Old 05-24-2005, 03:45 PM   #1
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
Default a/c problems...
anyone else having/had problems with their a/c? i heard that it was a real problem for subaru... my a/c just died on thursday, she's going to the shop on wednesday hopefully. it actually gets hotter when i hit the a/c button!
cliffhanger is offline   Reply With Quote
Old 05-24-2005, 05:05 PM   #2
opimax
Member#: 85940
I asked the Subaru rep about the A/C today , nothing unusual he said , also the brakes , should last 40k, acted like the he never heard the A/C was a problem....
Mark
opimax is offline   Reply With Quote
Old 05-24-2005, 05:30 PM   #3
2003Baja
Member#: 52985
only problem I had was after removing the whole DIN and disconnecting the cable for the A/C I didnt reposition it correctly so even though I set it for cold, it was more or less in the middle.
Fault was on me.
2003Baja is offline   Reply With Quote
Old 05-24-2005, 05:35 PM   #4
mjalex007
Member#: 66022
2005 Baja Turbo
Only problem here in New England is that we haven't had a chance to find out whether there is anything wrong with the A/C. Man, the weather has sucked since last November...
mjalex007 is offline   Reply With Quote
Old 05-24-2005, 06:46 PM   #5
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
?The New England Bajas came with AC?
getting pretty sick of this cold rain. Can't remember when I saw the sun.
Chris N is offline   Reply With Quote
Old 05-24-2005, 07:56 PM   #6
cliffhanger
Member#: 80446
2005 5spd Baja-T
Fault was on me.
i removed the din too, guess ill check that first and hope it was my fault! thx!
Old 05-24-2005, 10:17 PM   #7
mbaksic
Member#: 78280
2003 Baja Classic
Regatta Red/Silver
I haven't had any probs yet. But it has been cooler out here in cheeseland, so I have not tried to use it yet. Should be ok though, since it has not given me any prob yet. Mike
mbaksic is offline   Reply With Quote
Old 05-25-2005, 11:23 AM   #8
Guzzler
Member#: 79616
Any way to make the A/C colder?!?!?! Living in the desert southwest, I use my A/C 10 months out of the year
Guzzler is offline   Reply With Quote
Old 05-25-2005, 07:54 PM   #9
starfox101
Member#: 83174
Just got mine back late this afternoon,blew out 2 seals. Last month I had the dealer install the sub, they messed up the controls, had full heat for the weekend.
05 Baja just over 5000 miles.
starfox101 is offline   Reply With Quote
Old 05-25-2005, 10:16 PM   #10
baja03
Member#: 83018
2003 Baja
dark blue
i got 27000 miles on mine but the only thing i noticed is that it takes about 10 min. to cool down after it has been sitting in the sun here in houston
baja03 is offline   Reply With Quote
Old 05-26-2005, 06:08 AM   #11
Chris N
Member#: 5322
The AC system relys on a delicate balance of R-134a (refigerant). If theres too much or too little it wont be as warm as it should be. But, R-134a isn't as effective as R-12 (old refrigerant that eats the ozone) so freezing cold temps can't be achieved like the old days.
Stick a digital thermometer in your center vent and put the blower on 3rd speed with the AC on. Usually vent out put temps will drop to aprox. 45 degrees. If you think its not cold enough bring it to your dealer and let them know. I don't know what Subaru's minimum requirement is but Saturn's is 45 degrees after 5 minutes of driving, and usually most systems get down around 40 degrees.
Old 05-26-2005, 09:38 AM   #12
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
I think I use my AC almost year round. haven't had a problem with my '03 AC since I got it.
braveit1 is offline   Reply With Quote
Old 05-29-2005, 05:49 PM   #13
10.5sec1992AWDtalon
Member#: 63681
Mine is still working fine. 2003 with 30,000 miles.
10.5sec1992AWDtalon is offline   Reply With Quote
Old 06-11-2007, 04:10 PM   #14
pdiz
Member#: 82424
2005 Baja Turbo
Black Onyx
Mine never really felt too cool from the factory to begin and after 40K it has completely crapped out. No mods done to the DIN or anything. I have no clue what's wrong with it. Fans just blow hot vented air into the cabin. Very annoying. Is A/C still under warranty at 40K?
pdiz is offline   Reply With Quote
Old 06-11-2007, 08:18 PM   #15
Hawk296
Member#: 14555
1995 Impreza L
Baja
Mine had a condenser replaced under warranty. For some reason they just couldn't get the o-ring to seal. Works fine now.
Hawk296 is offline   Reply With Quote
Old 06-12-2007, 12:48 PM   #16
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I've had a problem with my AC refridgerant leaking out of the system. Not sure where exactly it's leaking yet but I'm keeping an eye on it. You can re-charge the AC with one of those R134a recharge kits at autozone or advanced auto parts - $20. Real easy. The low side service port of your Baja's AC is up close to the firewall - real easy to see and get to; it's got a blue cap on it.
