Old 02-22-2007, 11:50 PM   #26
fitzonthemark
Member#: 120691
2004 WRX
10105AA560
That's the part number for the 205 engine gasket set.
fitzonthemark is offline   Reply With Quote
Old 02-24-2007, 11:27 AM   #27
Tap
Member#: 21893
2002 WRX w/STi swap
Originally Posted by 2phless View Post
29 / 13207AA050 / SEAL-INT VALVE / 8 / intake valve seals (green???)
30 / 13211AA050 / SEAL-EXH VALVE / 8 / exhaust valve seals (black???) I haven't checked the difference yet.
green is exhaust and black is intake ... noted this when I tore down some stock heads.
Tap is offline   Reply With Quote
Old 08-16-2007, 07:00 PM   #28
nsucdm_wrx
Member#: 39771
02 FPRed 2.5l WGN
Built heads ;)
Pics are not up anymore?
Putting block back together and this would have been extremely useful.
nsucdm_wrx is offline   Reply With Quote
Old 09-11-2007, 05:13 PM   #29
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
same here. those pics would be quite useful.
question:
is the intake(AVCS) oil seal the one with the larger inner diameter?
14 / 806742160 / OILSEAL-42x55x8 / 2 / Intake cam seals
15 / 806732160 / OILSEAL-32x55x8 / 2 / exhaust cam seals
is it the top one of the bottom one?
vinceGC8 is offline   Reply With Quote
Old 09-11-2007, 11:14 PM   #30
nsucdm_wrx
Member#: 39771
02 FPRed 2.5l WGN
Built heads ;)
AVCS is the larger ID.
question:
Old 12-08-2007, 06:14 PM   #31
wrxsnowstyle
Member#: 122973
02 WRX wagon
aw darn. the pics have died.
wrxsnowstyle is offline   Reply With Quote
Old 06-12-2008, 01:59 PM   #32
modaddict
Member#: 95840
sold to a good bud
awaiting next car
So, is it worth buying the whole kit, or buying JUST what you need?
modaddict is offline   Reply With Quote
Old 06-12-2008, 02:07 PM   #33
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
if you buy a new oil pickup tube (strainer i think they call it) it comes with a small gasket on it, do you still use the larger gasket provided in this kit along with the one that is already installed on the brand new oil pickup?
Thanks a bunch!
cnstman is offline   Reply With Quote
Old 06-12-2008, 02:29 PM   #34
modaddict
Member#: 95840
sold to a good bud
awaiting next car
^^^do NOT double gasket, anything.
Old 06-23-2008, 10:26 PM   #35
jutes85
Member#: 127232
E92 M3
98' Foz
Anyone know how many injector seats I would need for a Top-Feed set-up?
jutes85 is offline   Reply With Quote
Old 06-24-2008, 05:57 AM   #36
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Thread came in handy. I just organized everything in individual zip lock bags. There's one part you didn't mention in the small parts bag. It's the caps with the green insides with a spring wrapped inside the cap. What are they?
methaddict is offline   Reply With Quote
Old 06-24-2008, 11:26 PM   #37
modaddict
Member#: 95840
sold to a good bud
awaiting next car
valve stem seals
Old 07-21-2008, 10:07 PM   #38
redwrxhead
Member#: 156834
A few more of those items: They are obvious when you need them.
where does that gasket to the far right go? i cant figure it out for the life of me.
redwrxhead is offline   Reply With Quote
Old 07-22-2008, 10:24 AM   #39
goDonut
Member#: 53723
03 WRX Wagon
It goes on the left rear timing belt cover. (Number 6 in this pic: http://www.subarupartsforyou.com/ima...ts/COVER36.jpg)
goDonut is offline   Reply With Quote
Old 09-06-2008, 04:17 PM   #40
frnkhr
Member#: 188731
1997 Legacy GT 2.5L
Wink
Upon retrospect, this post has been removed by the author.
Last edited by frnkhr; 09-07-2008 at 04:14 AM. Reason: needed to vent, resolved the issue at hand
frnkhr is offline   Reply With Quote
Old 02-28-2009, 05:10 PM   #41
Letze
Member#: 143323
1990 Celica Alltrac
Gray
bump, if you were doing a hybrid swap (04 WRX), would it be better get the 2.0l gasket kit and get the 2.5 STi HG's?
