Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 04-26-2007, 04:25 AM   #1
Wrx1234
Member#: 142341
2004 2.5L GT30rd WRX
SRR
Default How-to: 02-04 WR to 05+ Center Console Upgrade
So all of us who HATE our bugeye or 04 center console, here is exactly how i put in the 06 sti (same as all 05+) center console while maintaining the manual HVAC for affodability. (notice i didnt put sticky due to lack of pics)
1. get all the parts together to avoid 10 trips to the dealer like me:
Upper AC vents w/ hazard switch
Radio Bezel from an 06 TR
Shifter Trim w/ Ashtray
Ebrake/Cupholder Trim
Main center Console W/ armrest
05+ ebrake handle (need to use 02-04 cable just bend a tab to remove it)
05+ main center console bracket (underneath armrest)
Radio Surround (the black part that surrounds the radio bezel actually part of the dash color scheme)
Metal center console reinforcement bracket
Metal radio mounting brackets from an 05+
- All this i got for about 340 dollars (some used some new from dealer)
2. Start by disassembling the 04 console. (20 minutes)
-Remove all components, leaving nothing but the dangling harness.
-This includes the metal bar that anchors the center console to two screws (one on the glove box one on the opposite side)and the two 12mm bolts
-Also remove the main center console bracket
-To remove the ebrake, disconnect the 7" ebrake cable from the two ebrake cables coming from the back and swap the 5" cable that is connected to the 04 ebrake. Just use pliers to pull up the metal tab
3. Install center console (20 minutes)
- Reinstall the metal brackets removed in step 2 first
- Install the 05+ radio brackets onto your radio
- Install ebrake, bolts into the metal bracket you just installed and another stud already there.
- Install the rest of the trim, simply bolts back into place
than your left with this...
heres a partial parts numbers list
66061fe010 center vents 1
66063fe010oe lower console panel 1
66063fe000oe lower console panel right 1
92178sa000 bracket for center console 1
92178sa020 2nd bracket for center console 1
92177sa000 mat for cupholders 2
045104123 tapping screws/lower panel 10
045005143 tapping screws/center panel 10
92112fe500oe center console box 1
92126fe000 center console shift surround 1
66086fe000oe center console lower trim 1
66231fc030oe dash clips/trim clips 4
66201fe100 radio bracket 1
66201fe110 radio bracket 1
904710005 dash screws 20
92132sa030oe ebrake/center console cover 1
unknown--ebrake assembly
unknown-- center console reinforcement
EDIT: My radio is crooked becuase i have not installed my radio brackets yet :P
Wrx1234 is offline   Reply With Quote
Old 04-26-2007, 11:11 AM   #2
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
ill doing mine sooon to fit the aux plug for my 07 radio
teamslow wrx is offline   Reply With Quote
Old 04-26-2007, 11:54 AM   #3
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Does your radio not sit flush?
sheepdog is offline   Reply With Quote
Old 04-26-2007, 11:59 AM   #4
DieselClown
Member#: 36135
2005 WRX
^ I was going to ask. or is it just the picture?
DieselClown is offline   Reply With Quote
Old 04-26-2007, 01:52 PM   #5
Wrx1234
Member#: 142341
SRR
editted
Old 04-26-2007, 02:08 PM   #6
sheepdog
Member#: 93773
1995 Flat Khaki GC8
2011 STi Wagon
Ahh, I figured that might be it. Luckily it's an easy fix
Old 04-26-2007, 09:36 PM   #7
JustinsWRX
Member#: 72735
What is the part number the the trim piece that goes around the radio and hvac controls? Im having trouble finding it on www.subarugenuineparts.com I can find the part using the search, but it does not specifiy if its the TR, WRX, or STI trim. And seeing as how the STI trim is different and wont work with my cable driven controls I don't want to order that one.
JustinsWRX is offline   Reply With Quote
Old 08-30-2007, 10:44 PM   #8
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Radio Bezel, 06 TR:
66069FE020
I am almost done with my swap. 05+ STi Door Cards and 05+ STi Center Console. Power mirrors were wired up today and work just fine. Get the male plug/pigtail from the 05+ door for the mirror switch. There are 7 wires and it uses the same colors as 02-04. Extend/trace the wires over to the center console plug (where the switch used to be connected) and done deal.
lancelucas is offline   Reply With Quote
Old 08-31-2007, 02:27 PM   #9
Ghost Rider
Member#: 70346
2013 Focus ST
Performance Blue
wow, now i want to do this
Ghost Rider is offline   Reply With Quote
Old 09-01-2007, 10:50 PM   #10
law
Member#: 36842
2008 STI, S2000
AW, Black
is it possible just to do the lower part of the swap? so starting with the ashtray/shifter trim and back?
law is offline   Reply With Quote
Old 09-02-2007, 05:14 AM   #11
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
No...
