Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 09-20-2007, 02:49 PM   #1
biohazard06
Member#: 148934
06 sti
Default spark plug warranty issue
Make: 06 sti
Mileage: 17k
Time Out Of Use: 1day
Problem And Likely Cause: spark plugs
Modifications: none
Submitted For Warranty Work (Yes/No): yes
Reason Given For Denial: wrong spark plugs in car
Your Story: I bought my 06 sti bout six months ago. It had after market intake and bov, both installed with no tune. I took those parts off and put all new factory parts back on it. A few weeks ago I started having rough idle. So I thought it was the spark plugs fouling because of the after market parts and improper use of them. I searched around for a week trying to figure out what plugs to use. I found the Spark plug FAQ on here http://forums.nasioc.com/forums/showthread.php?t=518633
It was recommended to use "
The correct spark plug for you is SOA part number 22401AA630.
Denso Iridium IKH22 is the correct sized one step colder plug as seen on this thread.
NGK LFR7AIX (#2309) is the correct sized one step colder plug as seen on this thread.I could not find LFR7AIX in stock any where in reno nv. So I bought LFR6AIX. CEL comes back on the day after I installed the new plugs. So I took it to the dealer to have it checked out. They told me that the wrong plugs are in the car and that is what is causing the problem. They wanted $400 to fix the car since the plugs were not covered under the warranty (the correct plugs from the dealer are $22 each). And they suggested not to drive my car at all because it will cause further damage to the car. This made me mad, I've done the search to find out what to use. And they wont honor the warranty. I'm not saying that the spark plug FAQ is wrong but. just a warning to all the people using any plug other then stock could have this same problem. I told the guy that I cant afford to pay for it right now and if I take the car home and put the right plugs from the dealer in, will they honor the warranty. He told me yes it would and that I can bring the car back they will look at it again to see what the underlying problem really was. The service adviser then told me that it was going to be $103.00 for them just to look at the car because the incorrect plugs took it out of warranty. I was even more angered I told him that I came in for a check to see why the CEL was on and the car was under the org. warranty so it should not cost me anything. We talked about it he told me he understands and the they will wave that fee this time as a courtesy. And when I bring the car back with the right plugs they will not charge because the car will be back under warranty.
My question is has any other member here had this same problem?
biohazard06 is offline   Reply With Quote
Old 09-20-2007, 06:58 PM   #2
JRSC13
Member#: 49479
05 05xt sti stg 2
pp
doubt it, i work at a dealer and you can understand that it took some time for the tech to figure out what was wrong, and he is still getting paid. since the wrong plugs were in it, no warranty for that problem, consider yourself lucky they waived the fee at all........
JRSC13 is offline   Reply With Quote
Old 09-20-2007, 09:24 PM   #3
biohazard06
Member#: 148934
06 sti
I know what they did. its the same thing I did to figure out the problem the first time. They scaned the car got the code for "misfire cyl number 2" So i pulled the plug and the plugs are the factory org. at that point. The plugs are messed up. fouled and bad lookin. So i searched on here what to replace them with and all I could get here was LFR6AIX. i was going one step colder cuz i was gonna run meth/water and tune it. but not after this. the guy and i worked it out. he said i can put plugs in from them then they will look at it again.
Old 09-20-2007, 11:07 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
you should have taken it to the dealer in the first place, before replacing the plugs. If the plugs were the issue, they would have replaced them under warranty...they are covered 3/36.
It looks like they are giving you a break. Put the originals back in and take it back to them. If turns out not to be the spark plugs, they can go from there.
RexyGirl is offline   Reply With Quote
Old 09-20-2007, 11:21 PM   #5
biohazard06
Member#: 148934
06 sti
I was thinking about doing that. But I told the dealer that i didnt put the plugs in it. They want me to buy their plugs and I can put them in myself and they will honor the warranty. Just cuz I dont wanna pay $90 for plugs i'm going to do that. And see what they say. The guy also told me that if the wrong plugs did anything it wont cover warranty. but they were in the car less then 15miles. so that is not true.
Old 09-21-2007, 04:54 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
next time check your owners manual, the correct spark plugs are listed in there.
If you dont have one, ask the dealer.
munkis is offline   Reply With Quote
Old 09-21-2007, 06:07 PM   #7
tomt5078
Member#: 84619
2013 BRZ
No and I would never put the wrong plugs in my STi let alone my lawn mower
tomt5078 is offline   Reply With Quote
Old 09-21-2007, 09:34 PM   #8
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Well since the issue is that it had wrong plugs... definatly not a warranty issue since the plugs are not the ones installed from the factory. As for waiving the diag fee, just because a car is under warranty, does not mean all repairs will be. Your cel can come on because you didn't tighten the cap. At the dealership I work at, all customers sign an hour authorized time for all cel concerns even if the car is under warranty. Sure you had already diagnosed the issue... but if warranty is to be done, then the tech must perform a diagnostic check themselves. Paying $100 for that if not under warranty is reasonable. Just buy the plugs, install them yourself and if the cel comes back on your good to go. Unless its proven the issue came from previous mods and no engine tune.
Mavrik is offline   Reply With Quote
Old 09-22-2007, 12:52 AM   #9
biohazard06
Member#: 148934
06 sti
thats what i'm going to do
Old 09-22-2007, 03:21 PM   #10
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Don't forget that you can get Subaru parts at a discount by internet/mail order from a number of the forum sponsors.
armand1 is offline   Reply With Quote
Spark plug issue traffic80 Service & Maintenance 2 05-20-2009 01:53 PM
1998 2.5RS spark plug wire issue. Keith Service & Maintenance 2 02-17-2009 09:14 PM
Spark Plug Issue Blackmojo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-14-2007 09:21 PM
Having Issues With Spark Plugs cruzinWRX2 Service & Maintenance 3 11-02-2006 09:53 PM
Spark Plugs, CEL's, Misfires, and UTEC issues JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 04-16-2003 01:35 PM
