Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 09-11-2005, 07:39 PM   #26
2phless
Member#: 69343
1998 TransAm cnvrtbl
My part throttle gives part boost right now, which is nice. It used to climb steadily when in some mid-throttle position, kinda like creep, but different. I don't know if the GMBC fixed that or this combo setup. I did them within a couple of days.
But yeah, spool is quick. Lugging the motor still delivers a slow climb, which is related to the lack of PTFB situations, so I'll take it. Nailing it in 2nd or 3rd from about anywhere and it won't think twice before shoving me back in the seat. It's working well.
I set my low load sites on the boost map pretty high, then taper them back to reasonable numbers by the 60% column.
2phless is offline   Reply With Quote
Old 01-25-2006, 09:19 AM   #27
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
pic of interior knob:
Old 01-25-2006, 09:32 AM   #28
REX8
Member#: 24038
^^^is that a hallman product (the flexible cable and knob) or did you put that together yourself?
Basically, I'm looking for details on the drive setup, as far as parts go.
REX8 is offline   Reply With Quote
Old 01-25-2006, 09:32 AM   #29
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
duplicate pic posted...
Old 01-25-2006, 09:50 AM   #30
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
rex, after looking long and hard for alternate ideas, i just went ahead and got the hallman evo rx.
expensive? yes.
work exactly as promised? yes.
i had thought about using a speedometer drive cable to provide torque to any old ball/spring mbc, but the issue with those is that they are not really designed to be twisted both ways. i did not want rotational compliance making me guess how much i had actually turned the screw in the mbc. then of course you have the issue of mounting it, etc.
i know that hallman does make a retrofit kit for their mbcs so that they can be remote-ized. you could probably get one of those if you really like your current mbc. if not, i can heartily recommend their mbc. the rx has the ceramic ball, and it makes the tightest internal seal i've seen yet on ball and springs. by comparison the joe-p was a tinkertoy.
Old 05-31-2007, 04:23 PM   #31
disque71
Member#: 57330
2008 WRX
I installed the mbc with my gm bcs as you show but its unresponsive. Tightening fully down or loosening all the way out does nothing. Any suggestions?
disque71 is offline   Reply With Quote
Old 05-31-2007, 06:14 PM   #32
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
check and make sure you don't have the wrong nipples connected on the gmbcs.
at rest, with the car off, you should be able to blow from one connected nipple to the other. the car energizes the solenoid to raise boost. this will stop the flow through the solenoid.
when troubleshooting you can also disconnect the BCS entirely to make sure that your MBC plumbing is proper.
finally make sure that when you're WOT, whatever is controlling your solenoid goes to 100% duty. if you're using an oem ecu to do that, you need 100% wgdc and a boost target that's higher than you'll actually clamp it to with the MBC.
Old 06-18-2007, 12:01 PM   #33
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
had another brainstorm come over me a couple of months ago ...
http://www.iwsti.com/forums/showthre...99#post1147599
dual wastegates (ie internal/external).
it'll basically look like this:
WHY you ask?
well... this way you can have your cake and eat it too:
1) retain control over relatively low boost situations by springing your IWG only hard enough to hold the max boost you desire. right now my iwg spring is around 12psi and it'll hold >27psi (tested! )...
2) the EWG only opens up when the MBC does. the MBC controls max boost only. put a spring in it sized a few psi less than the minimum boost you want to VTA. in my case i'd put a 1-1.5 bar spring in.
3) since the 3-port solenoid is controlled by some electronic means, you can map desired boost to TPS and RPM. basically if you want max boost and EWG operation you send 100% duty to the 3-port. anything less will mean the IWG is open and limiting boost to some lower value. no issues with PTFB and boost control is retained at lower levels due to the relatively light spring in the IWG.
4) car is only wicked noisy when the EWG is open. when it's not, all turboback exhaust is in normal operation... ie, cats, mufflers, etc. who cares if it is restrictive and quiet, since:
5) when the EWG opens, you get the big VE benefit of a VTA dump. and it'll be noisy too!
the astute may notice that, on my car, this basically entails adding the EWG up pipe and actuator, removing a tee, and rerouting one pneumatic boost control hose to the new EWG.
Old 06-18-2007, 12:09 PM   #34
LastResort
Member#: 99289
You'll make a number of people happy with this idea, as it's been asked a number of times. Really, I think it's quite a trick idea, giving you streetability of a cutout, plus additional performance. I suppose this would also address boost creep issues, as those only happen at WOT, correct?
LastResort is offline   Reply With Quote
Old 06-18-2007, 12:15 PM   #35
theCRANKwalker
Member#: 71551
2005 Legacy GT
black
pretty crazy setup, any fall backs so far?
theCRANKwalker is offline   Reply With Quote
Old 06-18-2007, 12:15 PM   #36
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Correct.
Sounds like a very good idea Ride. I already use your hybrid setup (except with the stock BCS) and it works very well.
