are barely able to get on the computer.
but thanks for asking!
Old 05-23-2007, 01:25 PM   #12
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Removing the battery (or just disconnecting it) is a good idea but I can tell you from personal experience that even 2 months is not guaranteed to kill it. We left our 1995 Legacy parked for a month out in the open twice with no special care at all and it fired right up no problem. We also once left a 1990ish Mustang parked for 2 months out in the open with no special care and it also fired up and drove with no problems at all. The only problem we had is once the Legacy's rotors got very rusty and had to be resurfaced (AFAIK the only solution to this is to have someone drive it regularly).
Mike Wevrick is offline   Reply With Quote
Old 05-23-2007, 10:33 PM   #13
Mike Wevrick
Member#: 24654
1957 Taggart Comet
What's the logic behind this? I have seen some places store them upright.
Old 05-24-2007, 12:13 AM   #14
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The battery advice is based on worst case scenario, I've had 6 month batteries fire up, but seen 2 week old one be dead as a door-nail. The tire advice is based on what Luke posted awhile back for proper tire storage. Something...something....no "thump, thump, thump" while the "flatspots" get worked out of your tires as you go down the road....I don't know.
Old 05-24-2007, 07:58 AM   #15
jac04
Member#: 49895
09 Forester
The Yokohama tech bulletin that I linked states "As a rule, tires should be stored in an upright position to prevent distortion or disfiguration and to make mounting work easier."
Old 05-24-2007, 08:32 AM   #16
z&cobb
Member#: 12344
2002 2JC
blue
Is that for tires only? Shouldn't tires on wheels be stacked?
z&cobb is offline   Reply With Quote
Old 05-24-2007, 09:23 AM   #17
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Sounds like that applies more to unmounted tires. The pressure in a mounted tire should prevent distortion no matter how they are stored.
Old 05-24-2007, 09:26 AM   #18
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Agree, but you initially said "Your battery WILL be dead." It might or it might not. Also, why remove it instead of just disconnecting it?
Old 05-24-2007, 04:14 PM   #19
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I agree about the battery....BUT always plan on a dead battery and flat tires during storage....you might not get laid on friday night, but you always plan on it with a condom. As to removal or not, either can be done, but removal ensures there is no accidental contact. Mind you, none of this advice is set in stone, it's for people who have never done this before. I've stored or helped store probably 100 cars throughout my 18 years in the Navy for 3 days to 6 months...I know what you can and cannot and should and should not do, this is nothing more than a guide and there is room for error, but this pretty much covers it.
Old 05-25-2007, 12:07 AM   #20
Menik
Member#: 105966
2005 Cobb Stg2 STi
w/ WRX Wing & Roof Vent!
Armageddon!
...sorry, couldn't resist.
Menik is offline   Reply With Quote
Old 05-25-2007, 10:03 AM   #21
linsavy
Member#: 11620
1997 GF4-STiV3 clone
A Battery Tender or C-Tech battery tender will be a good investment if you plan on frequently storing the car. They will pay for themselves quickly in terms of not needing to replace batteries and for convenience. The C-tech can even bring a sulfated battery back from the dead in some cases.
A fully charged battery will live a lot longer than one that is charged and allowed to run flat.
Don't use a cheapo trickle charger for an extended time as it may catch fire, explode your battery or at least over-charge the battery and kill it.
linsavy is offline   Reply With Quote
Old 06-14-2007, 01:46 PM   #22
Psybin
Member#: 112719
2014 Evolution X GSR
06 STI & 05 9-2X = Sold
Dude this is great, thank you. Iíll be storing mine near the end of the year. 2nd deployment, weeee.
Psybin is offline   Reply With Quote
Old 06-14-2007, 08:58 PM   #23
Turbozn2006
Member#: 127991
2006 WRX Wagon
A brand new battery that has never had a load on has a storage life of about 3 months. After that they will start to discharge.
Turbozn2006 is offline   Reply With Quote
Old 09-26-2007, 12:28 AM   #24
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Should you add fuel additive if you are going to start the vehicle once a week or every two weeks anyways?
Dirtyhobo010 is offline   Reply With Quote
Old 09-26-2007, 12:35 AM   #25
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
The rodent thing is real! I saw it first hand in my old STi when I went to Iraq in 05. I hade her on jack stands, but that didnt stop them. They made a nest in my passanger seat!!! Little bastards!!!
rek888v2 is offline   Reply With Quote
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 82 10-19-2015 06:42 AM
