Old 08-28-2007, 07:39 AM   #51
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
The H6 revs pretty quick so IMO, running a 4.11 or 4.44 would force you to make a 2-3 shift on faster courses or be into the rev limiter for a little too long. The 3.90 should be fine. Also, it seems the 3.90 helps keep low rpm wheel spin to a minimum although I still got some and again, I wasn't really on it. The front 1.5 diff will be key too.
Oh...for those wondering, I have virtually no more AWD push! Instead, the car seemed to pivot...a nice feeling but, I'm sure my set-up will kill tires, I'll have to do MUCH more testing.
It's looking like sept 9th will be the next test day for us.
cueauto is offline   Reply With Quote
Old 08-28-2007, 08:04 AM   #52
Carisma
Member#: 89017
1995 Subaru Impreza
Red
I am so tempted to do this now for my track car.
I have someone that can do wiring for me and I can fab a new radiator myself.
Carisma is offline   Reply With Quote
Old 08-28-2007, 02:12 PM   #53
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
Reeeaaaalllllyyyyyyy........we may need to talk! I need a larger core than the original 1.8L core! I can't idle in line for very long right now....Florida heat is a killer!
Old 08-28-2007, 02:17 PM   #54
Carisma
Member#: 89017
1995 Subaru Impreza
Red
LOL...
Yeah I used to fab up ones for RX7's when I built them. It would probably look like a front mount since that would get the most air flow.
Old 08-28-2007, 04:07 PM   #55
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
What kind of pricing are we talking? Very interested.....
Old 08-28-2007, 09:31 PM   #56
AllWheelsDriven.net
Vendor
Member#: 124802
1996 22B-righton STi
Graphite Grey
Great thread Andy, it's about time you posted this up.
You are one of the pioneers with your set up..
Did you mention 3:90 w/ the RA gearset?? I know a guy that just put something like that in his GC and it works quite well.. That would probably work the best for your beast.
Still want that ride when our paths cross at an event..
AllWheelsDriven.net is offline   Reply With Quote
Old 08-28-2007, 11:21 PM   #57
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
Mick - you're not totally off base, but remember there are two parts: Torque x Gear Ratio. To turn 2500 at 70 miles per hour would be pulling a substantially taller gear than the 2.5RS 5th. I don't question the engine's torque (mine makes peak RS torque at less than 2k... even at the very beginning)
Barrett - you need to be in here too... you figured out most of the how to of fitment of my car. I'm just working out the bugs. And yes... 3.90 w/ the RA gearset is, I think, the right answer.
Andy
adhowe70 is offline   Reply With Quote
Old 08-31-2007, 01:52 PM   #58
SVXelerator
Member#: 78963
On the EG33 swapped cars, a turbo will go exactly where it would on an EJ__.
You could run a smaller A/C condenser from a Honda, you'd just need custom lines made..no big deal and not that expensive. Hood clearance may be an issue.
On that note, my SVX ps pump pulley barely hits the hood. I'm running a cf hood, so its clearancing its self.
For auto-x, get a front LSD before you even start! On my brief initial pass, I lit the inside front tire on the first turn.....nice and smokey!
So, where did you get a front LSD??
SVXelerator is offline   Reply With Quote
Old 08-31-2007, 02:41 PM   #59
DSM_Outback
Member#: 56345
93 Swapped L
Green
<psst>The Moose usually has some.</psst off>
DSM_Outback is offline   Reply With Quote
Old 08-31-2007, 08:40 PM   #60
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
^^^^^ true, I think he is selling one now.
I don't have one YET....Josh has the OBX one and loves it....
Old 09-01-2007, 01:11 PM   #61
jezzeppi
Member#: 10339
Default EG33 swap in Impreza (pwr steering)
cueauto and wagonL,
My 95 Pwr Steering lines don't reach to the mount points, nor does it look like the hood would close with the 95 pump in it. I'm assuming you both have eg33 units. My question is from which point did you connect the lines (down by the rack or up by the pump?) Custom or legos like usual?
Turned it over for the first time today!!!! (no ign or fuel yet, but progress)
Also just to confirm, what is the firing order as viewed from the radiator?
jezzeppi
jezzeppi is offline   Reply With Quote
Old 09-02-2007, 12:01 AM   #62
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
I know this is an Impreza only thread but...
I found it easier to connect the PS lines at the pump not at the rack. The pump barely fits... but it fits.
