#51 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
![]() they're in parallel. whichever one allows pressure to flow to the wastegate first is the one "controlling" the boost.
#52 |
Member#: 86061
MAIC
ok. I kinda understand that but I'm still a little confused. So if you want to run 20psi you set the manual boost controller for 20psi? and keep the duty cycle of the gm solenoid as high as it will go to basically just keep it open and let the mbc limit the boost to 20psi? and because the mbc is at 20psi it will let anything below that flow through just fine and use the gm solenoid to regulate boost? So I guess with the way you have it setup the gm solenoid does most of the regulating and its only under wot that the mbc really takes affect? This sounds like an awesome idea, I'm just trying to understand how it all works.
#53 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
In my hybrid setup, the boost line with the restrictor pill cracked and was leaking. But because of the hybrid setup the MBC was still able to keep boost in check
![]() But I got lazy and rather than replacing the line I went to full MBC, which PTFB on the automatic works perfect. Much more enjoyable to drive the automatic WRXs this way, now if I could convince my g/f to let me swap in a manual transmission.... |
#54 | |
Member#: 44422
SWIC
Vehicle:2008 G8 GT Burnouts on Central! |
#55 |
Member#: 86061
MAIC
I already have had my car protuned. 04wrx with vf34 running cobb AP. I'm using the factory boost controller with gm solenoid on my car. One thing I'm not overly fond of is boost response. I know with the vf34 it could be faster than what I've got. Its not slow but I'm confident it could be faster. I also know I don't have any leaks anywhere. Could I get a manual boost controller and hook it up just like you've got it and have it work out or am I going to run into problems? I also have an ewg is that makes a difference.
#56 | |
Member#: 32792
NESIC
part throttle, solenoid duty is <100%, therefore it allows some pressure signal to traverse through it and reach the actuator where it opens the wastegate and limits boost. full throttle, solenoid duty is 100%, and can be for all intents and purposes, ignored. the only pressure signal the actuator sees is that which passes through the MBC. now, can you turn the MBC down so that it's wide open, all the time? sure. you just get actuator spring tension boost levels (aka "wastegate boost"). just think of the MBC as a simple max boost clamp that you can adjust independently of the EBC. it will never allow boost to go above whatever its set at. (of course boost is ALWAYS uncontrollable under actuator spring tension, regardless of method.) |
#57 |
Member#: 86061
MAIC
Cool. This actually does sound like a good idea. I'd like to give it a shot.
couple questions: does having an ewg change anything? also I'm currently protuned with my setup I've got now. using gm solenoid for boost control. Would adding this other one in line screw with that? I'm assuming everything would be straight except for 100% throttle and that would just need to be adjusted so the mbc would be used instead? I guess it wouldn't hurt to try this setup and then get the car retuned. |
#58 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
I'm going to do this today, but I'm going to use enginuity to map it so that above 80% throttle the MBC is in charge. I currently run 21psi with meth on my 20G and will just set my boost targets to 23psi above 80% throttle so that the ecu doesn't think it's overboosting and then I can make quick changes to my WOT boost from 20-23psi. Thanks for the writeup ride!
#59 |
Member#: 49978
NESIC
Vehicle:2002 WRX w/ JDM STi 6spd, EJ255, VF39 & EWG |
::edit:: Looks like I'm better off not going this route right now.
#60 |
Member#: 114730
SWIC
#61 |
Member#: 49978
NESIC
I have an external wastegate with welded flapper and GM BCS, switching to the use of the GM BCS and MBC would require a retune of my WGDC, and I don't own a laptop or Tactrix cable, and my tuner is 8 hours away.
#62 |
Member#: 158043
RMIC
Vehicle:old Something new SWP |
Very interesting. I have always been a firm advocate of the MBC but in conjuction with the BCS it does well. Who'd a thunk
#63 | |
Member#: 105404
NESIC
Vehicle:2006 FPGreenSTI SOLD 04 GMC 2500HD Duramax CC |
i know Junior at ICS will offer to help you tune it yourself. I talked to him before, and Dave @ ESP in Sterling,MA is actually very good with the gm bcs my boost is solid as hell with it, Matt @ DSG although i am not on good terms with he is still part of the developement on the open source software and i would say many people are happy with his tunes!, Mike at TDC can tun open source, and Chris @ XX will do it as well. You have TONS of local options and I am sure if you asked them and told them your situation that you just need to have the WGDC reworked because of the MBC/BCS system your switching to they may charge you for an hour of work or maybe even just have you send them the map and adjust it. Most guys have cables, i know esp does and matt at dsg does....not sure on the others....i have a cable if you need to borrow..... also another good local NESIC member thats very good with Enginuity/Open ECU stuff is Jeremy, aka Blkscooby. pm him here or go to his personal page he just setup and email him..... http://home.comcast.net/~tauperformance/index.html just trying to help out and give you some local options.....i know there a few other local members that may be willing to help....bren wrx and weldinghank i know do a lot of work with open ecu stuff themselves..... |
#64 |
Member#: 49978
NESIC
Black STI, thanks for all the suggestions. Matt at DSG tuned the car and I'm extremely happy with how it runs, this was just something to contemplate as for some reason, around 8psi, 3rd gear, v7 JDM STi 6-speed, the wastegate is starting to open. Now that I switched from interrupt to using both ports on the wastegate, it isn't opening so early. I let off the go pedal around 12ish psi anyways, but I'm at school near Buffalo, NY, quite the drive from home.
