Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 10-10-2005, 02:20 AM   #51
gza
Member#: 84900
Too many shades of white
Originally Posted by Mike Wevrick
Yeah; I double-clutch my 1-2 shifts the first few times after starting car; more in the winter.
I also double-clutch my 1->2 shifts, those are the most tricky (for me) to get smooth...
gza is offline   Reply With Quote
Old 10-10-2005, 04:09 AM   #52
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by Damn Yankee
sounds like you're rev-matching wrong, unless you're talking about not using your clutch at all.
when I rev-match downshift it's clutch in with revs up as shifter goes into new gear, clutch out. if done right you shouldn't even feel the shift, you should just be at a higher rpm....works perfectly on my motorcycle too.
this is my method of downshifting.
clutch in
select neutral
clutch out
blip throttle
clutch in select lower gear
clutch out.
i am def. rev-matching and def. double clutching the right way. like i said it doesn't take anymore time to do than a simple rev-match. in fact, this is a much better way of rev-matching since when you rev-match without double clutching you're just increasing the engine revs. with my way of downshifting you rev the engine AND the input shaft which means less stress while engaging the next lower gears. which means the synchros don't have to do squat. that is a good thing.
MRF582 is offline   Reply With Quote
Old 10-16-2005, 09:48 PM   #53
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
http://www.teamsmr.com/movies/Footbox%20Small.wmv
^- someone using double clutching and heel toe like they invented it Good one for the n00bs to see
john
Butt Dyno is offline   Reply With Quote
Old 12-09-2005, 03:22 PM   #54
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
I know. New post in old thread. Double clutchers -- Do not forget about the clutch release bearing, which does double duty in DC and does not last forever.
PJC1909 is offline   Reply With Quote
Old 01-14-2006, 06:38 PM   #55
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
i think the heel toe section is wrong! well the animated part at least.
blip the throttle while in neutral then put in lower gear takes along. i think doing it that way seems pointless i dont see the point in reving it while neutral . My way of heel toe, let say im in 3rd and i want to go to 2nd for a turn so i brake then i push the clutch in then put in 2nd and blip throttle and let go of clutch.
1. brake, then clutch in
2. move to lower gear
3. blip the throttle with your heel, while holding in the clutch (the foot is still on the brake)
4. then i release clutch and the brake. yadadada then accel out
HighRevimpreza is offline   Reply With Quote
Old 01-26-2006, 05:14 PM   #56
matt30
Member#: 97330
2003 WRX
How do I shift without the thump?
You should wait until the point where you are no longer pressed into the back of your seat to let the clutch out on your second gear shift. As to the actual application of this technique:
1. You are in first gear, taking it to your favorite shift RPM.
2. Once you reach this RPM, let off the gas pedal and depress the clutch.
3. Shift into second. (Items 2 & 3 can be done quickly)
4. "The wait". Judge it based on your body's movement. Visualize your pelvis as the axis....when the rearward pressure of acceleration leaves your body and you feel as if you can naturally lean forward at the waist.....this is the shift point.
5. Release the clutch.
This is a shifting technique that requires some practice due to variances from car to car. Yes, it's slower, but better for your rear differential and transmission in the long run.
I think this could use some editing.
The imput shaft when disconnected from the driveline and engine rotates at about the same speed as the flywheel.
So if you want a smooth shift all you need to do is put light pressure on the gear shift untill it 'falls' into gear then lift up the clutch at a quick pace (less than a second) with no jerk or clunk.
For example, you're in second gear. For a smooth shift put your foot on the clutch and take the car out of gear. Take the gear lever, don't jam it into the next gate, and put light pressure to get it into 3rd. When the revs match the shifter will seem to almost pull itself into gear. At that time you can lift your foot off the clutch quickly.
Much easier than waiting for that point when the accleration of the car has slowed.
matt30 is offline   Reply With Quote
Old 01-26-2006, 06:47 PM   #57
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
Double clutching while rev matching saves your synchros from a bit of wear...the way you do it does not.
While the way you do it is certainly faster on the track, if you have the time during the daily commute to double clutch on the downshift...why not?
eltrouble is offline   Reply With Quote
Old 02-15-2006, 12:06 PM   #58
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
I just read this post and I must say it is VERY VERY informative. Some information I had been looking for about our transmission I just found . Thanks Unabomber you're the best.
akira02rex is offline   Reply With Quote
Old 04-05-2006, 03:12 PM   #59
dj_booduh
Member#: 70861
2005 Scoobie WRX
Unabomber... Will you be my friend???
dj_booduh is offline   Reply With Quote
Old 05-06-2006, 10:03 AM   #60
EJ25maxboost
Member#: 107441
very very helpful! Thanks!