The trick is to pull back on those AC 134A recharge kits and push it on the line good and hard. When seating it on mine, I pushed the aluminum line back at least an inch for it to seat in properly.
In my experience, the most common place for an automotive AC system to leak will be around the compressor - usually a gasket that's leaking either on the high or low side. You can buy a UV-light dye kit or clean the lines and areas around the compressor real real clean and check every now and then for an oily dirty buildup somewhere. If you see a spot that looks like dirt accumulated around oil - your leak is very close to that spot. It's refridgerant oil leaking out with your refridgerant. Don't worry if you've lost some oil though - it's usually not that big of a deal.
moonzie is offline   Reply With Quote
Old 06-12-2007, 04:54 PM   #17
seanr2
Member#: 62697
2003 BAJA
Garnet Red
Knock on wood... but I never had a problem with my AC (127000 miles) still blows cold and strong.
seanr2 is offline   Reply With Quote
Old 06-13-2007, 10:10 AM   #18
pdiz
Member#: 82424
2005 Baja Turbo
Black Onyx
Thanks, I'm gonna try to charge it after I find out of it's leaking first. I can hear a really weird whistling/whine/roar type sound when I run the A/C that comes and goes, but mostly is not there. Of course, it's just hot air now, so no point in running it, but that's what I hear.
Old 06-13-2007, 10:26 AM   #19
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Yup. When I was low on refridgerant I heard a whistling sound coming from the dash too. Most like because I was so low on freon so the liquid was more of a thick vapor than a liquid. You're low. Fill'er up!
Old 06-13-2007, 12:56 PM   #20
Kev5n24
Member#: 105711
2005 Subaru Baja
Black on Black
127K and you've never even needed to fill it up? Holy shhhit is Collegeville Pa anywhere near Antarctica?
Kev5n24 is offline   Reply With Quote
Old 06-14-2007, 11:59 PM   #21
pdiz
Member#: 82424
2005 Baja Turbo
Black Onyx
I filled it up today with just a small can of R134a (unfortunately, no gauge) and it seems to be blowing cold now! :-) I'm sure there's a leak somewhere, but hopefully it'll last a while.
Old 06-15-2007, 12:06 AM   #22
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I think the AC system takes somewhere around 22 or 24oz of freon. I emptied an entire 18oz can (a big one) and that put it right at about where it should have been. Those smaller cans only have about 12oz in them, so you may want to put another can in it. The labels under the hood indicate how much refrigerant the system needs.
Old 06-15-2007, 10:03 AM   #23
pdiz
Member#: 82424
2005 Baja Turbo
Black Onyx
Well I don't know how much was already in the system, so I really need to buy a gauge, but it blows pretty cold for now so I'm not going to worry about it just yet. But anyway, doesn't it seem odd to anyone else that we have to recharge it at all? Obviously it has a leak somewhere, or was undercharged from the factory. I guess time will tell since I just recharged mine.
I had a Miata I bought new in '93 and when I sold it two years ago, the A/C was still working great. Same with my girlfriend's '01 Kia Rio. I just don't know about Subaru quality. Don't mean to troll, I really like my Baja, but there's been several other common issues (driver's door weatherstrip, lower radiator hose leak, etc.) and when I try to take it to the dealer (when it was under warranty), there was always some lame excuse (the weatherstrip is the "turbo warning system" warning you to slow down as the turbo's breaking in, that's why it buzzes at speed). Lame!
Old 06-15-2007, 10:48 AM   #24
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
I did have two probs with it early 2K miles 1. the vents wouldn't stay in place and the other was not cold enough. It was overcharged from the factory. They let some out and has been good ever since now have 40K miles. Today its 108 degrees here and mine is working fine as well as my wrx although the wrx seems to be much cooler faster
downhilbil is offline   Reply With Quote
Old 06-15-2007, 11:26 AM   #25
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Eh, it doesn't surprise me. Seeing how many other folks now that seem to have the problem I'm somewhat cynical now of the A/C system on Subarus. More than likely you've got a leak somewhere and you're not the only one.
I checked with advanced auto parts and they can order Subaru Baja specific AC gasket kits (ALL gaskets) for $18.
I noticed a spot that I suspect might possibly be leaking refridgerant on the driver side of the radiator. Cleaned it. Will keep an eye on it.
99 Subaru Outback Shifting problem gifters Transmission (AT/MT) & Driveline 5 07-03-2010 03:05 AM
Need Help 06 legacy 2.5i problem BlobeyeSTi Mid Atlantic Impreza Club -- MAIC 9 06-04-2010 08:53 AM
Recurring CEL, yet "no problem codes found". Datalogs included karnick Engine Management & Tuning 4 06-03-2010 09:40 PM
Problems with my wrx stephentodd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-02-2010 08:53 PM
Problems...Problems...Problems... ashtaron14 Vancouver Impreza Club Forum -- VIC 12 04-17-2001 01:00 AM
