Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Alaskan Impreza Club
Old 06-30-2007, 05:47 AM   #1
prometheum
Member#: 92003
04 bicycle!
Default question about camber plates
if you install them on your car you loosen up those 4 little bolts and thats it at the top to adjust your camber right? how the hell do the 4 little bolts on top keep the suspension in position with the weight of the car sitting on top like that? especially under hard cornering?
prometheum is offline   Reply With Quote
Old 06-30-2007, 01:54 PM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
usually you set the top to the min camber setting, then align the car to spec. come autocross day you can easily dial in some more camber, and the way our suspension is set up by adding camber you increase toe out in the front, which also helps turn. at the end of the day you can easily slide them back to the min setting, which should return your alignment to the first specs. also cornering puts the majority of the load on the ball joint + control arm, not much force is put up top. they won't slide on their own
00Maddog is offline   Reply With Quote
Old 06-30-2007, 02:10 PM   #3
Firestrike
Member#: 135785
2006 Impreza WRX LTD
Cloaking Device Gray
I was asking Dale and Derrek about this. They both said that adjusting at track was a bad idea.
Firestrike is offline   Reply With Quote
Old 06-30-2007, 02:18 PM   #4
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
i dissagree! strongly! it will work just fine.
more camber + toe out = better bite in the corner. period!
Old 06-30-2007, 02:27 PM   #5
cooparu
Member#: 67767
2010 WRX
Red
That's why most plates have decent tick marks so you can adjust them back and forth without messing too much up. As long as you realize the toe issues like Jerry said, you'll be fine. Get a good starting point alignment for daily driving, adjust at the track, adjust back to the dd settings.
Lots of people do this. It keeps you from running crazy negative camber on a daily basis. Also, lots of good camber plate threads in the brake and suspension forum.
cooparu is offline   Reply With Quote
Old 06-30-2007, 02:47 PM   #6
wrcRS
Member#: 66632
2006 The Hurricane
Gray
Those four little bolts hold fine, many people up here who road race up in tanacross don't have any problems with them.
As for changing the camber back and forth, I wouldn't care, but then again I know that some people might not like the way a car drives with lots of camber with our sweet ruts in alaska.
wrcRS is offline   Reply With Quote
Old 06-30-2007, 02:55 PM   #7
Kentobeanz
Member#: 120065
1969 360 Sedan
Yep. The vibrations at Tanacross loosened quite a few other things on the car, but there were no problems at all with the front camber settings on mine.
K
Kentobeanz is offline   Reply With Quote
Old 06-30-2007, 06:11 PM   #8
Firestrike
Member#: 135785
Wow! So I can safely change my camber at the track?
Well, I guess I know what I am doing next time. Thanks!
Old 06-30-2007, 06:22 PM   #9
RawCode
Member#: 3115
2002 Impreza 2.5RS
Woah, I never even knew about Tanacross. Interesting...
RawCode is offline   Reply With Quote
Old 06-30-2007, 06:26 PM   #10
prometheum
Member#: 92003
04 bicycle!
well i'm sure there's nothing horridly unsafe about it like OMG YOUR CAMBER IS OFF BY .00032455 DEGREES...i mean we've all tapped the curb once or twice but it doesn't mean your car is going to explode at the track because it pulls to the right
Old 07-01-2007, 01:50 AM   #11
ScoobyTec
Member#: 138546
04 HD2500
Green....Loud
if your going to mess with the camber at the track it would bee a good idea to know just how much it will change toe. more than a 1/4inch toe out will cause the toe out on turns to be out of usable range causing the car to plow. when you turn toe out is increased as you turn because the inside tire does not travel the same path or as far as the outside tire.
ScoobyTec is offline   Reply With Quote
? about camber plates BlackPearlX Brakes, Steering & Suspension 12 07-13-2007 08:02 PM
I have a question about camber plates. R1 STi Brakes, Steering & Suspension 1 08-18-2006 07:05 AM
Specific Qs about camber plates for track w/Espelir GT, '04 STi rkkwan Motorsports 2 06-29-2006 07:17 PM
Need to talk to someone about camber plates SgWRX Brakes, Steering & Suspension 8 03-27-2005 10:34 PM
about camber plate aawen Brakes, Steering & Suspension 0 11-24-2003 03:03 AM