Since I have it doing what I want now anyways, I'll look into it closer and discuss it with Matt after I graduate in December. I'm probably moving away from EWG VF39 to EWG 20G/Green or IWG 20G/Green, not terribly sure yet. - Chris |
#65 |
Member#: 85905
Tri-State
Vehicle:2004 WRX |
Just did this on my car and it is sweet. No more out of control spikes during part throttle. Even with the 1820, as the rpms rose about the boost threshold I really had to focus on getting the car to stay smooth by using the throttle, now its just hold at desired throttle position and smooth. May need some more refinement but so far I like it.
#66 |
Member#: 85905
Tri-State
Vehicle:2004 WRX |
Quick question. Im using closed loop boost control and I have my 100% column set to all 500s so my Hallman can take over. Would the boost gain affect the spool up or would it not matter?
#67 |
Member#: 32792
NESIC
it's not gonna matter, from my experience, although i gave up on CLB a while ago.
#68 |
Member#: 98645
NESIC
Vehicle:2002 WRX Wagon PSM |
I've found that the faster i can get my WGDC to 100%, the faster my spool is. that means putting higher numbers in the 2 right columns of th dynamics burst/continuous tables. I LOVE THIS SETUP. my 16g reaches 22psi just shy of 3500RPMs.
#69 |
Member#: 32792
NESIC
in the special constants menu of the utec parameters you can set "wastegate closed below MAP" from 0 (off) to 10psig. this will effectively run 100% dc regardless of what the boost map is set to.
unfortunately not available in the oem ecu... maybe someday! |
#70 |
Member#: 10108
TXIC
Vehicle:07 STI 25G build in progress |
This is a good idea. You could even use the OEM solenoid on the 32 bit cars. I might have to try it, set the MBC at 13 PSI and use the OE for the rest. That way all you have to do is replace the line that has the restrictor pill with an MBC.
#71 |
Member#: 42376
Tri-State
Vehicle:2006 92x Aero Midnight Black Metallic |
#72 |
Member#: 10108
TXIC
Lol. I loved the response of the MBCs when I put them on cars (I ran one on my first WRX). I just don't like the fact that you have to change your boost when the temp is cold vs warm. In Texas it can go up to 90 in the day and 45-50 at night.
#73 |
Member#: 44422
SWIC
Thats another nice thing about the hybrid setup. Let the ECU use the comp tables to reduce the WGDC from 100% at WOT if you want to run less boost when its hot, for example. If the WGDC thru the BCS is less than 100%, you may not get the MBC to come into play.
#74 | |
Member#: 10108
TXIC
If the MBC comes before the BCS (in the line where the stock restrictor pill is located), the MBC acts like a replacement WG spring, but better. Set the MBC for like say 14 psi in 70 degree weather and let the factory BCS (or aftermarket) take care of bleeding off the rest. Why would you be running 100% WGDC? You would only have to run like 20% or something like that depending on what PSI you set your MBC to and your boost targets (more WGDC if you have a 16 bit ECU though). You will have to adjust your WGDC compensation table to match your MBC setting. It would take some dialing in in different weather, but once dialed in, it would work great. EDIT: Oh. my idea is different from Ken's. Ken runs his in parallel. My idea was to just use an MBC to replace the restrictor pill hose, in effect cutting any pressure that the BCS and WG actuator sees until a certain PSI is reached set by the MBC. Basically the MBC is an adjustable restrictor pill, but better the way I would set it up. |
#75 |
Member#: 134610
Vehicle:2003 WRX SONIC YELLOW STG 4 |
this might be a stupid question, but I went to the parts store to pick up a couple of T's and some vacuum hose, they didnt have any T's all they had were Y's which looks the same, do they work the same?
| Thread Tools | |
| Display Modes | |
| What kind of boost control solenoid/boost controller is this? | roninsoldier83 | Factory 2.5L Turbo Powertrain | 3 | 10-01-2007 10:24 PM |
| If the pill is your primary method of birth control, learn from my mistake | George71 | Off-Topic | 59 | 03-15-2005 12:00 PM |
| mbc/ebc and peak boost in lower gears? | chrisfranklin | Factory 2.5L Turbo Powertrain | 2 | 08-02-2004 09:29 PM |
| Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) | lstepnio | Private 'For Sale' Classifieds | 0 | 03-22-2004 06:43 PM |
| Need Help: An analysis of boost control methods | smiles | Factory 2.0L Turbo Powertrain | 16 | 01-07-2002 03:12 PM |
