Old 09-06-2007, 11:06 AM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Difference between 04-06 USDM STi heads and 07 heads?
Are there any differences between these year model heads?
wittmer25 is offline   Reply With Quote
Old 09-06-2007, 11:53 AM   #2
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Yes. I don't know all the specifics, but I think the 07 heads have a smaller combustion chamber, and different cooling passages.
TAPOUT is offline   Reply With Quote
Old 09-06-2007, 12:26 PM   #3
Member#: 106514
D25 cylinder head castings castings
- Added air injection
- 49.6cc combustion chamber
- Cooling passages, and most internal area of the casting is different to allow for the air injection.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 09-06-2007, 01:26 PM   #4
wittmer25
Member#: 102970
2004 STi gt30r
so my next question, are the 07 heads compatible with an earlier sti ej257 block?" i have heard of a block off plate for the air pump.
Old 09-06-2007, 04:43 PM   #5
R & H Garage
Member#: 139767
you'd need a custom piston. Otherwise your compression ratio will be around 9:1... if you don't want that.
I like 9:1.
Also, people with high HP 07's are showing cooling issues. Actual reason isn't known. It could be not enough flow in the heads or volume in the cooling system.
R & H Garage is offline   Reply With Quote
Old 09-10-2007, 05:22 PM   #6
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
- J.
can you explain what a D25 cylinder head casting is? or do you mean it actually says "D25" on the outside of the heads?
and how is the internal area different because of the air injection?
i put an 07 motor into my car and removed the air pump in the process to make room for other things. i also recently did a TGV delete and noticed the intake ports of the heads are very rough.
thread on the subject posted here: http://forums.nasioc.com/forums/show....php?t=1337066
TROLL is offline   Reply With Quote
Old 09-11-2007, 06:02 PM   #7
Devan M
Member#: 83435
I like 9:1.
Crawford stocks the custom components for the 07's that give you an 8.2 to 1 compression ratio.
Devan M is offline   Reply With Quote
Difference between a Perrin downpipe for 08+ and 07- mudbug Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-04-2009 07:08 PM
Differance Between 04-06 and 07 STI Heads javastiwagon24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-15-2008 07:29 PM
Help! Differences between 04 & 05 STi ECU caffee Engine Management & Tuning 1 12-27-2006 03:21 PM
difference between 04-06 sti and wrx 6 disc changer BuggeyEYED Interior & Exterior Modification 6 10-10-2006 09:59 AM
Difference Between 04 & 05 STi Clutches? spoolinsuby Transmission (AT/MT) & Driveline 1 05-10-2005 04:52 PM
