Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 09-02-2007, 10:26 PM   #1
MasterKwan
Member#: 98961
2003 WRX
Default Does taking out the rear hub damage the wheel bearing?
I'm trying to decide how to get around a problem I'm having (that I caused). I have new spindles including hubs for the rear of my 03 to replace the 80K miles spindles/hubs that I have now. Because I want to use the old backing plates so, I can use the same brakes, the question is:
1) Will pressing the hub out of the rear wheel bearing and pushing it back in damage the wheel bearing?
Honda clearly states in their manual that removing the hub, means you need to press in a new bearing. The suby shop manual, is a totally disorganized POS. I can't even FIND the procedure for wheel bearing replacement much less a discussion of the hubs. So, I'm coming to you all for advice.
MasterKwan is offline   Reply With Quote
Old 09-02-2007, 10:39 PM   #2
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
It's been my experience that when you press a hub out of a bearing, one of the bearing races (the part that the rollers inside the bearing ride on) will go with it.
You've got new spindles with hubs in them already, which means that there's bearings in them. AFAIK the backing plate should simply be a bolt-on piece, so swapping it shouldn't require a press of any kind to be used, although it's been a while since I've seen one, so I'm not cetain how accurate my information is.
silver2004impreza is offline   Reply With Quote
Old 09-02-2007, 10:58 PM   #3
MasterKwan
Member#: 98961
2003 WRX
With Honda's that's exactly right. Front or rear, the bearing pulls apart when you press the hub out.
Imagine this. The order is Hub, backing plate and spindle. The Backing plate fits OVER the bearing housing. then the hub is pressed into the bearing so, to take the backing plate off, the hub has to come out of the bearing.
I've done more research and the manual implies the hub can be pressed out without damaging the bearing. You can't re-use the bearing IF you remove the bearing but, it says to only replace the bearing if it's damaged. I read that as, pulling the hub doesn't damage the bearing.
Thanks for the comment though.
Old 09-02-2007, 11:18 PM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Pulling the hub will not damage the bearing if you do it right. I have done several and reused the bearings. If you think the Subaru FSM's are bad you should look at the mazda FSM's, they are much much worse. Do you have the actual FSM- or a lousy copy or Haynes POS?
Old 09-02-2007, 11:45 PM   #5
MasterKwan
Member#: 98961
2003 WRX
I have a copy. It's right up there with the POS Nissan manual. The Honda manual's like a novel. I can read it for enjoyment as well as to learn something.
Thanks. I'm going to try it in a few minutes.
FS: 02+ Front Passenger, Both Rear Hubs / Knuckles / Spindles with bearings Gro Harlem Suspension/Brakes/Handling 7 02-19-2009 09:23 PM
Questions about replacing the rear hub and bearing? stifry Transmission (AT/MT) & Driveline 5 12-11-2006 02:59 PM
How does having the wrong offset damage the wheel bearings? awdlifestyles Tire & Wheel 7 10-24-2005 11:25 AM
Anyone want to sell me a WRX hub w/ good wheel bearing? wigglesxjr Southern California Impreza Club Forum -- SCIC 1 07-20-2005 02:21 PM
does anyone know how to take out those orange pieces under the front blinker? imajinaxn Interior & Exterior Modification 9 02-06-2001 12:11 AM
