Old 08-15-2007, 01:56 AM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default Subie version of LS/VTEC
This is the latest project.
Probably looking at running a light setup, VF39 w/ my existing headerback exhaust and a tune at 15psi.
FuJi K is online now   Reply With Quote
Old 08-16-2007, 08:15 PM   #2
kay95
Member#: 45494
95 impreza L awd
green
Hmm which closed deck block is that??
kay95 is offline   Reply With Quote
Old 08-16-2007, 08:32 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
lets see.... LS/VTEC is B18 block w/ B16/B18-VTEC head, moreso the B16 if I'm correct. Normally it's Civic Si's that do this block upgrade to get a .2L's of displacement. But then you have Integra LS's that slap on a B16 head and voala, VTEC! And B16 head has better flow, aside from valvetrain difference from the B18 ITR head.
For us Subarus, this would be not a 2.0L, but a 2.2L. The WRX heads are ported, so it's a higher flowing head and it's slapped onto a bigger than normal Subaru turbo engine; 2.2L. The 2.5L would be more like Honda's H22.
SO.... it's the infamous EJ22T('91 w/ oil cooler) w/ PORTED '03 WRX heads(shimless). The TGV's are also ported to release some more TOP-END power.
I'm not sure how much power capable this is...but I'd call this my medium setup opposed to my light setup (STOCK complete EJ22T engine w/ TD04L/TMIC/headerback boosting at 15psi w/ MBC). My light setup yield me 178whp and 244wtq and was quick enough to run w/ a stock EVO9 in my little wagon.
Old 08-20-2007, 04:27 PM   #4
kay95
Member#: 45494
95 impreza L awd
green
Should be good for plenty of power. That EJ22t is a glutton for boost. Should be good for easy 300whp.
Old 08-20-2007, 07:07 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
blaahh try like 400+..you can hit 350 with an open deck and it will hold up IMO..
mxpunk is offline   Reply With Quote
Old 08-23-2007, 04:26 PM   #6
kay95
Member#: 45494
95 impreza L awd
green
I was being extremly conservative. If STI internals can do 600whp or better I would think this could do 500whp on a safe tune.
Old 08-23-2007, 09:38 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
really now?...and for how long
I've seen certain companies like crawford/i-speed claim 550 for their time attack car and we all know they have a high reading dyno...
Old 08-24-2007, 04:55 PM   #8
kay95
Member#: 45494
95 impreza L awd
green
http://www.rs25.com/forums/showthread.php?t=39629
Only as long as you have a good tune and dont keep trying to push the limit.
Old 08-24-2007, 05:58 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Without a PERFECT tune, you can easily bend the rods on an EJ22T block with anything over 350whp. Open or closed deck is not the end all determining factor here. Do a search and you will find some really ugly bent rod pictures...
Matt Monson is online now   Reply With Quote
Old 08-24-2007, 06:00 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
For the record, I have now sold Skully I believe 4 blocks in the last 2 years. They have been a mix of Ej22T and open deck Ej25 blocks. He's pushing the limits, but he's also blown up a lot of engines in the process...
Old 08-24-2007, 07:16 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
O rly?!
Which rods would you suggest, Eagles?
Tulsa, OK: 1994 Integra LS/VTEC JRSC skerman Private Vehicle 'For Sale' Classifieds 8 04-30-2006 12:01 AM
Tulsa, OK: 1994 Integra LS/VTEC JRSC skerman TXIC Private Classifieds 7 04-28-2006 09:44 AM
FS: eg hb w/ ls vtec SOCAL scoobyimpreza Private Vehicle 'For Sale' Classifieds 0 06-22-2004 06:03 PM
FS: JDM Front End 95 Integra LS/Vtec Addicted2Racing Private Vehicle 'For Sale' Classifieds 8 05-07-2004 12:57 PM
FS: 90 Civic hatch with LS/VTEC engine fellfrosch7 Tri-State Area Forum 5 11-09-2003 10:47 AM
Message Board Statistics All times are GMT -4. The time now is 04:43 PM.
