Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 08-22-2007, 07:01 PM   #51
WRXShawn
Member#: 35742
2002 PPG + FPGreen
I'm at work right now.
WRXShawn is offline   Reply With Quote
Old 08-22-2007, 07:20 PM   #52
JJ's Red Wagon
Member#: 155937
1995 Impreza w/EJ255
Red
Depending on you piping it can be a little tight access but far from impossible with the engine in.
JJ's Red Wagon is offline   Reply With Quote
Old 08-22-2007, 10:06 PM   #53
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
It's not the most fun, but I've worked in tighter quarters.
SloRice is offline   Reply With Quote
Old 08-22-2007, 10:51 PM   #54
tekgnosis
Member#: 76044
2000 RS w/02WRX swap
BRP
i dont know about with a rotated, but it's easier to work on it from underneath while the engine is in. do-able.
tekgnosis is offline   Reply With Quote
Old 08-23-2007, 10:04 PM   #55
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
so i'm thinking about doing this on a stock location turbo. anyone know if the fitting coming out of the p/s pump will interfere with my turbo inlet hose?
also, i cant seem to find the 14x1.5 to -6an banjo bolt setup on summit...i'm assuming this is the size i need? anyone know where to get one?
GrimmSpeed is offline   Reply With Quote
Old 08-23-2007, 10:11 PM   #56
root
Member#: 55854
2004 STi
Blue/silver
Not sure about the first question, but I can confirm that Summit doesn't have a 14x1.5 to -6 banjo (unless they are hidding it). What is being used is just a 14x1.5 to -6 straight connector. No banjo. I did do a little search and eventually found a specialty 14mm to -6 banjo, but decided not to use it this time around. Wish I could remember were I found it. But if you Google a bit, you will too. Definitely isn't a common fitting size.
I am in the process of doing this conversion myself, fwiw.
root is offline   Reply With Quote
Old 08-23-2007, 10:43 PM   #57
snwman
Member#: 72680
2013 Subaru STi
ok, I took my stock lines to a local hydrolic shop and had them fab me up some custom hoses.
Hoses look good and should work, plus it was only about $70 .
On a side note the hydrolic shop found and inline restrictor and placed it into the new hose.
snwman is offline   Reply With Quote
Old 08-23-2007, 11:09 PM   #58
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
do you know exactly where in the hose it was found?
Old 08-24-2007, 12:03 AM   #59
snwman
Member#: 72680
2013 Subaru STi
if someone can take a pic of the entire stock power steering line maybe I can circle it for ya.
Old 08-24-2007, 10:01 AM   #60
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Unfortunately, I think it will interfere with the turbo inlet hose. I don't think it's tall enough to make it over the inlet hose.
Old 08-24-2007, 10:52 AM   #61
STi5ubie
Member#: 89527
2005 STi
Originally Posted by SloRice View Post
apparently reading comp > you because if you read the rest of the thread, I said it works just fine on my car.
what kit do you have on there? iis that the perrin? looks good and btw, i was right the first time.
he made the "it works, he has it on his car" before you said you put it on your car. he actually said it rite after you said you were going to try it out after you got your car running.
-alan
STi5ubie is offline   Reply With Quote
Old 08-25-2007, 09:58 PM   #62
berserksti
Member#: 142113
Anyone selling their stock power steering line? If so, shoot me a pm.
berserksti is offline   Reply With Quote
Old 09-07-2007, 01:21 AM   #63
tekgnosis
Member#: 76044
BRP
has anyone replaced the big fat hose that goes from the resevoir to the pump?
if so, what size is that? 7/8?
Old 09-14-2007, 06:23 PM   #64
root
Member#: 55854
2004 STi
Blue/silver
Darn. Just popped the hose out of the fitting. I guess my first attempt at assembling hoses is a bust. I don't suppose anyone knows a place to by pre-assembled, flexible power steering lines with crimped -6 AN fittings? Otherwise attempt number two seems imminent, after I buy more hose.
Old 09-28-2007, 10:24 PM   #65
wrxhard
Member#: 108091
I believe that -6 AN is the same angle as a -6 JIC fitting. I make these types of hose probably twice a week. Any hydraulic shop should be able to make something for you out of 3000 psi double braid crimped hose. If THAT leaks, then it's either the wrong angle at the fitting or your hydraulic guy doesn't know what he's doing
Only problem is, the hose is black rubber and the fittings are usually a goldish anodized color. Not quite as bling. Sorry
wrxhard is offline   Reply With Quote
Old 10-15-2007, 11:24 PM   #66
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Bringing this up again
I need to know where the restrictor goes and I don`t want to destroy my stock lines..
My power steering whines with aps braided steel lines and quick rack, I did not see any restrictor in this setup
Letīs see if someone knows
Later
DJ
DJIMPREZA is offline   Reply With Quote
Old 10-16-2007, 11:49 AM   #67
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
No restrictor is necessary.
Old 10-17-2007, 11:58 AM   #68
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
I want to try this too! Are bugeye sizes the same as the sti? im guessing the factory PS system has the same size bolts,fitting, etc?
BuggeyEYED is offline   Reply With Quote
Old 10-22-2007, 03:38 PM   #69
BuggeyEYED
Member#: 101691
97 Supra TT
well, just so happens i brought my car to my shop to have some leaks checked out after my new motor was put in. my PS lines are leaking and they say i need to replace them so this looks like a perfect time to do this!!! again, like the question i JUST asked above^, would this work on my 03 wrx? same size everything?
Old 10-22-2007, 05:42 PM   #70
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
I'm guessing everything is the same. I think the PS racks are different between the WRX and STI, but I don't see Subaru going through the trouble to make the thread pitch and fittings different.
Old 01-02-2008, 11:04 AM   #71
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
nevermind...already sold.
Old 01-02-2008, 06:17 PM   #72
BuggeyEYED
Member#: 101691
97 Supra TT
pmd you!
Old 01-24-2008, 02:11 PM   #73
CatfaceType-R
Member#: 81102
need help...trying to do this within a couple days and feeling a little lost
CatfaceType-R is online now   Reply With Quote
Old 01-24-2008, 05:01 PM   #74
CatfaceType-R
Member#: 81102
bumpington!
Old 01-24-2008, 05:52 PM   #75
BuggeyEYED
Member#: 101691
97 Supra TT
i want to have this done too..anyone done this in the tristate? (:
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 04:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 07:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 11:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 11:58 PM
