Old 10-21-2007, 02:18 PM   #26
SinisterSkube
Member#: 96012
2005 WRX sedan
i have an extra auto climate control hvac if anyones interested
SinisterSkube is online now   Reply With Quote
Old 10-21-2007, 02:50 PM   #27
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
i hate my console but i'm not paying $400 for nicer cupholders and a hidden lighter outlet.
great writeup, if i ever come across a wrecked 06 TR maybe i'd do it.
Handsdown is offline   Reply With Quote
Old 10-21-2007, 10:45 PM   #28
awd-box-turbo
Member#: 64057
04 impreza wrx
WRBlue
okay... so i started doing this mod... and i have the 06 tr bezel but the 04 climate controls dont sit in the 05+center console nor can they be mounted/screwed in... my question is did you guys buy an 06 tr center console or mod the 05+ wrx center console? anyone have any ideas on this or suggestions? oh and how did you guys shorten your e-brake cable? and also keep the handle from shifting to the left?
awd-box-turbo is offline   Reply With Quote
Old 11-05-2007, 09:58 PM   #29
awd-box-turbo
Member#: 64057
04 impreza wrx
WRBlue
how do you stop the e-brake handle from shifting to the left?
Old 11-06-2007, 04:55 PM   #30
Hando567
Member#: 153595
2006 Impreza WRX STI
SGM
you dont, you just put a new e-brake handle in.
Hando567 is offline   Reply With Quote
Old 11-06-2007, 05:01 PM   #31
crazyGC8
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
The way I read this, he's not talking about switching the different ebrakes out. He's talking about the 05+ ebrake leaning to the left in the 04(I think). I just bent the bracket on mine if thats what your referring too....
crazyGC8 is offline   Reply With Quote
Old 11-06-2007, 05:04 PM   #32
Hando567
Member#: 153595
SGM
oh, haha, well i havent done this yet (its nearly impossible to source an 05+ console for a decent price) so i didnt know it did that. my bad.
Old 11-06-2007, 05:13 PM   #33
crazyGC8
Member#: 107421
No biggy, I can tell you of a place that has the full console conversions all day long for around 300-320 shipped if your interested.
Old 11-06-2007, 06:06 PM   #34
Hando567
Member#: 153595
SGM
please do pm me with this place.
Old 11-08-2007, 02:35 AM   #35
awd-box-turbo
Member#: 64057
04 impreza wrx
WRBlue
crazygc8, how did you bend the bracket? also, are you referring to the e-brake assembly itself?
Old 11-10-2007, 12:40 PM   #36
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Originally Posted by InvertedB View Post
What'd you do about the mirror adjustment switch that used to be in the center console?
In my car, I swapped to 05+ STi door cards and switches at the same time as the console swap. I had Audio Integrations extend/re-wire my mirrors from the center console over to the door switch.
They will sit in if you position them correctly. Also, there are some metal clips that the manual control cars (06-07 TR) have that the other models do not that serve as the mounts for HVAC controls. You can see the rectangular openings where these clips are supposed to go in to. My console swap came with one clip and I was able to use zip-ties to secure the other three corners of the HVAC controls. Sounds cheesy, but it is very solid and works perfectly.
You don't shorten the cable, you swap the short cable that is connected to the handle from your 02-04 handle to your 05+ handle. As for leaning to the left, like someone else said, I just bent mine so that the handle was reasonably centered.
lancelucas is offline   Reply With Quote
Old 11-11-2007, 01:04 AM   #37
crazyGC8
Member#: 107421
Yes, the whole assembly needs to be bent slightly(not just the handle). I just bolted mine in and put the ebrake up and used it's own leverage to bend the bracket. Be careful though, you can mess up the ebrake if your not careful. You could put it in a vice and do it, but the way I did it worked fine for me...
Old 11-11-2007, 05:36 PM   #38
awd-box-turbo
Member#: 64057
04 impreza wrx
WRBlue
are we talking the left mounting tap w/ no mounting hole? or bending the right side of the bracket, where the nut bolts in?
