#1 |
Member#: 125108
NESIC
Vehicle:2002 WRX WRB |
so ive searched this question with no luck.. i just moved to socal for mass. out in mass we have 93 octane so i was running a stage 2 xpt 93 octane map. driving across the country i found that iowa and nebraska only have 89 octane and 90 octane was a treat. now that i live in cali i can only find 91 octane. am i doing harm to my car by using the lower octane, and should i try to flash my ecu to a 91 map? i currently don't have a laptop like back east. so its a bit more of a hassle to do.
engine mods: injen cai 3" catless turboback catless uppipe thanks
#2 |
Member#: 105629
NWIC
Vehicle:2006 300c SRT8 Silver |
IMO, you'll probably want to switch to a 91 octane map pretty soon. You're basically making your current map lean out the car a little because it expects 93 octane but you're only giving it 91 (which, I hear, isn't great quality in some parts of California, Nevada and Arizona). It'd be pretty safe going the other way (ie. 93 octane with a 91 octane map) because rich is better than lean, but probably not the best idea vise-versa.
#3 |
Member#: 130355
Vehicle:2006 Impreza WRX WRB |
Cobb has a map designed just for the crappy piss you call gas in California. I'm not sure a standard 91 octane map would even be safe in California.
#4 | |
Member#: 118209
MWSOC
Vehicle:2002 WRX Sedan |
octane doesn't have much to do with the AFR. the AFR won't change (much) with different gas. what does change is if the car knocks or not, at a certain RPM it might need more fuel to prevent knock, even though it technically isn't lean, or at least any more lean then before. |
#5 |
Member#: 157526
RMIC
Vehicle:2012 |
I have a 91 oct map that runs great if you want it (STG 2)
#6 |
Member#: 98084
MWSOC
Vehicle:2008 WRX Sedan Charcoal Grey |
Sign up at osecuroms and you will be able to download a 91 octane map.
#7 | |
Member#: 66563
Tri-State
Vehicle:2002 Impreza WRX WR Blue Pearl |
I can understand where the confusion might come from, however octane has NOTHING to do directly with AFR. Since 91 octane has a lower knock threshold (ie what the octane rating measures) than 93, the ECU will ONLY run richer on 91 than it did with the 93 if it detects the presence of knocks. Otherwise fuel is fuel and the ECU has no way of detecting what sort of octane gas is in the tank BEFORE a knock event occurs. |
#8 |
Member#: 1055
MWSOC
Vehicle:2005 No legacy for u It's a diesel |
I'm hoping you intend to keep your car registered in Mass. You're going to fail your emissions test in about 4 seconds with no cats, that's if you don't get pulled over by a CHP officer that happens to follow you and not like your stink a$$ exhaust.
| Thread Tools | |
| Display Modes | |
| EQ Stage 1 Shortblock, EQ Stage 2 Heads, VF39 + 91 Octane = 279whp/333ft-lbs! | Equilibrium Tuning | Proven Power Bragging | 16 | 01-15-2010 08:02 PM |
| Differences between Cobb Stage 2 maps for 91, 91 and ACN 93 | 2slow | AccessPort | 0 | 02-12-2009 06:04 PM |
| 115 octane on cobb 93 stage 2 map | 03clipsegts | Factory 2.5L Turbo Powertrain | 66 | 06-20-2007 03:07 PM |
| Can I get away with just the Stage 2 Map with these mods or is a Protune necessary? | Red Rexx | Factory 2.0L Turbo Powertrain | 13 | 11-16-2005 12:11 AM |
| Vishnu Stage 2 STi dynosheet 91 octane and racegas | pio!pio! | Factory 2.5L Turbo Powertrain | 0 | 09-10-2004 12:42 PM |
