Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 08-19-2007, 09:20 PM   #1
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Default adjusted my cusco
well i finally got around to restacking the clutch's in my cusco RS rear diff, thanks to the guys at Z-1 for the info on how to stack'em. it was kinda interesting/fun since ive never done anything like that before. i had it set at 100% cause i didnt realize they were adjustable. now i have it set to 60% and the noise difference is amazing. where the slightest turn u would hear the rear diff now its completely quiet, ok not completely but at least my gf doesnt say somethin around every turn. i havent had a chance to push it yet tho, i wonder if ill notice a difference in the way the car acts in corners and whatnot.
getting the rear assembly out wasnt to hard, the part that took me the longest was figuring out how to take it out of the housing, and taking the diff itself apart. dropping the springs didnt help either, but at least i know how to do it now
romanlynch is offline   Reply With Quote
Old 08-19-2007, 09:40 PM   #2
keaniegenie
Member#: 94494
2005 Element 92x
very interesting.
I have cusco rs diffs on front and rear not yet installed. a 1-way front and 1.5 way rear. I was going to set both at 60%.
Please report any performance differencesm
keaniegenie is offline   Reply With Quote
Old 08-20-2007, 02:02 PM   #3
romanlynch
Member#: 126684
02 wrx
when i got it apart i saw that you can adjust the diff to be a 1-way, 1.5 way or 2 way, they are all from the same unit, its just how u put it together. if you need'em i have the page for how to stack the clutches.
Old 09-12-2007, 12:19 PM   #4
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
i have a cusco in my r180 - but have no idea what it was set to when installed
it "clunks" or "chatters" with every turn and in reverse
is this common?
MrMcCrackin is offline   Reply With Quote
Old 09-12-2007, 01:19 PM   #5
romanlynch
Member#: 126684
02 wrx
if they didnt adjust it then its at 100%. yes all that noise is "normal". ive been told that you can add some lsd modifier and it will take care of that, but i have not done this myself to confirm it. i have the paper that shows you how to re-stack'em if you wanna do that.
and please dont pee in my butt
Old 09-12-2007, 01:23 PM   #6
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
tanx for da update!
instead of pee'n - i will just get my clunk on!
lost my Cusco 2R damper adjuster, alternative tool? Carbon888 Brakes, Steering & Suspension 3 08-09-2006 02:13 PM
Moving to the stiffest setting on my Cusco adjustable swaybar on my STI; any thoughts Nivek-CA Brakes, Steering & Suspension 37 05-04-2004 12:26 PM
Any reviews of 22mm front and 22mm adjustable rear Cusco sway bars for the Sti whiteguyblacksti Brakes, Steering & Suspension 1 04-23-2004 03:48 AM
got a free cusco rad cap with my cusco oil can rad leaks? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-09-2002 04:43 PM
Adjustable 21mm Cusco swaybar CRAZY KEN Brakes, Steering & Suspension 0 07-02-2001 11:05 AM