Letze is offline   Reply With Quote
Old 02-28-2009, 07:31 PM   #42
1GR8WRX
Member#: 18792
I just recently finished a hybrid swap on an 02 WRX. Not saying that it's "better", but what I did was to get the STi gasket kit (10105AA590) and supplement it with the following parts:
13270AA162 - Rocker Cover Gasket
13272AA094 - Rocker Cover Gasket
13293AA051 - (4x) Rocker Cover Gaskets (spark plug openings)
Also, because you'll need to replace your camshaft seals:
806732160 - (4x) Cam Seal
It was extra important for me to get the STi gasket kit, as I replaced the pistons with forged JEs while doing the build. I wanted to make sure I had all the parts I could need. However, I didn't actually break the block open, so I still have a pile of unused parts from that STi gasket kit.
-1GR8WRX
1GR8WRX is offline   Reply With Quote
Old 03-19-2009, 05:49 PM   #43
lawnmower22
Member#: 179531
2005 STI
44 / 806932040 / O RING-32.0x1.9 / 1 / Orange and goes between the two block halves.
Great work on this information. I just wanted to let everyone know that line 44 in the list has a small error, but it's big enough to get someone the wrong part. The part number should be 806932030. It's just one digit off
Actually the 806932040 / o ring-32.0x1.9 part number and Subaru description match but it appears to be part of a Legacy oil cooler.
My local Subaru dealership looked up the orange o-ring that goes between the block halves for me today and gave me the 806932030 part number. I ordered two and will update when I get them.
lawnmower22 is offline   Reply With Quote
Old 03-19-2009, 06:12 PM   #44
lawnmower22
Member#: 179531
2005 STI
5 / 806932030 / O RING-32.6x2.7 / 1 / ???
I just noticed that the OP does have the part number listed. Probably just labeled it wrong.
Old 06-09-2009, 09:13 PM   #45
toflaherty
Member#: 212765
I just got this gasket set and it appears it has the orange o-ring that goes between the block halves, which is 806932030, as mentioned above, but it does not include 806932040, even though the parts list has this number as being supposedly included in the set..
toflaherty is offline   Reply With Quote
Old 06-30-2009, 06:35 PM   #46
Mechie3
Member#: 120152
Here are some pics I've been taking as I reassemble my engine since the ones above are dead. Some pics have the new gasket on the part and an old one next to it for clarity.
It appears that the STI, 02-05 WRX, EJ22t's and the 06+ WRX have different oil coolers (not sure which ones are the same among those though).
My oil cooler is in 2 parts. The teardown thread by reddevil has an oil cooler in 1 part. That's where the blue o-ring goes.
Wrist pin access hole gaskets:
Access port o-ring:
Oil pump main gasket and rubber wedges:
Top section of oil cooler:
Both pieces of oil cooler:
The blue o-ring (goes between oil cooler halves):
Old 07-30-2009, 02:51 PM   #47
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
subaruparts.com they have detailed diagrams linked to the part number
BlackJavaPearl04 is offline   Reply With Quote
Old 04-22-2010, 09:27 PM   #48
Ryan314
Member#: 82989
Hybrid EJ257
If I'm doing a standard EJ257 short block swap with 2.0 WRX heads, should I get the STi master engine gasket set, or the WRX master engine gasket set? Can't find a straight answer to this...
Ryan314 is offline   Reply With Quote
Old 04-22-2010, 11:02 PM   #49
1GR8WRX
Member#: 18792
I finished my build about 2 years ago now, but my list says that I used the STi gasket kit (10105AA590), plus separately purchased WRX rocker cover gaskets (4x 13293AA051). That gasket kit comes with a bunch of stuff that you won't use if you aren't cracking open the short block, but at the time I remember it being a lot cheaper than buying the necessary pieces separately.
-1GR8WRX
Old 04-29-2010, 06:16 PM   #50
Ryan314
Member#: 82989
Hybrid EJ257
Looks like my WRX overhaul kit didn't come with injectors orings and insulators... pissed about that.
2.5 USDM STi short block KZ_Scoob Private 'Wanted' Classifieds 7 10-03-2015 04:32 PM
Axis Stage 2 vs. USDM STi 2.5 Chad W Built Motor Discussion 14 04-29-2007 11:40 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines TooSlow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 01-24-2005 12:14 AM
2.5 USDM STI Motor is strong! Race Tested! WorldOne Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 102 06-23-2004 12:42 PM