EJ25maxboost is offline   Reply With Quote
Old 05-06-2006, 05:32 PM   #61
AudiTTkiller
Member#: 72875
2004 W R X
platinum silver metallic
what should be a sticky is the neccessity to get a kartboy short shift and bushings. words cant express how much better the car shifts.
AudiTTkiller is offline   Reply With Quote
Old 01-18-2007, 12:54 PM   #62
jjbehren
Member#: 136991
2004 WRX Wagon
Very good read. I'll use some of this to teach my wife to drive my car. Thanks.
jjbehren is offline   Reply With Quote
Old 01-18-2007, 01:12 PM   #63
evolsuby
Member#: 132609
2004 WRX
A very good FAQ
evolsuby is offline   Reply With Quote
Old 02-20-2007, 09:36 AM   #64
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
This answered a lot of questions. Thanks for the thread.
100_Percent_Juice is offline   Reply With Quote
Old 02-20-2007, 09:53 AM   #65
Rexer06
Member#: 125065
2006 WRX
How do I shift without the thump? You should wait until the point where you are no longer pressed into the back of your seat to let the clutch out on your second gear shift. As to the actual application of this technique:
another mtd works for me better:
Steps 1,2 and 3 are the same as above. Without having to wait (step 4 above), I would quickly release the clutch until just before the 'biting' point. Then I would gradually release the clutch until fully. During the process of releasing the clutch, i would gradually step on the gas. If done correctly, there will be no rear diff klunk no matter slow the car is or how low the engine revs are.
This method is very similar to moving from stationary in 1st gear and it works for all gears.
my 2 cents
Rexer06 is offline   Reply With Quote
Old 02-21-2007, 10:13 PM   #66
1weirdsuby
Member#: 141311
09 STI
Blubaru
awesome advice i'll take it easy on my shifrting now...driving a fwd car will do this to you
1weirdsuby is offline   Reply With Quote
Old 03-28-2007, 09:06 PM   #67
Silver OX
Member#: 144682
Great thread... very informative. While I'm not new to driving MTs, I just bought my first one. This really helps me understand the idiosyncracies of the Subie trans as opposed to the Audis and VWs that I'm used to driving.
Now I just need to fix my 1st gear Synchros so I don't have to drive it like an old REX. (long story...)
Silver OX is offline   Reply With Quote
Old 04-06-2007, 01:50 PM   #68
adamwrx ny
Member#: 142381
2002 Impreza WRX
Thanks! Very helpful. I have some practicing to do.
adamwrx ny is offline   Reply With Quote
Old 06-06-2007, 03:10 AM   #69
Warguy
Member#: 149110
2006 WRX TR
i have never heard of the heal/toe thing but i always downshift that was really helpful, but i dont quite understand what double clutching is used for, can anyone elaborate?
Warguy is offline   Reply With Quote
Old 06-06-2007, 08:50 AM   #70
evohuntinwrx
Member#: 141601
2013 Audi A5
Ibis White
I think for some trannies its better to double clutch to downshift quicker? im not totally sure tho someone help me out.
evohuntinwrx is offline   Reply With Quote
Old 07-15-2007, 04:46 AM   #71
xUNOx
Member#: 154020
2005 STI
Do you have to release the clutch while double clutching? I don't when I do it. Is that bad?
xUNOx is offline   Reply With Quote
Old 07-15-2007, 08:59 PM   #72
wrx4meinnd
Member#: 153745
2006 wrx limited
thankyou for anwsering every question i was afraid to ask
wrx4meinnd is offline   Reply With Quote
Old 08-06-2007, 03:29 AM   #73
ETown
Member#: 154170
2007 WRx Stg II
Good Granny Shifting...
awsome thread, i read it for an hour. cant wait to hit the road tomorrow!
ETown is offline   Reply With Quote
Old 10-10-2007, 12:56 AM   #74
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
+10 beautiful descriptions couldn't put it much better myself i double clutch and heel toe in the every day daily driver setting, that way its second nature not to mention a clutch is cheaper than a tranny
feint05 is offline   Reply With Quote
Old 10-17-2007, 03:14 AM   #75
supafastR
Member#: 161335
Default Wear and Tear
So, for the double clutch move, isn't that going to eventually put alot more wear on the throw-out bearing and maybe even the clutch disc itself? Someone asked above and I didn't see an answer yet...
SupafastR
supafastR is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 08:49 AM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 82 10-19-2015 07:42 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-03-2015 12:25 AM
Subaru FAQ: Read if you are a new Subaru owner! Unabomber Newbies & FAQs 41 10-11-2013 04:04 AM
