Old 06-15-2007, 11:35 PM   #1
ColesSTi
Member#: 99205
2005 Impreza WRX
Default Throttle body coolant mod 5-10 WHP gain
Hot coolant running through the throttle body will be directed around the throttle body instead of through it, this
bypass is for Cooler and denser air. And you will notice a warm instead of hot intake manifold when valve is
closed. You can you use a plumbing shut off valve from home Depot or Lowes to toggle on and off. If you have
the car in very cold climate's like Alaska you might want the valve. If the car will never see weather well below 0
degrees just reuse the 1/4 lines your be fine. All my car's have this mod and friend's car's as well never had any
problems. As for decreased fuel economy I feel if you don't have a good engine tuner and worried about your
MPG keep it stock.
Last edited by ColesSTi; 02-08-2012 at 10:46 PM. Reason: Update to verify ineffectualness
ColesSTi is offline   Reply With Quote
Old 06-15-2007, 11:45 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
there IS definatly an old thread on this board about this mod. Its a free mod, but these guys are selling the parts you need to do it so i guess its worth it. time is a valuable asset right.. right.
Spend a few minutes searching, there IS a thread or two about this mod. Make sure these guys are selling you what you need. My guess is after you find the old threads you'll just go out and buy what you need yourself if anything.
PaulRex is offline   Reply With Quote
Old 06-15-2007, 11:46 PM   #3
emeessen
Member#: 117741
2012 STI Ltd SWP
2006 Saab 97x Arc
Do not buy this. It is ridiculous.
You can buy the brass coupling at your local hardware store for like $3 and do the bypass yourself. Gains will be very very minimal too, not "6-8 HP at the wheels."
Jesus.
emeessen is offline   Reply With Quote
Old 06-16-2007, 12:12 AM   #4
nomex ninja
Member#: 108222
2002 WRX stage-x
Midnight Black Pearl
hahahah look at the "dyno runs"
nomex ninja is offline   Reply With Quote
Old 06-16-2007, 06:53 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
www.scoobymods.com has the instructions and this will NOT net you 5-10HP. I did it because it makes sense and it cost me like $2 for the fitting.
Old 06-16-2007, 07:28 AM   #6
prometheum
Member#: 92003
04 bicycle!
^^hmm live in alaska...probably shouldn't do this
prometheum is offline   Reply With Quote
Old 06-16-2007, 08:15 AM   #7
fastwrx25
Member#: 126441
03 bugeye
lol!!! I should've thought of selling this "mod" on ebay long ago.
did this mod before, nothing on the butt dyno.
fastwrx25 is offline   Reply With Quote
Old 06-16-2007, 08:18 AM   #8
ColesSTi
Member#: 99205
2005 Impreza WRX
Thanks, I will pick the stuff to do install at lowes today.
Old 06-16-2007, 08:24 AM   #9
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
I didn't have to buy any fittings. The factory coolant hose will reach the other connection on the block without bending or binding.
nicholam is offline   Reply With Quote
Old 06-16-2007, 09:05 AM   #10
Mechie3
Member#: 120152
Got pics?
Old 06-16-2007, 09:06 AM   #11
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
exactly. no extra parts are needed.
nhluhr is offline   Reply With Quote
Old 06-16-2007, 02:57 PM   #12
REDI-wgn
Member#: 38068
03 WRX Wagon
thats what I thoguht, i havnt done it as yet but the olny things that seems necessary to buy is 2 plugs
REDI-wgn is offline   Reply With Quote
Old 06-16-2007, 03:12 PM   #13
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Dude, you don't need to buy anything. if you're looking down at your block below the throttlebody there are too hose nipples. Simply take one of the hoses from the throttle body and connect those two coolent line hose nipples together. One of the two hoses on the throttlebody is too short. Use the other one. You can even reuse the hose clamp. Now paypal me $11.95. Gawd.
Old 06-16-2007, 07:18 PM   #14
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you can buy a couple large vacuum caps if you really want to 'cap off' the fittings on the throttle body... which really isn't a bad idea, but you can do the mod right now and then drive over to get the caps from any autozone.
Old 06-16-2007, 08:23 PM   #15
MasterKwan
Member#: 98961
2003 WRX
Yeah, plug it back in before winter. This is a common mod on integra's and civics too.
MasterKwan is offline   Reply With Quote
Old 06-16-2007, 08:30 PM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
no need to hook it back up. The car runs JUST FINE without it in subfreezing temperatures.
Old 06-16-2007, 09:20 PM   #17
Mechie3
Member#: 120152
No pics?
Old 06-16-2007, 09:34 PM   #18
goixiz
Member#: 99128
2005 SAAB 92x
or plumb your washer fluid through TB to get warm water to clean windshield and maybe a few more HP gain for cooling the TB
goixiz is offline   Reply With Quote
Old 06-16-2007, 09:45 PM   #19
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
thats amazing
99subi is offline   Reply With Quote
Old 06-16-2007, 10:15 PM   #20
MasterKwan
Member#: 98961
2003 WRX
You know, since the ECU can't measure a temperature difference at the manifold, it really shouldn't have any affect on power. On a Honda, the IAT sensor is after the throttle body so, the ECU can measure the difference.
Old 06-16-2007, 10:23 PM   #21
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
since we are talking about heating the air prior to its entry to the combustion chamber, yes, it should make a difference.
Old 06-16-2007, 10:28 PM   #22
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
I think I will do this in the next couple of days... It will not hurt anything so why not... The cooler the air charge the better so again why not!!!!
06grayrex is offline   Reply With Quote
Old 06-16-2007, 11:12 PM   #23
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Someone get some pics up of this
Needles is offline   Reply With Quote
Old 06-16-2007, 11:54 PM   #24
06grayrex
Member#: 116132
When I do this I'll try to get some decent pics....
Old 06-17-2007, 12:08 AM   #25
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Good thought, but a little backwards... the coolant flows through the TB to warm the TB up, not to warm the coolant
firebox40dash5 is offline   Reply With Quote
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 08:33 PM
Throttle body coolant path. Aus_RS Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-26-2004 11:55 PM
Turbo Q: Can you use the Throttle Body coolant lines for the Turbo? Kostamojen Normally Aspirated with bolt-on Forced Induction Powertrain 35 02-22-2004 09:14 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
