Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Closed Thread
Old 08-15-2007, 02:12 PM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Default Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING!
This used to be part of the suspension upgrade FAQ but now that we have more room at the top, giving it its own slot might not be a bad idea.
The rules.
The first rule of the suspension forum is: Do not talk about S-techs.
The second rule of the suspension is: Do NOT TALK about S-TECHS
The third rule of the suspension forum is: please search
There have already been threads about whatever you are asking.
Rule 3a: Search wisely! If you are searching for "what is the best coilover", search with the word "coilover" and search in "titles only" and you can see similar threads. Most likely you could search with "best coilover" and "title only" and see a thread exactly like the one you were about to post (except that 'best' is unfortunately an invalid keyword. rats!)
Rule 3b: if you did search, tell us what keywords you used so that we can help you pick better ones, or so that someone will know that there are no good results for those keywords.
Rule 3c: Read the sticky threads at the top of the forum! That's what they are there for. They have been developed based on the questions we see here, all the time. Chances are they can help you get your answer.
The fourth rule of the suspension forum is: Tell us what you are going to use the car for.
If you are asking for a product recommendation, no one can answer this question unless you tell us what you are going to use the car for. Things like "I just want the car to look slammed", "I do togue because it's what the JDM kids are doing", "I do 10 autocrosses a year and I want to crush all the Mini Coopers in STX", or "I do plenty of track days but also drive on city streets". You need to figure this out FIRST or no one will be able to give you helpful advice.
The fifth rule of the suspension forum is: Evaluate peoples' reviews critically. (Including mine!)
* People are biased. When you say "what is the best x" people are going to chime in saying that they like THEIR x. Duh. Most people who spend money on things are going to defend them and recommend them, even if deep down inside they think they suck. (I was like that about my JDM seats, for a little while, but in the end the damn things were just uncomfortable). No one likes admitting that they paid $1000 for something they are unhappy with.
* Most folks haven't experienced a lot of different setups. Even if someone does like their XYZ coilovers, their opinion is not very meaningful unless they have tried other similar setups. "I got Brand X sway bars and their great" doesn't mean much thing unless they have also tried Brand Y and Z who are in the same price range with similar features. NASIOC is awash with "my springs are great! i love them! my car handles like it's on rails!" posts. When in doubt - try to get firsthand experience. Go to meets and get rides in people's cars, that sort of thing. If all else fails, ask one of the people who specialize in suspension tuning who do this for a living and can give you a good recommendation. (And even then, remember that they may have an agenda.)
* There are a lot of variables when doing suspension/brake stuff. For instance, your poor ride quality may be from your really stiff tires, and not from your shocks. Experience helps you isolate these things. Just because someone does well on a set of coilovers doesn't necessarily mean the coilovers were the key - it could have been the stiff springs or the alignment or the camber plates or the new tires they just put on.
* A really profound post on this subject from Koni Lee. Read this! Read this twice!! And then again.
As with about anything in life, I am a firm believer that one should keep your eyes and ears open to any info that you are interested in and see what you can learn. If it works for you, great. Keep it and use it in your model, practices, etc. If it doesn't work for you, don't follow it but it wouldn't hurt to file it off in the background just in case later info might help clarify for you. If it just flat doesn't work for you then discard it. Don't put any one person on a mountaintop as the "all knowing" because the one thing you know for sure is that he doesn't know it all. He who proclaims the loudest to know it all is the likely one you should be concerned about or at least what his agenda might be. I prefer to think of it a ladder scenario. Learn from those above you on the ladder of knowledge of a topic and help those on a rung or two below you. If you feel or claim that you are on the very top rung you are likely misguided and may have reached a dead end.
Rule 5a: Take comments about how harsh or liveable a setup is with a grain of salt.
Some people don't bat an eye at 10k spring rates; some people think that having stiff springs is cool for some reason; some people think that a stock STi is too harsh. And pretty much every marketing department on earth has claims about "better handling without a decrease in ride quality". The only way to know for sure is to find someone with that setup and get a ride. No one but you knows your tolerance for harshness.
The sixth rule of the suspension forum is: Don't ask us to pick between two products.
There are a ton of these threads. "Which gizmo should I buy, X or Y?" That's not a very good way to frame your question. Start with what you're going to use the car for and what your goals are and why you think you need to buy parts to fix it. Talk about your budget and your constraints (i.e. ride quality, aesthetics) and people will recommend stuff. When you say "I want coilovers, should I buy ABC or XYZ" you are almost certainly eliminating a bunch of good options.
The seventh rule of the suspension forum is: BE HONEST!
The justice system has a saying - it's better to let ten guilty men go free, than to imprison one innocent man. Adopted to the suspension forum, this should read:
"'tis better to discourage ten enthusiasts from buying good parts, than to encourage one enthusiast to buy a bad part"
Remember - most people are going to ignore the "get a ride before you buy" rule. They are probably going to be going off of recommendations. Your recommendation very well may be the one that sways someone to buy something. If you are constantly doing the "OMG my suspension is the best0rz!" thing no one is going to know that it's noisy or it sucks on speedbumps or whatever.
