Old 08-25-2007, 05:08 PM   #1
S L O W W R X
Member#: 95109
Default GT37R, bugeye
We finally got my Bugeye on the dyno, I don't usually post much about my cars because I have never felt a need too but a couple of people have suggested that it would be nice for the rest of the community to see what we have done with the car.
First a couple of pics then the build details. Keep in mind the car isn't totally done, we still need to tuck up all the lines, shorten a few of them etc..
Motor
2.5 liter
Stock Crank
Pauter Rods
CP Pistons
Total Seal Gapless Rings
ACL Race Bearings
Version 8 JDM Heads
Ferrea Double Valve Springs
Ferrea Titanium Retainers
Ferrea 1mm Oversize Valves
Batlground Custom Ground Cams
Cometic Gaskets
ARP Head Studs
Magnus Intake Manifold
AEM ECU
Aeromotive Fuel Rails
1600cc injectors
AEM injector driver
Custom Fuel System by me
Turbo Setup
What is commonly referred to as a GT37R
Turbo Trix Exhaust Manifold...Modified
Tial 44mm Wastegate
Batlground Custom Exhaust
Batlground Custom Intercooler
Transmission
PPG 5 speed Straight Cut Syncro Box
This car has been a long time in the making. Ill get Mike to post the low boost dyno charts on Monday. Apparently after reading some post by Ron at Axis it appears that I didn't torque the head studs correctly. So after the first heat cycle we popped a head gasket...just barely. So I'll be pulling the motor on Monday and replacing the head gaskets probally with something a little thinner.
The car made 500whp at 18lbs spinning it to 7500rpms, we plan on spinning it to 8000rpms....but with didn't get a chance yet. It spools about the same as a GT35R with 1.06 backside. It doesn't look like 700whp is going to be a problem at all. I'll post more as we continue tuning.
Big Thanks to the guys at Batlground Motorsports Engineering. Brandon the head Mechanic has put everything he has into this project, he is the only mechanic that has ever touched this car. Dan has been awesome and he will settle for nothing less than perfection in his tunes. Scott Siegel the new arrival at Batlground has been there for technical guidance and general Subaru knowledge. Mike who usually handles front office duties was there all night the other night helping us get the car done. I can't say enough good things about these guys...Also a big thanks to Andrew at Gearboxtech.com for hooking us up with a gearset to get this beast down the track.
I'm open to questions if there is anything you want to know please ask.
Matt
S L O W W R X is offline   Reply With Quote
Old 08-25-2007, 05:11 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
interesting turbo placement How's the magnus intake manifold workin for you?
can you also comment on your fuel system? What pump are you using? Stock fuel tank? Sumped? Surge tank? Feeder pump? size of lines used, etc.
jigga is offline   Reply With Quote
Old 08-25-2007, 05:15 PM   #3
S L O W W R X
Member#: 95109
The turbo is there to cut down on Piping length. The first Magnus intake manifold we got had problems...but Marco sent us a new one pronto. They made it right and they did it quickly and they did it right. Great Customer Service.
Matt
Old 08-25-2007, 05:20 PM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
beautiful braided lines........those cost you $$$$$$$$$
What's the block under the turbo? a tank to pool the oil and then it gets pumped out?
What's the cars purpose? DD, Drags?
Looks good. Props to you.
modaddict is offline   Reply With Quote
Old 08-25-2007, 05:25 PM   #5
S L O W W R X
Member#: 95109
The block is basically just a sump for the turbo, since its actually lower than the oil pan we have to pump it out(Thanks to All-Aspects and Turbo Trix for the pump info).
Its just something fun to drive on the weekends and occasionally take to the drag strip. I would like to see it go 9s but we will see.
Matt
Old 08-25-2007, 05:44 PM   #6
wrxty
Member#: 121996
thats nucking futs!
wrxty is offline   Reply With Quote
Old 08-25-2007, 06:57 PM   #7
S L O W W R X
Member#: 95109
Sorry looks like you were editing as I was typing.
Fuel System is fairly simple. The guys at Batlrgound took the stock hanger out and mounted two Walboro 255s, those feed dual 6 an lines that run to the front and y into 1 8 an line. The 8 an feeds the rails and the rails feed the pressure regulator.
If we have any fuel delivery problems then we will go to a surge tank design.
