Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 09-14-2007, 04:33 PM   #1
InfamousDX
Member#: 25413
Question How to put a 2007 usdm sti 6 speed into my 2003 WRX
Searched but to no avail. If it's somewhere, sorry for posting this.
So lemme lay it out simple. 2007 usdm sti 6 speed transmission. 2003 wrx. What will I need to complete this swap WHILST keeping the stock r160?
I only ask about these specific years because I read the 07 usdm sti rear diff is 3.54 just like WRX's now so this swap should be easier than in the past. Thanks all.
InfamousDX is offline   Reply With Quote
Old 09-17-2007, 12:20 PM   #2
InfamousDX
Member#: 25413
just bumping this up in hopes for some insight.
Old 09-17-2007, 12:30 PM   #3
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
is the 07 sti tanny the same as the 06? if so you will be able to keep your r160 if you drive a bugeye
AWDWRXLOVER is offline   Reply With Quote
Old 09-17-2007, 09:14 PM   #4
InfamousDX
Member#: 25413
Did you do the swap? What do I need from the sti - tranny, linkage, shifter, clutch + flywheel setup... anything else?
Old 09-18-2007, 06:29 AM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
depends on which swap you do. i went full out. 5x114 hubs,r180, brembos front and rear etc. if you want to keep stock brakes you will need shorter drive shaft(auto), 04 sti axle front stubs w/ clips. there are several good sticky thread w/ links to other swpa threads that are very useful. read up and get a plan and budget before you start buying parts.
there are little things you will need to, fly wheel bolts for example, wrx has less than sti.
Old 09-18-2007, 11:47 AM   #6
InfamousDX
Member#: 25413
I've been reading and I've successfully done an 04 sti into a wrx, but I thought the 07 was slightly different.
I plan on keeping the WRX rear brakes (have 2 pots w/kartboy adapters) and alerady have 04 sti brembo fronts with my factory WRX axles. I plan on keeping the r160 as well so i guess the auto DS is in order.
Old 09-19-2007, 05:50 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
bookmarking this as I am also interested in this swap with the good 07 ratios. I can't imagine how much one will cost right now though
rjrutzky is offline   Reply With Quote
Old 09-19-2007, 10:55 PM   #8
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Just wondering, how did the wiring harnesses match up? I know mine will be different being an 04 6 Speed but i don't know if i will have to hard wire it in...
Jpizzzle is offline   Reply With Quote
Old 10-16-2007, 08:05 PM   #9
InfamousDX
Member#: 25413
bump.
Old 10-17-2007, 12:45 PM   #10
MrSlowbaru
Member#: 129231
2005 wrx
cgm
to the top, somewhere i heard that the 07 trannys are more of a drop in affair than the 06's were.
i want to confirm
MrSlowbaru is offline   Reply With Quote
Old 10-18-2007, 12:06 AM   #11
speedracer500
Member#: 6167
2002 WRX Big build
06 STi built, 00 L wagon
I have an 2007 sti limited tranny in my 02 WRX using stock R160 diff. Contact east coast swappers (http://eastcoastswappers.com/) (they did my install). There is a kit that they use to mate the drive shaft and axles to the tranny.
speedracer500 is offline   Reply With Quote
Old 10-27-2007, 01:54 AM   #12
speedracer500
Member#: 6167
2002 WRX Big build
bump.
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 811 12-02-2016 08:36 AM
How To - Swap a 2004 USDM STi Steering Wheel into a 2002 WRX Rizzo314 Interior & Exterior Modification 133 10-03-2016 10:30 PM
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 03:02 PM
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 11:04 PM
USDM STI 6-speed into USDM WRX? hobbzz Transmission (AT/MT) & Driveline 12 01-12-2003 04:26 AM
