Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-03-2007, 11:16 PM   #1
omdwrx508
Member#: 125108
Default 93 stage 2 map with 91 octane
so ive searched this question with no luck.. i just moved to socal for mass. out in mass we have 93 octane so i was running a stage 2 xpt 93 octane map. driving across the country i found that iowa and nebraska only have 89 octane and 90 octane was a treat. now that i live in cali i can only find 91 octane. am i doing harm to my car by using the lower octane, and should i try to flash my ecu to a 91 map? i currently don't have a laptop like back east. so its a bit more of a hassle to do.
engine mods:
injen cai
3" catless turboback
catless uppipe
thanks
omdwrx508 is offline   Reply With Quote
Old 09-04-2007, 05:40 AM   #2
dlh1999
Member#: 105629
2006 300c SRT8
IMO, you'll probably want to switch to a 91 octane map pretty soon. You're basically making your current map lean out the car a little because it expects 93 octane but you're only giving it 91 (which, I hear, isn't great quality in some parts of California, Nevada and Arizona). It'd be pretty safe going the other way (ie. 93 octane with a 91 octane map) because rich is better than lean, but probably not the best idea vise-versa.
dlh1999 is offline   Reply With Quote
Old 09-04-2007, 08:55 AM   #3
robert46123
Member#: 130355
2006 Impreza WRX
Cobb has a map designed just for the crappy piss you call gas in California. I'm not sure a standard 91 octane map would even be safe in California.
robert46123 is offline   Reply With Quote
Old 09-04-2007, 10:07 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
octane doesn't have much to do with the AFR. the AFR won't change (much) with different gas. what does change is if the car knocks or not, at a certain RPM it might need more fuel to prevent knock, even though it technically isn't lean, or at least any more lean then before.
rkramer is offline   Reply With Quote
Old 09-05-2007, 06:08 AM   #5
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
I have a 91 oct map that runs great if you want it (STG 2)
StupidFastWagon is offline   Reply With Quote
Old 09-10-2007, 10:09 PM   #6
dtpebs
Member#: 98084
2008 WRX Sedan
Charcoal Grey
Sign up at osecuroms and you will be able to download a 91 octane map.
dtpebs is offline   Reply With Quote
Old 09-12-2007, 10:20 AM   #7
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
rkramer is right. Please try to post accurate information especially when it pertains to something as sensitive as engine management. /channeling Uncle Scotty.
I can understand where the confusion might come from, however octane has NOTHING to do directly with AFR. Since 91 octane has a lower knock threshold (ie what the octane rating measures) than 93, the ECU will ONLY run richer on 91 than it did with the 93 if it detects the presence of knocks. Otherwise fuel is fuel and the ECU has no way of detecting what sort of octane gas is in the tank BEFORE a knock event occurs.
Worxman02 is offline   Reply With Quote
Old 09-12-2007, 05:21 PM   #8
kyledooley
Member#: 1055
2005 No legacy for u
It's a diesel
I'm hoping you intend to keep your car registered in Mass. You're going to fail your emissions test in about 4 seconds with no cats, that's if you don't get pulled over by a CHP officer that happens to follow you and not like your stink a$$ exhaust.
kyledooley is offline   Reply With Quote
EQ Stage 1 Shortblock, EQ Stage 2 Heads, VF39 + 91 Octane = 279whp/333ft-lbs! Equilibrium Tuning Proven Power Bragging 16 01-15-2010 08:02 PM
Differences between Cobb Stage 2 maps for 91, 91 and ACN 93 2slow AccessPort 0 02-12-2009 06:04 PM
115 octane on cobb 93 stage 2 map 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 66 06-20-2007 03:07 PM
Can I get away with just the Stage 2 Map with these mods or is a Protune necessary? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-16-2005 12:11 AM
Vishnu Stage 2 STi dynosheet 91 octane and racegas pio!pio! Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-10-2004 12:42 PM