I found that I was grounding a wire that shouldn't have been grounded. It was a black ignition wire that looked like a ground...It wasn't it was a power wire. Put a hot when on wire to it and the car fired up. I also ran a direct power line from the battery to the pump with a toggle switch...seems to work for me I was having problems getting the Fuel pump relay to work.
The firing order if your looking at the engine from the radiator its front left (1) then to the back right (6) then to middle left (3) to front right (2) then back left (5) to middle right (4).
Hope that helps good luck!
~Jedz
jedz123 is offline   Reply With Quote
Old 09-04-2007, 07:21 AM   #63
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
I used the PS pump and resivor from the SVX and my Impreza PS lines juuuust reached.
On another note, I am cutting some 1/8" steel to weld my motor and trans mounts solid. I do have a touch of contact between my hood and PS pulley....not a big deal though. I think it only touches when the engine torques over...
Old 09-04-2007, 08:01 AM   #64
jedz123
Member#: 67083
1993 Impreza L HB
What is every one using to latch down there hoods?
I was unable to reuse the stock hood latching system (no room with the pusher radiator fans). I found that hood pins have allowed me to keep the hood closed and latched.
Old 09-04-2007, 04:09 PM   #65
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
Hood pins........
Old 09-04-2007, 08:20 PM   #66
adhowe70
Member#: 3363
1982 Reynard
The beauty of the EZ30... stock latch.
Old 09-05-2007, 07:44 AM   #67
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
In reality, you could use the stock latch....bit of work but it could be done. I have a carbon hood and they should be pinned regardless of whether or not there is a factory latch. But I'm sure the EZ30 would cause waaayyy less headaches as far as those type of fitment issues are concerned...
Old 09-09-2007, 08:28 PM   #68
SVXelerator
Member#: 78963
So, which "Moose" might have a front LSD for sale, I see there are several members that have "Moose" in their site names?
thanks!
Old 09-14-2007, 11:50 PM   #69
wagonL
Member#: 84599
Originally Posted by jezzeppi View Post
cueauto and wagonL,
jezzeppi
i actually just use my stock 95 ps...just pretty much bent the metal lines a bit towards the bumper and it fits! haha well the hood did have a problem with the fitment but i chopped that area off...(weight reduction!! 5ounces!! :P) but yes...thats what i did...
wagonL is offline   Reply With Quote
Old 09-14-2007, 11:52 PM   #70
wagonL
Member#: 84599
well if anyone is interested....im actually at work so i cant do too much with the net...
http://www.mnsubaru.com/forums/showthread.php?t=19079
i used fuji_k's cell phone video recorder to tape my exhaust..and how it sounds with the eg33...
the lighten crank pulley and the 10.4lbs X-ACT flywheel makes it rev pretty fast! and it sounds very ferrariish...sounds very exotic! and i love the sound of it...
Old 09-15-2007, 02:19 AM   #71
Christian.
Member#: 87604
The car sounds super good, any more details about the exhaust manifold, muffler, piping size, etc.?
Christian. is offline   Reply With Quote
Old 09-19-2007, 04:38 AM   #72
anotherwhitegtb
Member#: 140486
Hey guys,
Im in the process of getting rid of my twin turbo Legacy GTB motor and putting an EZ30R in its place. Im pretty sure i have everything sorted (even the ECU side). One of the last things i need to sort out is the throttle body.
For those that have swapped the throttle bodies from the standard electrical one to a mechanical one, what throttle body did you use, and how much effort did it take to hook up to the intake manifold? Im trying to find the lazyest option (i prefer to call it effiecent though )
anotherwhitegtb is offline   Reply With Quote
Old 09-19-2007, 07:30 AM   #73
Slack
Member#: 17548
Originally Posted by anotherwhitegtb View Post
Hey guys,
I used the 04 H6 throttle body. ECS made an adapter for it to fit onto the 05+ manifold.
Slack is offline   Reply With Quote
Old 09-19-2007, 07:33 AM   #74
cueauto
Member#: 114715
96 H6 Impreza L Cp
#84 EM
Slack, how is your car doing? I haven't seen too much on it. I hope all is well with it..........
Old 09-19-2007, 08:43 AM   #75
jedz123
Member#: 67083
1993 Impreza L HB
thats nuts... Can't do that on the EG33 though.. Twin throttle
Vag-Com cable resource thread cooleys04 Open Source Reflashes 275 02-16-2016 11:51 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