Old 09-02-2007, 05:21 AM   #12
designfate
Member#: 114502
04 STi
Bugeye forever
do you really need to change the armrest part of the centor console. I thought it was just the upper piece of the dash, the trims, and the lower shifter/ashtray part, and also the part that surrounds the e-brake handle
designfate is offline   Reply With Quote
Old 09-02-2007, 08:39 AM   #13
law
Member#: 36842
2008 STI, S2000
AW, Black
Originally Posted by lancelucas View Post
No...
Alright, and the long answer is... JK
After looking closer its obvious, thanks
Old 09-16-2007, 04:23 PM   #14
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
04 WRX Wagon
05 STi Door Cards
05 STi Center Console
04 STi Front Seats
Feel free to PM/AIM me if you have any questions about the swap
Old 09-16-2007, 10:59 PM   #15
abgusaf
Member#: 143122
07 WRB STi
in the werks
No everything has to be replaced
Very Very easy upgrade tooke me maybe 45mins, everythings bolts right up
heres mine 02 wrx
Just as a reminder make sure to buy a new shift boot, this is an old pic, but as you can see that was the old sti shift boot
abgusaf is offline   Reply With Quote
Old 09-18-2007, 04:21 PM   #16
Hando567
Member#: 153595
2006 Impreza WRX STI
SGM
what exactly are these brackets?
Hando567 is offline   Reply With Quote
Old 09-18-2007, 06:19 PM   #17
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Looks like this will be my next mod lol
EdHilario is offline   Reply With Quote
Old 09-18-2007, 07:23 PM   #18
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
Sweet, bookmarking this for later modding.
dave_88 is offline   Reply With Quote
Old 09-19-2007, 10:04 PM   #19
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
There is a "tri-pod" bracket underneath of the armrest and associated plastics that needs to be changed out to the 05+ model. The 05+ bracket needs to be modded slightly to fit into the rear guide for it to fit correctly, but it's simple with a hacksaw or cutoff/grinder wheel. IIRC, one of the bolts (driver's side) is not re-attached with the new bracket, so only 2 of the 3 are bolted down.
The "Metal center console reinforment bracket" is referring to a metal bracket behind the upright part of the center console, under the radio.
Old 10-12-2007, 01:54 PM   #20
sxotty
Member#: 95600
2003 WRX wagon
The "Metal center console reinforcement bracket" is referring to a metal bracket behind the upright part of the center console, under the radio.
Can you expand on this at all? I have an 05 center console and right now it doesn't seem to sit flush with the bump for the tranny. Is this because of having the old bracket?
Also what do you mean by?
Found the answer to second question Tuner ready... but dont have any idea of the part number...
Thanks.
sxotty is offline   Reply With Quote
Old 10-12-2007, 02:24 PM   #21
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
^^^Yes.....
crazyGC8 is offline   Reply With Quote
Old 10-12-2007, 02:41 PM   #22
sxotty
Member#: 95600
2003 WRX wagon
Can you just use the Radio bezel from a regular impreza instead of an 06 TR? It is hard to find out exactly what I will be getting otherwise. Maybe the 03 bezel can be cut to fit though... I will be cutting it up anyway to put a LCD into it.
Old 10-12-2007, 05:02 PM   #23
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
edit- reading > me.
hdempsey is offline   Reply With Quote
Old 10-20-2007, 10:19 PM   #24
Hando567
Member#: 153595
SGM
so does anyone have the part # for this main center console reinforcement?
EDIT: is it possibly part #4 in this image
https://www.trademotion.com/schematics/7/7591411.gif
Here is the list to go with that image
1) Console assy 2) Pocket 3) Pocket Upper bracket
4) Pocket Lower bracket 5) Lid Upper 6) Lid Lower
7) Lock 8) Hinge 9) Hinge Cushion
10) Cup holder 11) Upper cover 12) Mat
13) Switch cover 14) Park brake cover 15) Seat heat switch Right
16) Switch Center differential 17) Socket 18) Cap
19) Ashtray housing 20) Ashtray 21) Shift housing Manual trans
22) Shift housing Auto trans 23) Shift plate Wrx sti 24) Manual trans W/o wrx sti
25) Shift indicator Auto trans 26) Manual trans W/o leather 27) Auto trans W/o outback
Old 10-21-2007, 02:59 AM   #25
InvertedB
Member#: 82455
Chapter/Region: HIIC
2006 Saab 9-3 2.0T
SportCombi
heres mine 02 wrx
What'd you do about the mirror adjustment switch that used to be in the center console?
InvertedB is offline   Reply With Quote
04 to 05+ center console swap mgsm666 Subaru Conversions 2 11-19-2012 09:42 AM
04 to 05 center console??? reddrex Interior & Exterior Modification 18 11-16-2012 04:28 PM
04 to 05 center console mbaker Interior & Exterior Modification 2 05-06-2009 02:39 PM
For those 02-04 who wants newer center console fluxcapacitor SCIC Private Classifieds 13 01-31-2008 10:55 AM
02-04 center console to 05+ center console swap? Wrx1234 Newbies & FAQs 2 04-15-2007 05:25 AM
