Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-28-2007, 07:41 PM   #1
pjo42387
Member#: 139295
2003 Silverado
07 R1
Default problem with eniginuity
When opening the logger. It says on the bottom left ''Cannot connect to ECU, check serial port, cable is connected ignition is on''. Ive only used ECU flash to flash my stg2 map and i wanted to delete some CEL's i got. I have the p2433 air injection system. Also can i disable all codes that have to do with the air injection system? Theres like 6 or 7 of them.
pjo42387 is offline   Reply With Quote
Old 09-28-2007, 08:13 PM   #2
Tea cups
Member#: 103136
the logger has nothing to do with disabling CELs. You need to open your rom in Enginuity (File menu), disable the CELs, save and then flash it to the car with Ecuflash.
Old 09-28-2007, 09:42 PM   #3
pjo42387
Member#: 139295
2003 Silverado
07 R1
I know the logger has nothing to do with the CEL's, i just want to log my car as well as turn off the codes. For some reason it wont connect though.
Old 09-28-2007, 10:14 PM   #4
Tea cups
Member#: 103136
did you try changing the com port from the drop down box in the logger?
Old 09-28-2007, 10:18 PM   #5
JMS77
Member#: 136833
Just an FYI, the Logger does not work on the Intel Macs. There is no 'com port' number and there is no alternate way to make the Mac recognize the USB/Tactrix cable.
The editing functions work perfectly though.
JMS77 is offline   Reply With Quote
Old 09-29-2007, 12:02 AM   #6
pjo42387
Member#: 139295
2003 Silverado
07 R1
ya i tried that and neither of them work. This is on a windows xp.
Old 09-29-2007, 09:02 AM   #7
Tea cups
Member#: 103136
Sounds like a driver issue. You said that you flashed your map with Ecuflash? Did anything change between when you flashed your map sucessfully and when you tried out logging? For example, did you upgrade to a newer version of Ecuflash? Are you still using a tactrix cable?
Thread for 2006 WRX's with Stock Transmissions with no problems with more WHP/WTQ rhinotech Transmission (AT/MT) & Driveline 233 07-19-2013 09:33 PM
Boost problems with VF34 fordfabwiz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-20-2010 07:28 PM
Got a little problem with the speakers, needs help to pinpoint the problem. SilentShadow Car Audio, Video & Security 4 12-03-2006 09:34 PM
Problem with AT - 2 gears, problems shifting. mrmephistopheles Transmission (AT/MT) & Driveline 0 07-10-2006 05:35 AM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 11:23 AM
