Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 08-24-2007, 11:27 AM   #1
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
Default rallycross tyre width question
background: 05 sti rallycrossed on clay, gravel and dirt surfaces which are primarily dry to very dry, occasionally there is a rare mud puddle but never wide event that you can't take a line around it.
current tyre size: 225-45R17 nokian happailietta RSI. I'm looking at some tyre replacement options and one of the options is available in the 225, 235 and even a 245 width. all of which will fit on the wheels and clear my fenders.
so is the wider patch a good thing on dirt in the same manner it is on tarmac? would the added sidewall height rise my debeading risk a lot or make for more sidewall flex for dimenished turn in response?
looking for some people to weigh in on this (fred, orion, christian). I really wish i had the coin and stones to pull the swap to group n brakes and get proper 15" wheels...
maybe in a year or 2 but whatever rubebr i get in the next month should hold me over til then
pjhe is offline   Reply With Quote
Old 08-24-2007, 02:43 PM   #2
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
i've got 205 Kumhos and 215 Falken gravels. i've run some 195 snows and 205 ContiExtreme Contact all seasons, but i can't say there was really any way to compare all 4 based on width as conditions varied greatly.
obviously on a loose surface (like the outside of turns at OA) a narrower tire will get to the bottom of it sooner, but in the areas of hardpack (inside of turns at OA) you'd want darn near a 245 premium summer tire (Azenis 615, Kook RS-2, etc)!
Orion is offline   Reply With Quote
Old 08-24-2007, 02:59 PM   #3
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
i know i'm so torn esp with the fact that a lot of the events are going to be at summit now
and what would likely be best at hastings?
the tyres i'm looking at are snows, with a good aggressive centre section but the shoulders are more closed off then the nokian rsi's are (longer life but i am concerns about grip in loose stuff because of that)
and of course ideally i want to be rotating on the inside line (yeah i WISH i was anywhere near that good)
Old 08-24-2007, 03:06 PM   #4
remowgn
Member#: 41149
04 09 FXT
SSM
If you're willing to go with something other than the super spendy group n brakes, TCE has a decent wilwood kit that will allow you to run 15" wheels. You'd only need to do the fronts obviously, and Todd at TCE can get you set up with the proper front calipers to maintain the right brake balance with the STI rears. I have the full kit on my WRX, and it's quite nice. The aluminum calipers and rotor hats drop a TON of weight.
http://www.tceperformanceproducts.co...s.pl?record=19
remowgn is offline   Reply With Quote
Old 08-24-2007, 03:27 PM   #5
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
hmm in 5x114.3 that would certainly be an option. I'm going to have to test fit some 15"s on the rear and the grp n frts aren't too bad price wise, but i think the brembo rears still might not clear 15"s in the back
Old 08-25-2007, 08:08 AM   #6
Fred
Member#: 3560
06 STi, 02 WRXes
94 Open Light 2.5RS
The 2000 2.5RS stock wheels won't even fit back there. I'd love to see a 15" wheel that would fit.
If I was stuck with stock wheels, I'd try 225/50/17 with a very stiff sidewall and very aggressive tread pattern, whatever tire that ends up being.
You're really handicapped with the STi, though - so the biggest thing will be removing as much weight as you can, modulating the throttle and focusing on running the shortest line possible with no mistakes.
Fred is offline   Reply With Quote
Tyre Size Question Sports Wagon Rocky Mountains Impreza Club Forum -- RMIC 6 09-01-2009 08:35 PM
wheel width question?? Rock_Strongo Tire & Wheel 2 10-14-2003 03:47 AM
Snow Tyre Pressure question mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 8 11-30-2002 07:03 AM
Offset vs. Wheel width question bobafett Brakes, Steering & Suspension 5 10-08-2002 10:35 PM
offset, wheel width question zabutter Brakes, Steering & Suspension 4 08-17-2002 10:50 PM
