Old 08-15-2007, 08:06 PM   #1
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Default rear tophats
So i just got KYB agx's and H&R springs that are meant for a sedan, but for my 95 legacy wagon.
So long story short the springs on the wagon rear are bigger (wider around top of the spring) then the sedan rear spring.
Is it that i just have to change the tophats to a sedan tophats, I saw sombody on here have sedan eibach springs on a wagon so thats why i did it.
anyone have a answer for what i should do my cars apart right now any quick response would be very helpful.
EastsideLegacy is offline   Reply With Quote
Old 08-15-2007, 09:04 PM   #2
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Match the strut tops to the sedan, and you're golden. The correct strut tops will match the correct springs/struts.
Huffer is offline   Reply With Quote
Old 08-16-2007, 11:45 AM   #3
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
you should be able to use your existing top hat, but you'll need the correct upper spring perch... or get the correct springs.
omahasubaru is offline   Reply With Quote
Old 08-16-2007, 04:54 PM   #4
EastsideLegacy
Member#: 58806
2.2L legacy wagon
yea do you think you could determine the problem im having with a picture of the spring and the top hat that i am having problems with.
I herd that Subaru springs stay the same width just about, from the bottom to the top of the spring, and if this is the case then i do have the wrong spring.
Old 08-16-2007, 07:53 PM   #5
spdracr00
Member#: 65823
1996 Impreza L
Red
what does the spring say? rear tophats were the same on all legacys, (sedans + wagons) from 92-99.
spdracr00 is offline   Reply With Quote
Old 08-16-2007, 08:00 PM   #6
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
Right, but when you buy top hats, they come with spring perches. Get a set of Group N top hats for all four corners - just order a set for a sedan and you'll be laughing.
-Matt
mattwalters is offline   Reply With Quote
Old 08-16-2007, 08:08 PM   #7
spdracr00
Member#: 65823
1996 Impreza L
Red
rear tophats are all 0ne piece
Old 08-17-2007, 12:08 AM   #8
EastsideLegacy
Member#: 58806
2.2L legacy wagon
yea they are one piece but someone said that the camber adjustment on the wagons perch/tophat are differnt so i dont know.
Old 08-17-2007, 10:28 AM   #9
Huffer
Member#: 36735
99 GF8 Impreza 2.0
You can't adjust camber via the rear top-hat. You can only adjust camber in the rear using camber bolts.
Rear camber isn't adjustable on factory parts.
Old 08-17-2007, 04:34 PM   #10
EastsideLegacy
Member#: 58806
2.2L legacy wagon
Yea i worded that wrong.
What I ment was isn't the rear tophats different so it makes the rear camber different on the sedans then the wagons, but im not sure.
But yea i called H&R and there the wrong springs they sent me miata ones. Box was right not the springs though.
thanks everyone
Old 08-19-2007, 03:33 PM   #11
jamal
Member#: 71875
98 Legacy GT
my wheels fit
They don't.
Only 02+ Impreza sedans and wagons have different tracks, and the strut top mounts have nothing to do with it.
jamal is offline   Reply With Quote
Changing Rear Tophats = Different Rear Strut Bar? Brisky Brakes, Steering & Suspension 2 09-11-2009 09:38 AM
02-03 v7 Group N rear tophats/dms coilover tophats Pierpo Suspension/Brakes/Handling 2 05-19-2009 11:00 PM
FS: NC OEM 03 Wagon springs, 03 rear tophats, 03 rear dust boots udelslayer Suspension/Brakes/Handling 0 09-13-2006 03:13 AM
Socal: 02 Rear Tophats Or 04 Wrx Rear Struts/springs 4cylpwr Private 'Wanted' Classifieds 1 10-29-2004 10:06 PM
FT: V.7 STi rear tophats for V.8 STi rear tophats redobs Private 'For Sale' Classifieds 1 06-10-2004 08:40 AM