Master2192 is offline   Reply With Quote
Old 06-18-2007, 12:15 PM   #37
theCRANKwalker
Member#: 71551
2005 Legacy GT
black
Old 06-18-2007, 12:16 PM   #38
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes.
quiet manners on the street, whenever you're not at max boost and the ewg is venting. very similar to the cutout-equipped car with a nice quiet axleback and a cat still in the pipe.
at wot you get BETTER VE gains than the cutout car since you are not only dumping to atmosphere, you're doing it from BEFORE the turbo hotside.
otoh, you would still give up SOME performance by having the turbine gasses pass through the "restrictive" turboback exhaust (that the cutout does not do), since the turbo shaft's energy is a function of mass flow rate and pressure differential across the turbine, and one would assume that there is some additional pressure seen at the turbine outlet. then again, all of the wastegate gasses are subtracted from that post turbo exhaust pipe, so that acts to reduce the pressure seen there. it's probably close to a toss-up.
the vta ewg def. takes care of that, whereas putting a cutout on a creeping car is going to make it worse.
Old 06-18-2007, 12:17 PM   #39
Master2192
Member#: 83254
98 2.5 RS
04 WRX
For even more fun, you could get a boost activated cut out in the downpipe and also have it setup with the EWG boost line off the MBC. Then it would be full dump to Atmosphere above that limit :-p
Old 06-18-2007, 12:19 PM   #40
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well, let's be clear--i haven't tried the EWG dual wastegate idea... YET.
the hybrid ebc/mbc has been in place since a few days before i started this thread, and i haven't touched it since.
Old 06-18-2007, 12:23 PM   #41
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
-snip-
Old 06-18-2007, 12:29 PM   #42
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yeah, i've looked at those cutouts (basically big wastegates) and i like them FAR better than the electrical/wormdrive/solenoid types.
there's a lot less to go wrong, there are no connectors to short out, and they don't get damaged from being stuck/jammed open or closed.
the idea of a whisper quiet car that goes ape-**** and scares women and children when you floor it appeals to me!
my wife already hates my car, so i figure what the hell. i just need to keep it quiet around the cops.
Old 06-18-2007, 12:58 PM   #43
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Taking this one step further, if the internal wastegate is controlled by an interupt as per your diagram, couldn't you set the max duty at 100 with a target boost that was really high at 100% throttle? That should create the following scenario:
Target boost at 18psi and WGDC normal in 85% throttle column.
Target boost at 21 psi and WGDC at 100% in 86% throttle and up column.
MBC at 19psi.
Boost below 19 psi would be controlled by the internal wastegate only.
At above 85% throttle, the target boost will jump up and drive the WGDC to 100% closing the internal gate. Boost is now controlled by the external gate only.
I haven't tested this as I don't have an external gate yet, but the theory seems sound. You could set the crossover point for whatever boost and throttle % you want. Personally I would change the 100% throttle column to a value close to the crossover (like 86% above.) That way you would have a clear switchover point and then adjust it as needed for a smooth transition.
bluescoobywagon is offline   Reply With Quote
Old 06-18-2007, 01:02 PM   #44
Master2192
Member#: 83254
98 2.5 RS
04 WRX
haha, exactly. I thought of using a stock STI Cat-back to keep the car quiet, and have one of those cut outs in the downpipe set at something like 15 psi. But I never thought of doing a EWG Dump to Atmosphere along with the cutout.
Old 06-18-2007, 01:05 PM   #45
Master2192
Member#: 83254
98 2.5 RS
04 WRX
MBC at 19psi.
You just explained how this already works!
Old 06-18-2007, 01:17 PM   #46
bluescoobywagon
Member#: 14911
Not A Wagon!
Going back I see that now. I guess I didn't fully catch it the first time through. Although I don't see anything about fine control over the crossover point.
Old 07-10-2007, 07:17 PM   #47
sjs0433
Member#: 86061
very curious to see more about this. Not so much the ewg/iwg but the manual boost controller paired with a gm solenoid. I think having that slightly slow boost response is what I like least about my car. I know a manual boost controller would get me that quick spool but I like some of the safety features of the electronic boost control. Do you know of anyone that has set this up on an 04wrx? I know those didn't do so well with mbc's like the 02/03 wrx's did.
sjs0433 is offline   Reply With Quote
Old 07-11-2007, 06:32 AM   #48
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well if it is tuned, then there is no issue as to what year of car it is.
you'll need to have your EBC, whatever it is, adjusted to default to 100% duty cycle at WOT so that the MBC will be the only component "in circuit."
Old 07-11-2007, 07:56 AM   #49
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
the real reason that 04+ WRX "did not like" MBC is the closed loop/ open delay programming by Subaru. Once that is tuned away (very simple) then there is no difference between using Ken's MBC/ BCS hybrid method.
blkscooby is offline   Reply With Quote
Old 07-11-2007, 08:20 AM   #50
sjs0433
Member#: 86061
That's what I thought the reason was for the 04+ not liking the manual boost controller but I wasn't too sure.
has anyone used a mbc with an ewg before? Would it actually work as well or not? I'm really curious to read this over and get a fully understanding of how ken's mbc/ebc works b/c right now I'm still a little confused.
So does the vacuum source hit the mbc first or the gm solenoid first?
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 10:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 12:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 09:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 06:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 03:12 PM