Matt
Old 08-25-2007, 07:12 PM   #8
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
How much psi are you looking to Run on race-gas? 32-33ish
STi_Guy04 is offline   Reply With Quote
Old 08-25-2007, 07:16 PM   #9
S L O W W R X
Member#: 95109
30-35 psi, we will just have to see what the car likes.
Matt
Old 08-25-2007, 07:17 PM   #10
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
500 whp at 18psi is pretty awesome. Can't wait to see the high boost #'s!
r0nzar is offline   Reply With Quote
Old 08-25-2007, 07:49 PM   #11
S L O W W R X
Member#: 95109
Yeah, theres still more left in it.
Oh the AVCS isn't even working yet. I suspect that we will see spool similar to a .82 35R by the time we are done.
Matt
Old 08-25-2007, 07:53 PM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Matt
ahh cool.. sounds simple enough... and its running okay so far yes?
I think im in the same boat as you in that im not a fan of the surge tank in my DD, but i am also trying to decide whether to do the walbro thing ot go with a Weldon inline fuelpump stuffed underneath the car.
Old 08-25-2007, 07:56 PM   #13
S L O W W R X
Member#: 95109
Yeah it runs fine, even with the 1600s in it. The car still has full interior and AC, so putting a surge tank in it wasn't really what I wanted to do.
Matt
Old 08-25-2007, 08:05 PM   #14
fobiawrx
Member#: 91074
04 sti
white
look at you go! wee need more turbo fog light cars on this board! congrats on the # and post up more pics.
fobiawrx is offline   Reply With Quote
Old 08-25-2007, 08:13 PM   #15
S L O W W R X
Member#: 95109
Hopefully it will be back on the dyno at the end of next week.
I've been watching youre thread. Keep up the nice work.
Matt
Old 08-25-2007, 08:23 PM   #16
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
whats up with "Total Seal Gapless Rings"?? I went on there website and all i saw were specs and what not........are there really no gaps in the rings?
Old 08-25-2007, 08:27 PM   #17
S L O W W R X
Member#: 95109
My engine builder had them spec'd for my build. Apparently they have about 1 million diffrent ring material combos that you can use. Pretty cool stuff.
Matt
Old 08-25-2007, 08:31 PM   #18
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Matt
Are you running both pumps at 100% duty cycle at all times? Or are you running them off the stock fuel pump controller somehow?
Old 08-25-2007, 08:46 PM   #19
benw
Member#: 103320
1998 swapped
Forester L
love the turbo mini-sump!
please tell me you're going to cut a hole in the bumper for the intimidation factor.
benw is offline   Reply With Quote
Old 08-25-2007, 09:03 PM   #20
Ghost Rider
Member#: 70346
2013 Focus ST
Performance Blue
wow, that is some build up.
Ghost Rider is offline   Reply With Quote
Old 08-25-2007, 09:04 PM   #21
a04subaruwrxSTi
Member#: 129787
04 STI
Java Black Pearl
omg! Looks freaking awesome!
a04subaruwrxSTi is offline   Reply With Quote
Old 08-25-2007, 09:53 PM   #22
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
turbo is looking good man! Also are you going to run exhaust?
RexRexRex is offline   Reply With Quote
Old 08-25-2007, 10:12 PM   #23
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
I got to come by and see this thing Matt. Whens the next dyno day?
STiBottom is offline   Reply With Quote
Old 08-25-2007, 10:26 PM   #24
milano12
Member#: 157574
thats insane. nice
milano12 is offline   Reply With Quote
Old 08-25-2007, 10:29 PM   #25
WRXsponge
Member#: 79621
Bug Waggy
3.0 PNP
Great build. Do you have any under-car pics?
WRXsponge is offline   Reply With Quote
FS : WRB bugeye hood, scratches and a dent or two, $20 or FREE! MannyMohawk#5 SCIC Private Classifieds 15 01-08-2011 10:35 PM
T3/T04S to GT37R - Projected Gains? Teh Legacy Proven Power Bragging 44 02-05-2008 09:43 PM
GT37R Axis S5 Cosworth Head/Cam billionaire7 Built Motor Discussion 28 10-18-2007 04:25 PM
GT35R vs GT37R? nastiaz04 South West Impreza Club Forum -- SWIC 70 05-27-2006 11:59 PM
GT37R? Would it work on a STi? MARKGSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 04-12-2006 04:17 PM
