Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 06-20-2007, 11:20 AM   #1
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Default Hybrid 2.5L short block build Q's
I'm looking to build a hybrid motor due to some unfortunate motor problem.
Car is 2005 WRX originally with EJ20
I'm looking to do the following
Bottom end 2.5L short block swap.
deautchwerks 750 cc injector or PE 800 cc injector
Walbro 255 fuel pump
ARC FMIC
and some sort of short ram intake. (HKS SMF Maybe....)
Tuning will be either ecutek or ap street tuner.
The car still be using the stock EJ20 top end stock and 5MT Transmission. (yes i know i know i already did all the reading in regards to weakness of the transmission)
Turbo in consideration
FP Green 8cm - 2.4" inlet internal waste gate
Deadbolt 20G / TD05 8cm
Blouch 20G / TD05 (Should be same or similar to deadbolt setup)
Any suggestion to the setup? am i missing anything?
Kenji815 is offline   Reply With Quote
Old 06-20-2007, 12:48 PM   #2
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Make sure there hasn't been any damage to the heads. Are you building it yourself or trusting it to a shop?
wrxfactor is offline   Reply With Quote
Old 06-20-2007, 12:51 PM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
reputable shop is building it.
Old 06-20-2007, 01:00 PM   #4
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Forgot to ask, why are you shelling out big money for an ARC FMIC but leaving the tranny alone?
Old 06-20-2007, 01:45 PM   #5
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
transmission is on the list.. just haven't decided.. i'm still doing my research
Old 06-20-2007, 11:23 PM   #6
eggpattern
Member#: 120288
04 wrx wagon
blue
Build your heads. Look at any hybrid dyno chart and see why, it's like throwing a rock over a cliff.
At least new cams. Wrx cams will not support your turbo.
I used sti cams and modded them(get a machinist to plug 4 holes on end of intake cam)
I used cometic .051 to adjust compression of sti shortblock. ride5000 will be right behind me talking about "squish". I chose to have the right compression instead of right "squish" and you should too as long as you're running a bigger turbo.
Arp studs.
eggpattern is offline   Reply With Quote
Old 06-21-2007, 07:05 PM   #7
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Are you going with a "built" shortblock (Crawford, cosworth, etc) or just a stock Subaru STi block?
Forged Pistons?
STi oil pan, oil pickup, STi dipstick? Are you going to run headers because some require the STi pan for clearance.
Timing Belt....
Cams, valves & valvetrain?
The list can go on and on......
New oil pump and water pump?
You may also need a Perrin big MAF intake...
Mine did in order to properly tune it with ECUtek.
skimobile is offline   Reply With Quote
Old 06-21-2007, 07:23 PM   #8
Garage Spec
Vendor
Member#: 133383
2004 Subaru GDB STI
wow nice plans hope to see it come to life
Garage Spec is offline   Reply With Quote
Old 06-21-2007, 07:25 PM   #9
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
I will be using
subaru oem 2.5L short block
2.5L oil pan, baffle, oil pick up, dip stick
stock exhaust manifold.
stock EJ20 top end (cams, valves etc)
Cosworth oil pump and sti water pump
Old 06-21-2007, 11:18 PM   #10
Tom W
Member#: 136728
04 PSM WRX STI Wgn
FP Black 82HTZ powered
You might be on a buget, but I recomened you swap in some cams or port your EJ20 heads. You'll see more power and quicker spoolup for your turbo, I recomened Kelford cams I heard good things about there cams
Tom
Tom W is offline   Reply With Quote
Old 06-22-2007, 11:04 AM   #11
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
With the amount of power i'm planning to put down (280-350 whp)
Cams seems to be a very expensive investment to get that extra few gain in spoolup. (around $800-1000)
I'm trying to stay within a budget but build a reliable daily driven and weekend track warrior motor.
