South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-07-2007, 12:49 AM   #1
dblurx4
Member#: 124935
'05 WRX
Default Help with me HKS SSQ...
Ok, heres the deal. I received the BOV for Christmas last year. I installed it and it worked perfect for about 2 weeks. Then all the sudden one week it just started acting up? My car was jumping around at idle, and fell on its face a couple times. Figured it was a vac. leak of some sort. So I took it off and re-installed my stock BOV and it fixed the problem immediately. Any ideas on how to fix it, what to look for etc... It has been sitting for months. Any input would be great... I need the BOV for more power, so PLEASE help me !
Thanks in advance
Justin
dblurx4 is offline   Reply With Quote
Old 09-07-2007, 12:57 AM   #2
shwoop_soobie
Member#: 102323
99 power poles
beware
my advice would be to use your stock bov. the hks one acted up because your car does not like it... it likes stock, re-cerc
what kind of power are you planing on having...? i don't see any reason the stock wouldn't work with any type of reasonable power...
find uni bombers thread on bov's... it will answer all
shwoop_soobie is offline   Reply With Quote
Old 09-07-2007, 01:02 AM   #3
dblurx4
Member#: 124935
'05 WRX
Hey thanks, I received the BOV as a gift from my gf. She has been wondering why the hell its not on my car ... So I was just looking to fix the problem, for I wouldnt mind having it back on. If I sold it she would, well you know how women are . . .
Old 09-07-2007, 05:23 AM   #4
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
have you checked to see if it is leaking air? not sure how to check it tho. Try nasioc technical boards.
tspinks is offline   Reply With Quote
Old 09-07-2007, 07:11 AM   #5
dozer54321
Member#: 116437
2002 WRX - MINE
99 SUS - WIFEY
gormonks car did the same thing when he put on his full atmospheric, it would die at idle, he tuned it out, did you reset your ecu when you put your BOV on for "more power"
dozer54321 is offline   Reply With Quote
Old 09-07-2007, 10:27 AM   #6
dblurx4
Member#: 124935
'05 WRX
I didnt try that... I called HKS and they told me just to get the car tuned with the BOV on my car. So I guess here in a couple weeks im going to get a header abd APS 3", I will just tune it then. I was told to tune it with it on there, and also I was told to just disassemble the whole thing and put it back together. But the darn thing is brand new. So do you think I should just try putting it back on, then unplugging my battery and seeing where it gets me?
Old 09-07-2007, 10:43 AM   #7
dozer54321
Member#: 116437
2002 WRX - MINE
99 SUS - WIFEY
you can try it, but your better off just keeping the stocker on until you get tuned but you can try the ecu reset if you want to try it
Old 09-07-2007, 04:35 PM   #8
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
id say put it on night before ur tune, after tune u should be gold
Old 09-07-2007, 06:08 PM   #9
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
The hks is known to leak and cause this problem. There are a lot of hks fakes out there also which have crap build quaility.
If your car runs fine with the stocker then I think you have a problem with the hks. If you are able to tune it out then you are just putting a bandaid on the problem and not fixing it.
Smoby is offline   Reply With Quote
Old 09-07-2007, 06:39 PM   #10
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
stand on one foot, tap hks twice with index finger, say 5 "hail marry's", re-install hks bov, start car...
and it still will run like poop, cause hks+suby is not a good match.
WgnWheel is offline   Reply With Quote
Old 09-07-2007, 10:41 PM   #11
gormonk
Member#: 98960
1978 brat (fo realz)
red
i'd like to know where you got that info. with the design of the hks it is impossible to leak unless
1. its broken
2. car has a vacuum leak
but yeah dude resetting the ECU wont be enough. there are ways to tune around it. leave the stocker on for now. it took me 2 months to tune for my atmospheric bov. its a pain in the ass.
gormonk is offline   Reply With Quote
Old 09-07-2007, 11:13 PM   #12
dblurx4
Member#: 124935
'05 WRX
Thanks guys for all of the help. My girl purchased the BOV from hopupracing.com. Im pretty positive its the real deal, but then again who knows? The car runs perfect without the HKS on there. So for now I will just stick with it... When I get my car tuned next here in a couple weeks, I will slap it on there and see where it gets me. If the same result occurs, I will just put my stocker back on. To be honest, I really do like the way it sounds ... I might just go ahead and see if I can go a different route, maybe the Greddy RS or something else? Is there any full atmospheric BOV out there that doesnt give you trouble?
Old 09-08-2007, 12:04 AM   #13
gormonk
Member#: 98960
red
greddy RS is what im usin
Old 09-08-2007, 12:38 AM   #14
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
I have heard of a few leaking when at idle. The MAF tells the ecu how much air is being used and fueling is adjusted accordingly. If you have a leak then your motor is getting less air then the ecu thinks so you run rich.
How did you tune out your issue, mess with the maf table?
Old 09-08-2007, 12:55 AM   #15
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
1. its broken
That is what I was saying earlier, a lot of fakes means crap parts which break. The shaft inside likes to stick also
I actually had a ssqv and it leaked where the vaccuum nipple went into the bov if I put any pressure on it.
Old 09-08-2007, 01:07 AM   #16
gormonk
Member#: 98960
red
thats cause of a bad seal where it goes into the housing. a buddy of mine had the same problem. i took it apart and fixed it with a new fitting. but yeah after messing with my maf table and afr table i was able to tune it out completely. dozer can attest to how well my car runs in stop and go traffic (thats what most of our work commute was.)
Old 09-08-2007, 08:14 PM   #17
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
I'm pretty sure that HKS makes a kit make it a re-circ. BOV. I personally don't like external BOV, they're noisy and waste perfectly good, filtered & metered air. unless it's to run different piping arangements, such as a front mount.
John2.5RS is offline   Reply With Quote
Old 09-08-2007, 09:31 PM   #18
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
pm treefrogaz for a tune man, best thing you can do.
SubeSTIle is offline   Reply With Quote
Old 09-09-2007, 02:26 PM   #19
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
desmo750 is offline   Reply With Quote
Need Help With My HKS Turbo Timer Type1 TeamDeezNutz Electrical & Lighting 5 09-18-2009 07:53 PM
help me with my HKS ssq bov djpete Tri-State Area Forum 5 12-31-2005 03:36 PM
Help with an HKS SSQ BOV dexterous Factory 2.0L Turbo Powertrain 8 09-12-2004 12:47 PM
Anyone up to help with an HKS SSQV shaneswrx Mid Atlantic Impreza Club -- MAIC 1 11-11-2003 09:33 PM
Need help with me S-AFC settings??? Xscreamer Normally Aspirated Powertrain 3 02-21-2001 08:13 AM
Message Board Statistics All times are GMT -4. The time now is 04:12 PM.