No one should be embarrassed if they spent $ on something and it doesn't live up to expectations. It sucks but it happens. Don't let other people reproduce your mistakes. Get all the information out there that you can.
The eight rule of the suspension forum is: When you give a recommendation, qualify it as best you can.
Make your advice as specific as possible. If you think Axxis Ultimates are great because you used them on your Miata, don't say "Axxis Ultimates are great! They will hold up to track events!" - say "I used them on my Miata at seven track events and they held up great". That way someone can decide how to evaluate your review. They might realize that a 3300 lb STi and a 2200 lb Miata don't use the same track pads. If you only got one ride in a set of Teins and they were bouncy, don't say "Teins are bouncy" say "I got a ride in my friend's 240SX and he had the Tein Flex and they were bouncy". This will help everyone.
The ninth rule of the suspension forum is: There is NO BEST. There is only what's best FOR YOU.
Don't ask what the best springs, brake pads or coilovers are. There is no such thing. Everyone uses their car for different things. What works for an ALMS team is not going to work for someone in Alaska.
The tenth rule of the suspension forum is: No picture requests.
This is not Member's Car Gallery.
Bonus rules
A. The moderators reserve the right to lock your thread if we feel like you're not even trying to ask a good question.
B. The moderators reserve the right to lock your thread if you spell the word "brake" incorrectly.
These are not "do this or get banned" rules, just "do this if you actually want useful help" rules. Thanks
John
Butt Dyno is offline
Old 12-13-2007, 01:10 AM   #2
Butt Dyno
Member#: 17301
is the "dark side"
Old 12-16-2007, 03:37 PM   #3
Butt Dyno
Member#: 17301
is the "dark side"
Updated Teh Rules (tm)
Old 02-20-2008, 11:05 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
Minor updates - added rule 5 as rule 5a, and a new rule 6.
The lock button is always a possibility for enforcement. If you are going to ask for help you should at least have to do a little bit of work to make life easier for the people that are helping you.
Old 04-02-2008, 12:23 PM   #5
Butt Dyno
Member#: 17301
is the "dark side"
Added a Koni Lee quote to Rule #5. Koni Lee rules.
Old 04-09-2008, 12:25 PM   #6
Butt Dyno
Member#: 17301
is the "dark side"
This is written about software, but applies quite well here...
How To Ask Questions The Smart Way
http://catb.org/~esr/faqs/smart-questions.html
The first thing to understand is that hackers actually like hard problems and good, thought-provoking questions about them. If we didn't, we wouldn't be here. If you give us an interesting question to chew on we'll be grateful to you; good questions are a stimulus and a gift. Good questions help us develop our understanding, and often reveal problems we might not have noticed or thought about otherwise. Among hackers, “Good question!” is a strong and sincere compliment.
Despite this, hackers have a reputation for meeting simple questions with what looks like hostility or arrogance. It sometimes looks like we're reflexively rude to newbies and the ignorant. But this isn't really true.
What we are, unapologetically, is hostile to people who seem to be unwilling to think or to do their own homework before asking questions. People like that are time sinks — they take without giving back, and they waste time we could have spent on another question more interesting and another person more worthy of an answer. We call people like this “losers” (and for historical reasons we sometimes spell it “lusers”).
We realize that there are many people who just want to use the software we write, and who have no interest in learning technical details. For most people, a computer is merely a tool, a means to an end; they have more important things to do and lives to live. We acknowledge that, and don't expect everyone to take an interest in the technical matters that fascinate us. Nevertheless, our style of answering questions is tuned for people who do take such an interest and are willing to be active participants in problem-solving. That's not going to change. Nor should it; if it did, we would become less effective at the things we do best.
We're (largely) volunteers. We take time out of busy lives to answer questions, and at times we're overwhelmed with them. So we filter ruthlessly. In particular, we throw away questions from people who appear to be losers in order to spend our question-answering time more efficiently, on winners.
If you find this attitude obnoxious, condescending, or arrogant, check your assumptions. We're not asking you to genuflect to us — in fact, most of us would love nothing more than to deal with you as an equal and welcome you into our culture, if you put in the effort required to make that possible. But it's simply not efficient for us to try to help people who are not willing to help themselves. It's OK to be ignorant; it's not OK to play stupid.
So, while it isn't necessary to already be technically competent to get attention from us, it is necessary to demonstrate the kind of attitude that leads to competence — alert, thoughtful, observant, willing to be an active partner in developing a solution. If you can't live with this sort of discrimination, we suggest you pay somebody for a commercial support contract instead of asking hackers to personally donate help to you.
If you decide to come to us for help, you don't want to be one of the losers. You don't want to seem like one, either. The best way to get a rapid and responsive answer is to ask it like a person with smarts, confidence, and clues who just happens to need help on one particular problem.
Closed Thread
MAIC FAQ and Threads of Note. Read this before posting! rhdude Mid Atlantic Impreza Club -- MAIC 1 01-17-2008 08:37 PM
Simple rules for oblivious drivers. Please add your own. rex n effect Off-Topic 87 12-29-2005 09:47 AM
A few simple rules for TXIC Orion Texas Impreza Club Forum -- TXIC 0 11-22-2002 12:41 AM