Old 06-22-2007, 12:29 PM   #12
Tom W
Member#: 136728
04 PSM WRX STI Wgn
Thats what i doing to with my 04 WRX Wagon. But looking to make about 400hp and still be a reliable Daily driven, road race, drag race car. it depends on the turbo i chose
are you keeping your 5spd or going 6spd? iam swaping to a 6spd
Old 06-22-2007, 12:35 PM   #13
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
For now i'm staying with the 5 speed.
Budget reasons.
In the future i willl upgrade to PPG or 6 speed.
What turbo are you thinking about to make 400 whp?
Old 06-22-2007, 12:46 PM   #14
quikie
Member#: 131604
2003 WrX
have you purchased your shortblock yet? go to this website thekingofparts.com got the whole sti motor with everything wp, op, and the engine gasket set. its 2000 for the whole thing, and depending where you live i cost me total 2200. i had a budget of 3200 but i decided to be safe and get cams and a new valverain, doing the swap my self should be done by middle of next week. GL
quikie is offline   Reply With Quote
Old 06-23-2007, 01:13 AM   #15
Tom W
Member#: 136728
04 PSM WRX STI Wgn
Right now iam looking at a rotated GT30R or somthing similar to it. If you can think of anything let me know
Tom
Old 06-23-2007, 09:49 AM   #16
ayobreezie
Member#: 117855
2003 O.O
AWP
I hear rotateds aren't very good for road racing...
ayobreezie is offline   Reply With Quote
Old 06-23-2007, 02:00 PM   #17
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Tom
that's a good choice.
GT30R is definitely a good turbo.
I didn't want to change to rotated setup (budget reason)
I think FP Green or Deadbolt TD05/20G will satisfy my need.
I'm looking for fast spool, linear power (around 300 whp).
Old 07-04-2007, 04:11 PM   #18
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Project update.
The motor is out of the car.
Parts to be installed
2.5L Short block swap
2.5 Oil pan / pick up / dip stick / baffle
Modified oil pump
Machine the stock EJ20 head.
Old 07-04-2007, 04:33 PM   #19
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
good for you, with the sti oil pan, I just KNOW you're going with equal/length headers, ya...?
cellobro is offline   Reply With Quote
Old 07-05-2007, 12:09 AM   #20
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Nope.. i love the boxer sound.
with the 2.5L oil pan , it will maintain the oil level better at high G
Old 07-28-2007, 10:48 AM   #21
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Alright so i got my EJ257 shortblock installed with all the original EJ20 components.
The car is untuned right now, just cobb stage 2 (EJ20)
The car has a very rough idle.
Any insight on this?
i know i definitely need a tune for the ecu to properly run the ej257
Could the rough idle cause by something else?
Old 07-28-2007, 07:09 PM   #22
Drink
Member#: 102682
... ripper's
sister.
Sounds like mapping to me.
Run what ever map you had for the 2.0, as fueling requirements are the same for the 2.5 as long as you stay out of boost.
Drink is offline   Reply With Quote
Old 07-28-2007, 09:50 PM   #23
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
those injectors..
maf scaling has to be adjusted
injector data also has to be tinkered
but you need a tune
Old 07-29-2007, 01:12 PM   #24
edo2000
Member#: 68709
2012 WRX
red
Originally Posted by Kenji815 View Post
Project update.
Modified oil pump
I'm thinking of doing a similar hybrid. What machine work did you do on the EJ20 head? What head gasket did you use?
edo2000 is offline   Reply With Quote
Old 07-29-2007, 01:39 PM   #25
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Originally Posted by jaxscuby View Post
those injectors..
but you need a tune
yeah i think i need a tune also.
i'm actually running stock WRX injectors right now.
WTB 2.5L short block / long block ibanez24_7 Private 'Wanted' Classifieds 5 02-14-2009 09:14 PM
hybrid 2.5L Short block new setup Q's Kenji815 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-20-2007 03:45 AM
Interesting tid bit on Sti 2.5L short block IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-26-2003 12:10 PM
2.5l short block with 2.2l heads Tensecgn Normally Aspirated Powertrain 2 02-02-2001 05:06 PM
2.5L short block Tensecgn Normally Aspirated Powertrain 0 11-30-2000 05:14 PM