Old 11-11-2007, 06:31 PM   #39
crazyGC8
Member#: 107421
I would say it's probably where the nuts bolt. Like I said above.... I just bolted mine in and tugged on it carefully so I couldnt say *exactly* what part of the bracket it is. Maybe someone else thats done it can chime in.
Old 11-17-2007, 12:41 AM   #40
Tougesteve
Member#: 161590
seeing as i cant make a new thread this looks like a decent place for my question :P
new owner of a 04 sti here... when i purchased it, it had a aftermarket headunit... i recently bought a oem 05 sti headunit and it all pluged up power radio connector was there but the speaker harness was spliced with an aftermarket harness... im having an extremely hard time finding a speaker harness not even at the dealer any suggestions ; ;
Tougesteve is offline   Reply With Quote
Old 12-05-2007, 10:58 AM   #41
Rice Devil
Member#: 51164
Jap Jp mag 09
Ti mag 09 (cover)
Good write up, but does anyone know if the newer centre console, spec C style is a plug and play into the bugeye?
RD
Rice Devil is offline   Reply With Quote
Old 07-05-2008, 07:49 PM   #42
wrxmeade
Member#: 171945
2004 WRX Wagon
Thumbs up
the zip tie method sounds cheesy, but I just did the exact same thing in my 04 to 06 console swap. Four zip-ties, one at each corner, and its not going anywhere. Great call.
As for the e-brake handle, even swapping the cable did not give me enough tightness in the line so I improvised a bit. I used a nylon spacer from Lowe's to 'shorten' the cable by an additional 3/4 inch. Now its OEM tight and no ordering special parts.
All in all, very easy, but it definitely took me like 3 hours to figure everything out the way I wanted. So again, very easy, just takes a bit of time.
wrxmeade is offline   Reply With Quote
Old 07-05-2008, 08:37 PM   #43
Hando567
Member#: 153595
SGM
does anyone know where one can get the rectangular clips? I havent been able to find any anywhere (even jamie over at subaru genuine parts couldnt find a Part number for me to order). Ive had mine in for awhile now, but i stole 2 of the clips from my OEM clock pod and the other two are the ones that hold the radio trim on. lol.
Old 07-06-2008, 01:45 PM   #44
Unrealgtx
Member#: 178853
2007 Sleeper Suby
im kinda confused as to why some pics have the silver sti trim around the boot and others dont? does this thing stick on or does it screw on because it doesint look like it will fit on the first post picture
Unrealgtx is offline   Reply With Quote
Old 07-06-2008, 08:21 PM   #45
Hando567
Member#: 153595
SGM
depends on if you get the STI console or the WRX one basically.
Old 07-07-2008, 01:36 AM   #46
Unrealgtx
Member#: 178853
2007 Sleeper Suby
oh ok so these part numbers are for an sti one or wrx one?
Old 07-07-2008, 01:37 AM   #47
Hando567
Member#: 153595
SGM
i honestly couldnt tell you. I just got my whole swap through millenium auto. No PNs needed
Old 07-07-2008, 09:08 AM   #48
MonkeyKarma
Member#: 147206
02 WRX
Blue of course
Great Job.
MonkeyKarma is offline   Reply With Quote
Old 08-01-2008, 05:36 PM   #49
lbleiweiss
Member#: 165573
2004 Subaru WRX STi
please tell me!
I googled it and there are TONS of millenium auto's could you please be more specific?
lbleiweiss is offline   Reply With Quote
Old 08-01-2008, 11:09 PM   #50
Hando567
Member#: 153595
SGM
the one thats a vendor on here. look in the vendor for sale section.
04 to 05+ center console swap mgsm666 Subaru Conversions 2 11-19-2012 08:42 AM
04 to 05 center console??? reddrex Interior & Exterior Modification 18 11-16-2012 03:28 PM
04 to 05 center console mbaker Interior & Exterior Modification 2 05-06-2009 01:39 PM
For those 02-04 who wants newer center console fluxcapacitor SCIC Private Classifieds 13 01-31-2008 09:55 AM
02-04 center console to 05+ center console swap? Wrx1234 Newbies & FAQs 2 04-15-2007 04:25 AM
Message Board Statistics All times are GMT -4. The time now is 08:37 AM.
